![]() Join Date: Nov 2013
Finally Starting
Re: Finally Starting
Great start!
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Your in the right place here, lots of good people with lots of experience.
Make sure you bag and tag EVERYTHING and take lots of pictures, you will need them for reference when its time to reassemble.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Is that the worst of the rust? Are also going to have to replace the usual floor panels, cab corners, rockers, lower pillars, etc?
The drivers side cab corner is going to have to be replaced, the rockers inner and outer have been done, passenger side corner has been started (PO). Rear cab mounts need changed atleast the outer half of them. I bought a fleet side bed in near perfect condition minus the tail gate and lights.
#7 | |
The only problem I have with that is I want to be able to keep the original vin tag. What can I do about that?
![]() Join Date: Mar 2012
Where do you guys find the time to work on these trucks, with two kids and other honey do's , it seems like i will never get mine finished......
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
I've got 2 kids also, but they are old enough we don't have to mind to them all the time and they both actually enjoy helping on the truck. Now for the surprising part they are both girls. LOL The honey do's kind of stack up once in awhile.
![]() Join Date: Apr 2008
Best thing to do is make it a family project.
#12 | |
Florida Edition
I drilled out the rivets from my vin tag and scrapped the cab.
Florida Edition
You'll need 'rosette' rivets' to reuse that VIN. Very, very hard to come by and possibly illegal in some states.
#15 |
Mine were not "rosette". They are round, they are actually still on the drill bit I used. Cab, front clip and bed all had the same matching color under the bad paint job on top of them. Yes the frame number also matches.
Unless they just rebodied the frame. |
#16 |
Kind of intriguing if they weren't rosette style because they certainly were from the factory on every truck I've seen. Possibly swapped previously?
#17 |
#18 |
Well I've got the shocks, e-brake lines, driveshaft and the manual transmission cross member all off and I think it's ready to go to the blaster. Besides powder coating what is the best paint to coat it with when it gets home?
#19 |
#20 |
I got the front suspension put back together this evening.
#21 | |
![]() Join Date: Sep 2010
I asked about the rosette rivets a few weeks ago and was pounced all over and told by the administrators of this board that it is illegal and is not a topic on this board and will be cancelled every time... Well me being me... I said fine I will just investigate that myself... What I found out is it is illegal in all 50 states to remove a ID plate and replace it without the DMV and Highway patrol in... Then it is questionable... It has to be approved by them PRIOR to anything being done... then re-inspected upon completion... The you run into the issue of taking the truck from one state to another... That is a Whole new set of issues...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
#22 |
I think I have found all the patch panels that I need (found not boughten). Starting with the foundation and going up. I'm hoping to save the money and just have the rust places above the sun visors fixed professionally.
#23 | |
Just my opinion...
#24 |
![]() Join Date: Feb 2001
Best of luck ... looks like you have a great start.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#25 |
I got my tubular motor mounts and cross member installed and set the block and tranny in for a test fit. They fit like a glove. I finally got around to making the new track bar. I don't know how long it's going to take me and my family to finish this but we're having fun doing it. I've been so dead set on putting a 383 in it when I started and the further I go I keep having thoughts of maybe a 427. We'll see.
