Old 04-27-2014, 07:35 PM   #26
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: What did you do to your Blazer/Jimmy today?
Installed a refurbished OEM am/fm truck radio, freshened up the AC ducts, and swapped the repro dash pad for a really nice OEM example. It took most of the weekend and taught me I need bifocals!
DeadheadNM is online now   Reply With Quote
Old 04-27-2014, 08:05 PM   #27
timski69gmc
timski69gmc's Avatar
Looks great! Gotta come see it in person.
timski69gmc is offline   Reply With Quote
Old 04-27-2014, 08:13 PM   #28
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks! Please do. I believe there's a parts swap here soon (but I have to work!).
Old 04-27-2014, 08:53 PM   #29
asolde
asolde's Avatar
Did some trouble shooting on the engine and found out the intake was leaking all the way around so I pulled that all apart cleaned it and ready to reinstall. Trouble shot my transfer case leak sure enough I have to drop it out and reseal the adapter. Put some new trim molding on my right rear body panel. Thats enough for me this weekend. Alex
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 04-27-2014, 09:05 PM   #30
71jimmy
71jimmy's Avatar
Pulled my gauge cluster and replaced the light switch, that fixed my dash light dimmer and my courtesy lights. Also fixed my tach, the needle would bind up at 1800 rpm, the needle sits on a spring all I had to do was slighty pull it out which now allows the needle to fully rotate. Also ran the wiring for the door pins that control the courtesy lights, now need to make a jumper to wire them in. Attempted to install my new passenger side inside fender after I had painted it, but decided to wait until I have some help so I don't fubar the paint.
Time for a nap!
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-27-2014, 09:06 PM   #31
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Alex how'd you trouble shoot for the leak? Nice new ride btw!! I've got a leaking heater core, my heater blows cool not hot, and my fuel gauge is inaccurate so I've got a lot more trouble shooting to.
Old 04-27-2014, 10:01 PM   #32
IlliniK5
Assembled my new grille with billet inserts....while watching hockey on my couch.
1970 CST K5. 350/TH350/205. Dana60/14FF. 2" rear/1" front lift. 33" Cooper AT3s on MT Classics black powdercoated. 4 wheel disk.
IlliniK5 is offline   Reply With Quote
Old 04-27-2014, 11:05 PM   #33
timski69gmc
Did a light refurbish on a used tach cluster I picked up last year. Finally installed it, but the temp gauge pegged to the top when I got the power on. Any ideas on that one? Off course the battery was too dead to fire it up, so still not sure if the tach even works. Throw the battery on the charger and try again tomorrow.
Old 04-27-2014, 11:27 PM   #34
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Wish I could help - having a real struggle right now with my fuel gauge which is off by 1/4 turn or so clockwise. I need to swap in the original cluster which was working well. Lights look good - I upgraded to brighter ones in my tach cluster, #168 IIRC
Old 04-28-2014, 12:13 AM   #35
timski69gmc
Bummer. Thought I had seen a thread somewhere on the Temp gauge. Will have to see if I can find it. I had a mixture of 168's and 194's in the three clusters I had in pieces. Wasn't sure which were the brighter ones, I mostly just wanted them to work. I think most were the 194's.
Oh, and got my K/5 emblems back one. Only had one when I bought it. Found another on Ebay and touched them up. Much better having matching emblems.
Old 04-28-2014, 05:43 AM   #36
asolde
asolde's Avatar
I sprayed brake cleaner around the intake while the engine is running and listen for rpm increase. Heater cores are a PITA I am sure you have study up on that one. I haven't had to trouble shoot a fuel guage yet.
Old 04-28-2014, 12:33 PM   #37
rwhite692
Repairs/Upgrades on the Dana44. New Yukon 4340 axles and ujoints, ball joints, hub bearings, seals, new Warn locking hubs, rotors, brake calipers. Degreasing 42 years of caked-on grease sludge, and bead-blasting everything took me more time than anything else...
rwhite692 is offline   Reply With Quote
Old 04-29-2014, 09:44 AM   #38
GhostTown
GhostTown's Avatar
Polished the bumper with a little never dull. Tried to polish some of the aluminum with little success.
GhostTown is offline   Reply With Quote
Old 04-29-2014, 10:12 AM   #39
Wasted Income
Boosted Member
Wasted Income's Avatar
Powdercoated the charge pipe to match the rest of the stuff.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-03-2014, 08:56 PM   #40
asolde
asolde's Avatar
Put my intake back with some new gaskets and it is running pretty good now, just got to dial it in a little. Set everything up to specification 8 degrees BTDC and 30 degrees dwell 650 rpm at idle.
Old 05-04-2014, 10:39 AM   #41
rckymtnhi
Finally was able to get this out of hibernation and begin the list of this year's projects..........
rckymtnhi is offline   Reply With Quote
Old 05-04-2014, 08:05 PM   #42
2003 silverado
2003 silverado's Avatar
Added Craigslist special tires/rims
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
Old 05-04-2014, 08:35 PM   #43
asolde
asolde's Avatar
Swaped my cluster for a new bezel, replaced the oil pressure guage (good fix) to no pressure at all. Replaced my dash pad and discovered I need all new ac hose's, another controler, and I gotta do a heater core.
Old 05-06-2014, 11:52 AM   #44
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm under the dash doing nearly the same. If you have any tips for digging out the heater core let me know. I'm still working through an issue with my fuel gauge and then on to the heater core. I got a made in Mexico bronze/brass core from Rockauto as I couldn't locate a new US example - will add some remaining tower clamps and a new heater control valve at the same time.
Old 05-06-2014, 01:12 PM   #45
asolde
asolde's Avatar
Pete one thing for sure you have to drop the inner wheel well down to gain access to the lower bolts on the heater core housing. While you have all of that apart on the inside of the heater core housing replace all the seals on the box.
Old 05-06-2014, 05:15 PM   #46
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Great idea thanks. My heater doesn't blow hot air - must be something a miss in the duct work. The heater valve does shunt hot coolant to the core. Need to trouble shoot that after my cluster issue is resolved.
Old 05-13-2014, 08:11 PM   #47
asolde
asolde's Avatar
Did my heater core today, 6 hour job. Were the stock heater cores made by Harrison just wondering?
Old 05-13-2014, 09:22 PM   #48
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sounds painful - I may do that over Memorial Day weekend. I believe Harrison did make the stock cores. How did your replacement core fit?
Old 05-14-2014, 05:41 AM   #49
asolde
asolde's Avatar
The replacement core fit fine (Ready-Aire, Vista-Pro). I believe it is the same one you got from Rock Auto.
Old 05-17-2014, 08:19 PM   #50
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Replaced the tach/clock cluster with a tach/vac cluster all OEM gauges rebuilt by member Livrat. My rebuilt tilt painted dark saddle arrives Tuesday...
