04-17-2014, 11:19 AM | #26 |
Re: Overheating issue
Sure about that?
project: "my happy mess" |
04-17-2014, 07:01 PM | #27 |
I disagree with your statment. My lower radiator hose has wire running through it to keep it from colapsing, from that "water sucker" pumping coolant through the engine.
1970 GMC K2500 aka MaTeR 2007 Chevy Silverado 1500HD Classic |
04-17-2014, 10:57 PM | #28 |
You're wrong! And it's simple to prove yourself wrong by removing your radiator cap, start the engine and let it warm up so the t-stat opens, and you will clearly see the direction of flow. As mentioned in this thread, there's a reason the lower hose has a coil wire inside it...and it's not there to add minerals to your coolant
Mark 71 C10 Cheyenne 12 Aprilia RSV4 |
04-17-2014, 11:39 PM | #29 |
The top hose should be empty when the thermostat is closed. When the thermostat OPENS, the pressure maintained/created by the water pump forces the heated coolant to pass by the thermostat (via engine) and enters into the radiator through the top hose -thereby causing the cooled coolant previously in the radiator to enter the engine via the bottom hose. When that cool coolant enters the engine, the thermostat recognizes and closes - allowing the newly heated coolant in the radiator to cool. Rinse, repeat.
04-18-2014, 08:53 AM | #30 |
Picture is worth a thousand words , YOU NEED A SHROUD , will solve your problem
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
04-18-2014, 10:29 AM | #31 |
That's it... I am calling my Dad...
I wonder what else he has taught me that is wrong... hahaha myyamr7 & litew8... thank you for clarifying/correcting me... that makes perfect sense. sjburk, sorry if I caused a lot of confusion.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
04-18-2014, 10:34 AM | #32 |
This last quote is incorrect. The picture with the arrows was correct.
04-18-2014, 10:42 AM | #33 |
Ive got similar problem, been told my alternator isn't providing enough power to my electric fan, and I don't have a shroud. new 4 core hoses, thermostats, caps,
only thing I haven't done is a heat gun. bout ready to let the shop tinker with it as I'm tired of driving with the heater on and its 115F out. (just got an original rear slider window, talk about a/c 8D ) |
04-18-2014, 10:49 AM | #34 | |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
04-18-2014, 02:21 PM | #35 |
Not sure it's the root cause but should definitely help.
04-18-2014, 02:23 PM | #36 | |
project: "my happy mess" Last edited by litew8; 04-18-2014 at 02:30 PM. |
04-18-2014, 02:39 PM | #37 | |
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
04-18-2014, 08:43 PM | #38 |
The comment about the shroud is partly true, but a 6 cylinder shroud is almost more of a fan protector than a shroud, it's not going to help a lot. You can see the black shroud on top of the radiator in this picture.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-18-2014, 09:35 PM | #39 |
Interesting
04-19-2014, 02:04 AM | #40 |
If we can't laugh at ourselves, who can we laugh at. all good
04-19-2014, 06:57 PM | #41 |
I've had good luck in the past with drilling the t-stat base. 1/8 hole seems to allow the air to pass back the to radiator without allowing too much coolant to pass. . Any bigger than 1/8 I think would defeat the purpose of the t-stat.
71 Cheyenne 4X4 SWB 383/350 |
04-19-2014, 08:49 PM | #42 |
I had the same problem as described at the beginning of this thread on my '66 250 CID: first cycle of the thermostat would peg the gauge. It was very concerning. Replaced every thing multiple times, nothing fixed it. Even thought of air bubble/pocket. Nothing worked until I did exactly as Curtm220 mentioned..., 1/8 hole in base of thermostat. That was 6 years ago and never a problem again. BTW, 6 cylinders didn't come with a shroud - no such thing.
04-19-2014, 09:01 PM | #43 |
No such thing because they weren't invented yet? Or just because there isn't enough heat generated to justify the need?
04-19-2014, 09:07 PM | #44 |
I doubt that,since all 67-72 L6s came from GM without a shroud.
04-19-2014, 10:00 PM | #45 |
Here's one on 60-66's, but he's got A/C and it's a 66. This is what I imagined it might look like, but I guess it was only for trucks (66 only?) equipped with a/c. Strange GM would eliminate the shroud, it looks dangerous without.
04-19-2014, 10:05 PM | #46 |
If the OP is still following along, I wonder if the problem is due to having replaced the thin two core radiator with a thicker 3 core radiator, and, not having a shroud.
04-19-2014, 10:23 PM | #47 |
There is a metal finger shield mounted
04-20-2014, 04:54 PM | #48 |
I was also thinking it may have something to do with that, I still have my old radiator and ive been considering having it restored my grandfather says he knows a guy and he will ask soon. And about that drilling a hole in tstat, can i see a pic of exactly where you drilled the hole?
1967 GMC C1500 1/2 ton I6 250ci |
04-20-2014, 09:28 PM | #49 | |
Google "drilled thermostat" and look at the images tab. Many thermostats now come new with a relief machined into the base to remedy the exact problem you're describing.
04-20-2014, 09:52 PM | #50 |
Wholly thermostat Batman! I wonder why the L6s that never had the drilled thermostat never had this issue all those years
