08-29-2014, 09:51 PM | #101 |
Re: Parting out a 72 blazer
Im interested in the gas tank straps seeing 69-72 passed on them, got any pic,s??
thanks Donnie
Things happen for a reason! |
08-30-2014, 06:37 PM | #102 |
Here you go 30 plus shipping lmk
08-31-2014, 10:42 PM | #103 |
Active Member
Would like the windshield frame if not rusty . Cut out 6 Inches below the glass. Don't need the glass. Let me know the details Thanks Pat.***
08-31-2014, 10:58 PM | #104 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=632354 |
09-01-2014, 08:47 AM | #105 |
Are they pitted or have any holes on the straps from rust, would have to bead blast them before painting,,,would you do a close up pic?
Could you do $30.00 shipped,,, 29720 South Carolina
09-01-2014, 05:18 PM | #106 |
I was going to take them to work with me tonight and blast them to see how they turned out but they both have small rips in them. Sorry, may have another set but will take a couple of days to locate them.
10-03-2014, 10:58 PM | #107 |
Not sure if you are still parting it out...
I'm looking for the passenger seat mount on the floor for the factory seats, also looking for a driver side retractable belt, I prefer saddle but I could make do with any color. Thanks
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
10-04-2014, 12:08 PM | #108 |
Sorry no seat belts but do you need the actual seat brackets off the seat or the nut plates in the floor board
10-04-2014, 10:20 PM | #109 |
Do you still have the tach dash cluster?
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
10-04-2014, 10:25 PM | #110 |
Yes but sorry not for sale listed in the very first post
10-04-2014, 10:36 PM | #111 |
I missed that, thanks anyways.
10-27-2014, 10:24 AM | #112 |
Interested in the brace that goes under the cab that the front of the bucket seats bolt to. Thanks
10-27-2014, 11:00 AM | #113 |
72 floor is gone but I am parting a 71 right now that should have that would you be interested in that one? If so send me your zip and I will get you a quote shipped.
10-27-2014, 01:17 PM | #114 |
Yes I'm interested. My zip code is 71270. I'm also looking for the seat bracket for the passenger side to fit a pickup if you have any. thanks
10-27-2014, 02:36 PM | #115 |
I have been told the blazer floor bracket for the seats are different then the trucks if that matters. There is a forum member that sells reproduce seat brackets for the trucks if that is what you need. Just trying to make sure you get what you are looking for.
10-27-2014, 04:16 PM | #116 |
Do you have a good set of the rear frame rails? I need about 2 feet of each frame rail.
1972 3/4 ton 402/400 1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift |
10-27-2014, 08:19 PM | #117 |
10-27-2014, 09:12 PM | #118 |
Sent a PM. thanks
10-27-2014, 09:21 PM | #119 |
Responded to your pm
10-28-2014, 07:55 PM | #120 |
Hard to tell what is what but my phone takes crappy pictures and it is setting on the ground with a flat tire. If you need better I can try again also took pictures of the nut plates on the outside. The channel only captures the inside seat mounts there are nut plates on the outside for both seats. So for both nut plates and center channel 40 plus 15 shipping makes it 55 shipped. Let me know if still interested.
10-28-2014, 07:57 PM | #121 |
more pics!! I don't know how you will be able to tell what they are I took them and still don't know. LOL let me know if you need better
10-28-2014, 07:59 PM | #122 |
Junior Member
i'm looking for the door side and the body side plate door wedges one is stainless steel and one is brass thanks mark
10-28-2014, 08:01 PM | #123 |
Hello Mark I have what you need will get you a picture tomorrow 25 shipped will be 1 ss plate 1 brass plate and will have to check but should be 1 shim plate also.
10-29-2014, 10:05 AM | #124 |
These are the pictures for Doug. He only needs the long brace, not the others.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
12-11-2014, 08:38 AM | #125 |
ttt
