#301 | |
![]() Join Date: Aug 2013
Re: 1963 C-10 SWB BBW Fleetside in NC
#302 |
Is your truck a short bed or long? I found that some minor work is required to fit the auxiliary springs on the short bed. Just a little trimming on the end of the outer bumper brackets where the mount to the frame. Think it was around 3/8" I had to trim off...but other than that they are bolt and play.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#303 |
Found a NOS 63 farm truck plate still in the matching original envelope today for the fleetside. These plates are very tough to find and especially in NOS. Will be a nice addition to the fleetside.
#304 |
Score on the plates, very nice
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
#305 |
Going with stainless bolts?
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#306 |
Yeah probably.
#307 |
![]() Join Date: Mar 2013
Nice score on the plates!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#308 |
Thanks man....the farm truck plates are hard to find here in NC....especially NOS
#309 |
Those plates are
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#310 |
Thanks, here some better detailed pics. Was never issued and has the matching nc dmv paper envelope. Nc lets us run year of make plates at no cost. Just have to be able to produce registered plate if asked. I keep the registered plate in the glovebox with a copy of the nc statute. Have had to show it 2x in 5 years.
#311 |
All interior cab prep done on the stepside and it got dark, so figured id build a vacuum gauge for the fleetside gauge cluster. Used an older pontiac vac gauge and a 60-63 delete plate
Took 20 minutes total and had the parts on hand so no extra cost ..minus decal. I will have to order a new vacuum gauge decal. Took the needle of using two spoons apply pressure under the base of the needle on the sides. They always pop of great this way. Removed the cover of the gauge by the two tiny bolts. Took the back side of the rivet off using a small phillips head screwdriver. The back of the rivet is soft. .maybe 7-8 turns and it'll let the delete face free. Used the old gauge as the template and drilled a 3/16" hole for the needle. Bolt the new face on & thos is where the decal will apply....but you guys get the idea. I see these vac gauges go for $20 all the time if I had to purchase one on ebay. With a delete plate, gauge & decal and maybe 20-25 minutes...it'll make a nice addition to the truck and save $200. The gauge itself is identical to my original gauge in my stepside. The delete is the same size plate..so once redecaled it'll look oem
#312 |
Some more pics
#313 |
Last few
#314 |
Ill have to fix the pics tomorrow...my phones flipping pics. Will set the needle once the decals in. Put it in the cluster for now.
#315 |
Gauge cluster looks good!
#316 |
Thanks bud. Cant get to far into this build until the stepsides done, but cant help do some smaller projects
#317 |
![]() Join Date: Apr 2013
looking good brother...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#318 |
Thanks for the kind words and for checking the build out.
#319 |
those vac gauges are going up in price, glad i snag'd mine i may just leave it and not change the face...
#320 |
Thats a nice gauge...I dont blame you.
#321 |
How will that mount to the cluster housing? I imagine the back of the housing plate will have to be modified?
#322 |
#323 |
found a sun tach for 12V 6cyl also. ima leave em with their faces kinda like the non original look. fricking repop vac and tachs are $200 apiece !!! but u already know that. paid less the $200 for both...
#324 |
my latest project took me bout 30 mins to get it str. it was broke and twisted, but i got it
#325 |
added to my to do pile
