03-24-2014, 12:34 PM | #1 |
Project 6 Point Oh
I've decided to start a build thread after working on my 72 K5 Blazer for almost two years. I was just going to get it drivable and not do a restoration, but I couldn't stop myself LOL. Now I'm in the process of a frame off restoration, and dropping in a 6.0 LQ9 and a 4L60. I don't get much time off from work, so the process is slow, but steady. I was a mechanic years ago and worked on tons of these old trucks, but I got out of the business way before LS motors were introduced, so I will be needing advice on that end. I've taken tons of pics along the way and will post a few. Three things I don't do are transmissions, and paint and body work. Everything else I plan on doing myself.
03-24-2014, 12:50 PM | #2 |
Re: Project 6 Point Oh
This is what it looked like when I went to buy it. Sitting outside with no top on, roll bar in backwards, wiring pulled out, no brakes, and barely running. The truck looked good from a distance, but was really rough up close. The floor was toast but I couldn't tell because of a thick coat of fiberglass covering the damage. The gas door install was horrible and covered up by LOTS of bondo. The patch for the original gas neck hole was a thick layer of bondo too. |
03-24-2014, 12:52 PM | #3 |
03-24-2014, 12:56 PM | #4 |
I think the only thing electrical that worked was the ignition switch and an external horn button. lol |
03-24-2014, 01:07 PM | #5 |
Got the double wall top back on it and got it home. I don't think the top had been on it in a long time. It had been outside with no top, exposed to the elements for no telling how long. |
03-24-2014, 01:13 PM | #6 |
03-24-2014, 01:21 PM | #7 |
Got the front clip off and the motor and trans out. |
03-24-2014, 01:25 PM | #8 |
Found a 2003 6.0ltr out of an Escalade with 77K on it. |
03-24-2014, 01:31 PM | #9 |
I could tell there was going to be issues lol. |
03-24-2014, 01:36 PM | #10 |
Looks like it used to be white. The SPID was gone, so I wasn't sure. |
03-24-2014, 01:47 PM | #11 |
03-24-2014, 01:51 PM | #12 |
03-24-2014, 01:58 PM | #13 |
The wiring had more butt connectors and electrical tape than I'd seen in a while. |
03-24-2014, 02:00 PM | #14 |
Looks awesome!!
03-24-2014, 02:02 PM | #15 |
Vin plate match title? Ill watch
03-24-2014, 02:10 PM | #16 |
LS motor mount from Pacific Fabrication, 4L60 to NP205 adapter from Advance adaptors, and a Ididit tilt steering column. |
03-24-2014, 02:12 PM | #17 |
Yes VIN plate does match.
03-24-2014, 02:16 PM | #18 |
Oh boy |
03-24-2014, 02:20 PM | #19 |
Rusted out inner fender and a bonus quart of oil! |
03-24-2014, 02:30 PM | #20 |
puke |
03-24-2014, 02:34 PM | #21 |
03-24-2014, 02:39 PM | #22 |
At least the rocker boxes underneath were good. |
03-24-2014, 02:57 PM | #23 |
They had brazed a piece of metal behind the original gas neck hole, then filled the rest with bondo!!! It looked like a hockey puck went in there. |
03-24-2014, 03:03 PM | #24 |
03-24-2014, 03:08 PM | #25 |
That's gonna have to be replaced and redone correctly. So far this truck needs everything. |
