04-26-2014, 10:32 AM | #451 |
Re: 72 Dropmember Suburban
04-26-2014, 06:53 PM | #452 |
did u buy it from CFM motorsports??...he's one of my vendors at conroe....good guy....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
04-26-2014, 08:48 PM | #453 | |
Spent the day getting all the seats and console holes drilled so I could get the carpet in. After all that, I realized the carpet I got was for a low hump, not the high hump that I ordered. I called the place I got it from and they are supposed to order carpet again Monday and they said it may be in this weekend. I did get my slosh tubs pedal cover polished and installed. |
05-02-2014, 12:14 PM | #454 |
nice build. how do you like the vhx gauges.
05-02-2014, 01:05 PM | #455 |
05-02-2014, 02:52 PM | #456 |
Just sat down and went through the entire build. You are doing a hell of a job and your Burb is absolutely beautiful.
05-02-2014, 03:01 PM | #457 |
Im slowly knocking down my to do/to get list. Im hoping to drive her this summer. |
05-06-2014, 02:21 PM | #458 |
once again nice build. I was just wondering how and where you mounted the elevel sensors. Also what aluminum dash bezel is that. I thinking of switching my autometer gauges to the vhx. If you can post pics that would be great.
05-06-2014, 03:07 PM | #459 | |
The aluminum dash I got from someone locally but I believe its the same one LMC and the other companies sell. Got some more parts ordered. I should be home for a while in a week or two to get some work done. |
05-12-2014, 04:40 PM | #460 |
05-12-2014, 04:44 PM | #461 |
nice score!
what is that air-evaporator? I thought water evaporated? hahaha...got any info on that? is that an early A/C option based on water evaporation?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
05-12-2014, 04:46 PM | #462 |
05-12-2014, 04:47 PM | #463 |
cool (literaly :-) )
05-12-2014, 04:57 PM | #464 |
I think I can make this kit work http://www.oldairproducts.com/catalo...it-p-4509.html
When I get back, Old Air isn't too far from me, I may take the cover up there and see if they have a demo unit that I can look and see if it will work. |
05-14-2014, 04:53 PM | #465 |
05-14-2014, 05:06 PM | #466 |
05-15-2014, 09:43 AM | #467 |
05-15-2014, 08:30 PM | #468 |
Spent the better part of the day working on getting the brakes put on. I only got one side done. I ordered the spindles for a 72 and apparently I had 63-70 ball joints. I had to pull the lower A arm to swap out the ball joint which meant I had to take the header loose to get the mount A arm bolt out. Im hoping to get the other side done tomorrow.
While the truck is on jack stands, I still have a lot to the under side so before I take it off jack stands, im going to try and finish that all up too. |
05-15-2014, 08:37 PM | #469 |
You're a machine!
JK |
05-17-2014, 04:29 PM | #470 |
05-18-2014, 12:57 AM | #471 |
What color carpet did you use with the parchment seats? It looks good.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
05-18-2014, 10:01 AM | #472 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-18-2014, 10:52 AM | #473 |
low n' slo
man that looks great!
did you buy the full carpet set or just the front and the middle?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
05-18-2014, 11:13 AM | #474 | ||
Might be a cool idea, maybe make it just a little larger to make an aftermarket evaporator fit in it, could add a rear dome light and speakers...hum Know anyone that can do it? Thanks, I bought carpet for just the passenger area and it came in two pieces and I also ordered the matching floor mats. I really like the carpet!!! |
05-18-2014, 02:31 PM | #475 |
Never been much on the plaid.....but you and Losh have made me a fan!.....love it...that oyster color was popular in 70's and early 80's vettes....always liked it...jim
