1964 C10 Hercules Diesel
Hello fellow diesel fans. I was not aware this section of the board existed.
Little info on the engine. Its a 3.7L Hercules Diesel. VE pump, Original GM application, SM465. Found while looking for a 4bt. Was originally in a Chevy delivery van. Thinking maybe a repower for a 6.2. Here are a few photos of the build. ![]() Yes, Its painted Cummins Beige, Sue Me! ![]() ![]() Little bit of CM modification. ![]() ![]() ![]() ![]() ![]() ![]() |
Re: 1964 C10 Hercules Diesel
I'm currently running 2.92s out back from an old big block Cadillac. Not real happy with this setup. I would like to find a NV4500 or maybe a 3500.
Kudos. I like setups like this everyone does a Cummins. I like it a lot I went the custom 6.5 route. My build is in this forum as for the trans did you only want a manual? I building a 4l80e full manual no electronics. Awesome job I just love how it came out. Hows the power?
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
i know nothing about that little engine, but it sure looks like a heck of a truck. Well done!
Cool truck and build. Most lowered trucks run gassers. Nice to see a lowered coal roller!
sweet truck bro!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
6>8 Plugless........
![]() Join Date: Sep 2007
Awesome truck and great job doing the swap!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Thanks Dudes! I recently swapped in a NV4500 out of a 92. Upgraded to the hydro clutch (very easy) and love it. Having the extra gear is awesome on the highway. I still lug pretty hard from 2nd to 3rd. Ive got the 3200 governor spring I need to install along with turning up the power screw. We will see if that helps any. If not I will look into replacing the gears in the rear over the winter.
this truck is super cool!
You have a pyro, correct?
What turbo does it have? |
Ignore
![]() Join Date: Mar 2011
What intercooler are you using? Do you have any pic's of it?
I would like to put one on my truck and still have room for an AC condenser and leave the battery where it is.
63 k20 with cummins 4bt, owned sence 1982 |
#13 | |
it measures roughly 24"X11"X3" ![]() ![]() |
I like this. What's the power like? I'm in the process of gathering information for a swap. Right now I'm considering a 4bt, but I haven't put money on anything yet.
