#26 |
Re: My 68 5.3/4l60E swap
#27 |
What brand Trailblazer headers are these? I was looking at the Kooks.
#28 |
Mine are Pacesetters. I would not spend the money for the Kooks headers. If you were going to spend that much you might as well buy the conversion headers. The reason for buying the pacesetters is that they are about 200 dollars cheaper then the swap headers.
#29 |
The only reason I didn't consider the pacesetter was because I seen a thread where the guy had to clearance the drivers side of the frame down near the collector. It also appeared that the drivers side header angles towards the frame. Did you have these issues?
#30 |
Bad ass man! Sounds great!
#31 | |
Thanks man. It's been fun building it. |
#32 |
#33 |
Hello Amr84ss, how did you set your fuel system by using that edelbrock intake? A breakdown would be nice. Can you use the stock injectors? Didn't he intake come with fuel rails. Inquiring minds want to know. Thanks in advance for the information. It looks nice.
#34 | |
On the new set up, the rails are sold separately. The rails use either ev1 or ev6 injectors. I don't think the stock truck injectors will fit. I think they are to tall. My truck is in the shop getting the trans rebuilt, I can get more pictures if needed. ![]() |
#35 |
Truck sounds great...Good Job
#36 |
If possible, I would like to see more pics of the edelbrock set up.
#37 |
#38 |
Thanks Amr84ss, I might look into using the edelbrock intake.
#39 |
#40 |
