Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-21-2014, 09:25 AM   #26
LockDoc
The Older Generation
LockDoc's Avatar
Re: NJ Suburban
If the springs have been replaced with lift springs that will happen. My '70 Longhorn 4x4 has the same problem with the 3" lift springs, as you can see in this picture....
LockDoc
Leon
Old 05-21-2014, 12:19 PM   #27
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Thanks guys. The shackles are going up not down so they haven't been flipped. It must have lift springs. Stock height for this truck was pretty high but it is an inch or two higher now. Once I ditch the running boards it will probably look better.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 05-21-2014, 09:10 PM   #28
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Removed the grill, stereo, one running board and lots of odds & ends. The rear wheel doesn't look so out of place now.
Paul
Old 05-21-2014, 09:12 PM   #29
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Is there any way to move the wheel back? Great looking truck. Love the color.
Paul
LockDoc
Old 05-21-2014, 10:50 PM   #30
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
Thanks. I hope to be driving it in the next week or so...
They make axle re-locator plates. The alignment pins are offset in them. I will post pictures of them in the morning.
LockDoc
Leon
Old 05-22-2014, 02:22 PM   #31
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Here are the offset plates. One way off sets them about three quarters of an inch and the other way one and a half inch. I don't know who carries them, I bought these off of member "DieselWrencher".
LockDoc
Leon
Old 05-22-2014, 09:09 PM   #32
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Cool. Thanks Leon, I'll start looking around for a set.
Today I got the Lund visor off, the other running board and more of the interior. The visors were really popular in the 80's and 90's. Does anyone run them any more? This one will go up for sale soon as well as the bumper guard.
Paul
Old 05-22-2014, 10:22 PM   #33
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
No problem Paul...
I think some guys still use the visors. I see pictures of trucks with them on here....
I took the running boards off of my '71 and a friend of mine wanted to buy them for his '69 DD. His wife wouldn't ride in it because it was too high for her to get into.
LockDoc
Leon
Old 05-26-2014, 08:43 PM   #34
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Almost ready for the sawzall! All that is left to remove is the steering column and the seats. Took tons of pictures.
Old 05-28-2014, 08:39 PM   #35
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Ready for some Sawzall therapy!
Paul
Old 05-29-2014, 09:28 PM   #36
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
Looks like you have your work cut out for you
LockDoc
Leon
Old 05-30-2014, 08:22 AM   #37
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Sawzall therapy was successful. Looks like my only problem area on the frame is the rear section. I'll have to cut the section out of the 68 frame and weld it in.
Next step will be to degrease and power wash and after that remove the fuel tank, fuel lines and brake lines.
Paul
Old 05-30-2014, 08:58 AM   #38
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Rear frame section and my home made hitch. That gas tank sure looks out of place, for now!
Paul
Old 05-30-2014, 11:50 AM   #39
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
Wow!!!, you sure made short work out of that!..
LockDoc
Leon
Old 05-30-2014, 12:02 PM   #40
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Lots of aggravation at work Leon. It was really good therapy!
Paul
Old 05-31-2014, 09:24 PM   #41
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
3 cans of Gunk to remove all the built up crud on the engine and transmission. Looks like I need a replacement trans/transfer case cross member. Are they tough to find?
Tomorrow I'm going to pull off and save the exhaust system, start wire brushing and remove the body supports that need replacing.
Paul
Old 06-01-2014, 01:26 PM   #42
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: NJ Suburban
Paul,
If it is the same as the Blazers I am pretty sure I have one here that is in decent shape. it was a turbo350/205 setup that was in it.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is online now   Reply With Quote
Old 06-01-2014, 08:52 PM   #43
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Thanks Richard. Can anyone confirm that it is the same as what I'm running? How do I identify what transmission and transfer case I have?
Paul
Old 06-01-2014, 09:50 PM   #44
bigrigpardo
Re: NJ Suburban
that is a 4 speed sm465 with an np205 transfer case. so its a 465/205 combo were a 350 205 was a turbo 350 auto with a 205 case
bigrigpardo is offline   Reply With Quote
Old 06-02-2014, 08:41 AM   #45
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Thanks for the info. Did they make different 4 speed trannys for the trucks?
With this combo, 1st was always a low or crawler gear and I always started out in 2nd. With my 68 2wd burb, it started in 1st, 2nd was too steep and required me to slip the clutch too much.
Oh, I saved the entire roof of the burb I scrapped if you want some of the sheet metal.
Paul
Old 06-03-2014, 07:51 PM   #46
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Cut the rear frame portion from the 68 today in the pouring rain so I can repair the rear section of the 70.
Any recommendations on welding this on? I was thinking of the following steps:
1) remove the rear shackle mount
2) make wood braces under the existing frame in 3 or 4 locations to orient the frame where the X's are.
3) cut the original frame and replacement frame at the same point.
4) butt weld inside and out
5) use my extra steel to fish plate inside the frame
6) re drill the shackle mount and bolt back into place with grade 8 fasteners.
Any suggestions? Should I post this on the truck section or someplace else?
Paul
Old 06-14-2014, 08:49 PM   #47
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Spent the last week removing all the bolt on hardware from the frame. It is all leveled and ready for frame repair.
Paul
Old 06-14-2014, 10:10 PM   #48
LockDoc
LockDoc's Avatar
Re: NJ Suburban
Paul
That sounds like it will work. I would cut the side rails on a 45º angle instead of straight down though....
LockDoc
Leon
Old 06-16-2014, 08:43 PM   #49
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Right side done except for reinforcing plate and left side almost ready for welding.
Paul
Old 06-22-2014, 01:48 PM   #50
pwdcougar
pwdcougar's Avatar
Re: NJ Suburban
Both sides are done! Now on to removing the engine, transmission and transfer case and get the frame ready for paint. Didn't add a reinforcing plate to the right side and not sure I will. The heavy steel homemade hitch plate that bolts on should act as enough reinforcement. Had trouble welding the left side reinforcing plate on the upper inside. None of my grinders would reach the inner corner of the frame for clean metal to weld. Once the drivetrain is removed maybe I'll try a different wheel on my 7" grinder, tilt the frame up and re weld that part.
