09-14-2014, 12:02 AM | #1126 |
Re: What did you do to your truck today? Chapter II
Whelp.... i tore apart my heater core box. Cleaned a big ol mouses nest from ALL the pockets and crevices. ( a five gallon wet or dry vac full) bleached the heck out of it. ( the last thing i need is hantavirus) recoditioned the motor and replaced the squirrel cage. Cleaned the core, lightly sanded and applied 4 coats of rattlecan clear on the box, resealed and reinstalled. It came out good
Dangit. It posted sideways again
1967custom |
09-14-2014, 09:43 PM | #1127 |
Got my new wiring harness finished up, installed carpet after laying sound deadener, new heater core installed, new dash pad, new Dakota Digital VHX system installed, getting ready to install all cab rubber, get all the glass back in and be ready for Crusin' the Coast in about 3 weeks! Tried to post photos, but got some weird error message about a security token....whatever that means.
Steve McMillen ASE and GM certified Master Technician 25 years+ experience No, I do not know it all, that's why I attend tons of training. |
09-14-2014, 10:30 PM | #1128 |
Installed rear sway bar from CPP. Can wait to see...feel how it handles.
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
09-15-2014, 01:48 AM | #1129 |
09-15-2014, 07:00 AM | #1130 |
Nice cuts... that will give you some good strength...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
09-16-2014, 01:28 AM | #1131 |
I painted the inside of my tailgate with Rustoleum spray on bedliner just to see how it does & to get an idea how the rest of the inside of the bed walls & the wheel wheels are going to look once I finish sanding & prepping it. I was able to get two coats laid down before dark thirty and it turned out better than I expected. I know it's not Herculiner, Line-X or Rhino Liner but it will work fine and it's a heck of a lot cheaper too. I want to get the inside walls painted before putting down the new wood & rails.
"Now all I need is a shop to go with my shop vac!" |
09-16-2014, 07:03 AM | #1132 | |
1970 C10 Short Stepper with 71/72 front clip. |
09-16-2014, 08:54 AM | #1133 |
I got mine at Lowe's http://www.lowes.com/pd_303289-90-24...ductId=3728969 I have seen it at Home Depot, Wal-Mart, Autozone & Tractor Supply too. And you can get it at Amazon.com as well. The "spray on" bed liner that Rust-OleumŽ sells is actually called "truck bed coating". Rust-OleumŽ does sell a "bed liner kit", it's a two component epoxy/rubber based roll on product & not a spray. I'm not sure how good it is, the spay-on was just more convenient for me.
09-17-2014, 04:14 PM | #1134 |
Installed a set of show panels, a matching radiator cover and Fesler Built hood stops. Also added silver powdercoated hood latch and radiator brackets (upper)
Before: During: After:
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-17-2014, 08:29 PM | #1135 |
Super looking engine bay you got there.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
09-17-2014, 11:40 PM | #1136 |
Yeah whered you get those filler covers in all you pics? Watch those wrenches on your battery!
1967custom |
09-18-2014, 03:12 AM | #1137 |
Very nice.....
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
09-18-2014, 07:19 AM | #1138 |
That looks great...
09-19-2014, 11:02 AM | #1139 |
Finished this up to go with post #1053.
Helping a local clean up his 68 50th.
1967 C10 SWB Owner - Rustbelt Restorations |
09-19-2014, 01:53 PM | #1140 |
New member here,
Not really what I did today but over the last couple days. 2 days ago Started working on my 69 GMC Custom 1500, pulled out the seat and all of the floormats and padding(which is completely shot). Also started to assess the rust floor damage. Last night I pulled the fuel tank sending unit and pickup tube. the float is completely missing, but I did ohm out the sending unit and it does look like it's working. My only other issue is the prefilter on the end of the pickup tube is pretty rotted and split. was also full of good ol black gunk. along with probably 1/4" of sludge in the tank. weekend project is to pull the tank drain it and get ready to run a KBS coatings tank sealer kit through it. I'm pretty new to a lot of this but have been told that I'm pretty mechanically inclined so I've been reading a lot. |
09-19-2014, 02:45 PM | #1141 |
09-19-2014, 05:27 PM | #1142 |
I set/adjusted the lash on my solid roller cam lifters and changed the plugs out.
09-20-2014, 09:57 PM | #1143 |
Shot Hipoliner.
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
09-22-2014, 01:21 PM | #1144 |
Looks great!
09-22-2014, 02:11 PM | #1145 |
RAT1968 '68 Cab/'71 Parts
Used the bed to go get a bed.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
09-22-2014, 02:58 PM | #1146 |
Today, I messed with the glove box door.
Silly. But I like it. It stays.
09-22-2014, 04:29 PM | #1147 |
Rebuilt air vents before installing Vintage Air system.
09-22-2014, 05:18 PM | #1148 |
Got the engine, transmission, and headers installed this weekend.
Didn't even have problems with the AC Compressor Clearing.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
09-22-2014, 05:45 PM | #1149 |
Spent yesterday pulling the water pump twice to try to fix a coolant leak, then ran some sealer through it just to make sure. Today put new shocks on all four corners and installed new wipers. Maybe next weekend I'll try working on my 67 instead of my Tahoe.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
09-22-2014, 07:36 PM | #1150 | |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
