09-06-2014, 03:36 AM | #1 |
Ac bracket
To do a swap on my 85c10 will I need a different ac mount than the stock 2003 suburban one?
09-06-2014, 12:27 PM | #2 |
Re: Ac bracket
Depends on which motor mounts are used. I used the hedman ls swap kit and leaves the compressor in the stock location. It's pricier than some other kits, but by the time you add a relocation kit, it's kinda of a wash.
09-06-2014, 02:35 PM | #3 |
Re: Ac bracket
09-06-2014, 02:36 PM | #4 |
Re: Ac bracket
Didn't even know they made mounts. So with the hedmans everything fits, no issues?
09-06-2014, 02:44 PM | #5 |
Re: Ac bracket
Just looked into the hedmans setup and there for a 4l60. I'm going to be running a th400.
09-06-2014, 03:40 PM | #6 |
Re: Ac bracket
You can relocate the A/C compressor with the Holley LS Truck A/C relocation kit, they are inexpensive and will save you serious headaches.
You can go here https://www.holley.com/products/ls_p...essory_drives/ or you can call them up and tell them what you are doing and they will make a list of parts you will need and what it will cost. Last edited by Xeen; 09-06-2014 at 04:03 PM. |
09-07-2014, 01:56 PM | #7 |
Re: Ac bracket
I believe they have a trans mount for
The 4l80e, which I assume is the same as the 400. The only fittment issue, was I had to clearance the driver frame for one of the header tubes, & I mean barely grind it. |
09-07-2014, 05:16 PM | #8 |
Old member
Re: Ac bracket
Google is your friend. There are several brackets that will relocate it for you. Just depends on how much you want to spend. Mine is a LS bracket.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-07-2014, 07:24 PM | #9 |
Re: Ac bracket
Kwik performance make a LSx ac relocation set up for $200.00. I think you gotta buy sanden compressor. Total cost involved is $400.00. Good luck.
09-07-2014, 10:58 PM | #10 |
Re: Ac bracket
Dirty Dingo A/C and motor mounts "Cheap~Fast~Easy" pick two!!
09-08-2014, 04:24 PM | #11 |
Re: Ac bracket
Looks like dirty dingo will be my pick. Already going to be using there engine mounts
09-08-2014, 04:44 PM | #12 |
Re: Ac bracket
Looks like you already made your choice but here's another option that might save you a bunch of money: http://www.maliburacing.com/forum/vi...p?f=34&t=79059
Basically, the guy used an A/C bracket off of a TBI 4.3 V-6 (the same is also on the TBI 350), trimmed off the lower section, and made a couple of support brackets to keep it from moving. Looks as good as factory and allows you to keep your existing A/C compressor in the stock location. It should also save you the money from having to re-work your lines and then recharging the system after splicing everything together (if you have to right compressor to start). I'm lucky and have a TBI 350 in my '89 K5 so I already have the right bracket and compressor to go this route instead of paying $$$ for the bracket kit, compressor, and recharge. |
09-10-2014, 10:19 AM | #13 |
Re: Ac bracket
If you go DD you will need to replace their supplied tensioner with a Gates-38164 which cost another $45...I just had to do this.
09-11-2014, 05:02 PM | #14 |
Re: Ac bracket
I have several thousand miles on my set up as seen on the floor, which is all D D, why did you have to change your tensioner?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 09-11-2014 at 05:18 PM. Reason: add pic |
09-11-2014, 07:16 PM | #15 |
Re: Ac bracket
We have different brackets. My belt kept jumping and the bracket vibrated badly. But DD was cool and replaced the money I spent on the spring tensioner. I have no problem with DD!
09-11-2014, 08:42 PM | #16 |
Re: Ac bracket
so the dd will come with tensioner? all I will need is belt and compressor?
09-11-2014, 08:53 PM | #17 |
Re: Ac bracket
09-11-2014, 10:04 PM | #18 |
Re: Ac bracket
Any recommendations on where to get compressor?
09-11-2014, 10:17 PM | #19 |
Re: Ac bracket
Mine is a vintage air, bought from summit
09-12-2014, 07:57 AM | #20 |
Re: Ac bracket
I bought the Sanden from a local A/C shop in Tucson, Century Auto A/C
