Closed Thread
Old 10-30-2014, 07:38 PM   #76
Re: What did you do to your truck today part III
Welcome aboard disastorbus. The truck looks good!
Palf70Step is offline
Old 10-30-2014, 10:16 PM   #77
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
All Sanded Rocker Installed Whole Truck Epoxed Primed, lil Scuff Next Week and A Gallon K200 And Blocling Next Month Then More Primer!!!!
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline
Old 10-30-2014, 10:17 PM   #78
1971 GMC SHORTY
Left Side
2002 FXDP
Old 11-02-2014, 04:55 PM   #79
Grizz1963
Grizz1963's Avatar
I have decided to do a dual update, running over two days this weekend.
Started by going over to mate Martins place at 07.00 on Saturday with another mate, Ian in tow to help him with the final stripdown of his chassis and then to get it into the garage and then to move other bits about, including the cab into the carport so that he can start the welding marathon he has ahead of him.
I will let the pics do most of the taking.......
Needless to say, there is a lot of rust and we managed to strip off a few bolt heads. Fortunately Martin has purchased many new parts for his build.
This is the lever bar we used on quite a lot of the bolts n nuts.
Because I was there to take photos of the progress, I ended up working for a change.
it was not a sunny day......
Pooping my pants or farting ?
Unfortunately we did not have any smaller tools.
U Bolts cut as there are new parts in store.
Getting the rear spring off nearly gave Martin a hernia.
Between fetching cups of tea and biccies, we did allow Ian to pack the tools away.
DONE !!!!!
Next up we moved the cab in under the carport and then all pilled into cars and went back to my place.
So back at my place I pulled the truck out and got all the bits ready.
But not before I had pre-cooked 20 Peri Peri chicken wings and got some sausage ready for Ian to do us a BBQ later.
He was also on kettle duties.....
Just starting to take the front wheel off.
Old vs New shocks. New shocks were ordered at -2"
Martin and I getting our heads together.
And then it got spicy...... Martin was all over me like a cheap suit.
There was a lot of huffing and puffing to get old nuts and bolts loosened.
Thank goodness these trucks are built in Man Size.
In the mean time Ian kept us tanked up with tea and coffee as well as passing, collecting spanners and taking some photos.
At some point, after much bashing, we got the spring removed.
It seems the original spring was cut down by 2 inches and refitted, and over time it, along with the shock absorber had become very saggy.
Once done with the drivers side we reassembled and put it back on the floor.........
Using my special measuring stick expectantly, to see where the 2 inch lower than standard shocks n spring had taken us, I was shattered to find the front stood 2.5" higher than before. AAAAARRRRGGGHH !!!
At this point it was getting to be dark, and Ian had cooked us all the spicy wings, which we ate directly off the fire/grid along with the sausage in hotdog rolls so we pushed the truck back into the garage till this morning, when Martin was back at my place by 07.45 (It is truly great to work with someone who gets up at a sensible time) My appologies to Martin's Amanda and my Nicola for having tosit around while we got down and dirty.
After Martin left I posted up threads on the Chevy C10 board and Garage Journal and Rods n Sods looking for advice. Much was offered.
So when we pulled the truck out this morning and jacked it up, I crawled underneath to inspect yesterdays fittings.
YUP..... The spring had not been located so after some grunting and adjusting, we dropped it down again and found the new height was 10mm taller than the old parts. PERFECT !!!
On to the passenger side, which took a lot less time to do.
By 11.00 Martin had left to go shopping, and I shut shop to get out and spend some time with Nicola who was waiting patiently for us to finish.
Next job will be getting the rear suspension sorted, possibly also replacing the lowering blocks.
A couple of other observations on this job included non matching nuts and bolts keeping the suspension together, some very worn fittings and also front brake lines that need replacing sooner than later.
Shock absorber top mount bolt.
And lastly, the parts that came out.
Original springs cut down by a coil, giving 2" lowering.
That's all folks.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 11-02-2014, 07:57 PM   #80
bigdaddy64
bigdaddy64's Avatar
Patching the lower fender and added a rolled lip for my exhaust cutouts.
66 c20 with 1/2 ton 73-87 front and rear suspension
2-1/2" drop spindles, air-bags, c-notch rear frame
463 Pontiac, SRP Pistons, Eagle Crank and Rods
Mega-Squirt Fuel Injection
bigdaddy64 is offline
Old 11-02-2014, 09:45 PM   #81
DakotaKid
This weekend, i got my Front Fram horns patched up, got the Frame from the firewall forward painted, got my 74 Crossmember installed, and rebuilt the front suspension.
Hope by the end of the week to have it back sitting on the ground with my Power steering adapter and Dropped coils and spindles installed.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline
Old 11-03-2014, 11:36 AM   #82
scuderia
scuderia's Avatar
Got the tail lights installed and working (for now, the sockets are pretty shot) and took it for a short drive. Nice to finally get her out in to the sunlight
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline
Old 11-03-2014, 01:16 PM   #83
DLW
After dealing with a mess load of rivets, drilling holes and cutting the notches, I started installing my PB stage 2 Deluxe kit. Got the stock trailing arm cross member off with the cab on and really wasn't that bad to remove thanks to a snap-on air chisel and long drill bit. Hit everything with some primer and satin black, rattle can style. My air bag fittings I had mysteriously disappeared so I didn't get the trailing arms and shocks installed yet.
DLW is offline
Old 11-03-2014, 07:48 PM   #84
schpeen
schpeen's Avatar
Out with the old...
schpeen is offline
Old 11-03-2014, 08:44 PM   #85
pimpston65
pimpston65's Avatar
finally took delivery of my 66 K10 burban, build thread will be coming!!!
pimpston65 is offline
Old 11-03-2014, 08:50 PM   #86
pimpston65
pimpston65's Avatar
smokes and pops, drives great!!! no brakes, but going to storage tomorrow til i have time to start the full rotisserie restoration. im going full on original down to the last bolt... see ya soon
Old 11-03-2014, 08:58 PM   #87
pimpston65
pimpston65's Avatar
guess what plate i'll be rocking up front?
Old 11-03-2014, 11:14 PM   #88
cooperhw
cooperhw's Avatar
Went out and took pics. Then came in and loaded them into the computer. Logged on here and posted a few of them in my new build thread in the project section.
cooperhw is offline
Old 11-03-2014, 11:31 PM   #89
sodly
sodly's Avatar
Congrats, Pimpston. It's been a long time coming.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline
Old 11-04-2014, 12:41 AM   #90
1971 GMC SHORTY
Diggin Those Black Ca Plates
2002 FXDP
Old 11-04-2014, 11:51 PM   #91
markeb01
Senior Enthusiast
markeb01's Avatar
I was bored today so I went out and did a walk around video of the most recent updates to the truck. I think my cell phone camera lens must be dirty because it doesn’t look very clear to me. I suppose it could also be because of the grey overcast sky as well.
https://www.youtube.com/watch?v=H0_g...ature=youtu.be
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 11-05-2014, 04:14 AM   #92
Jonnyspringfield
I picked up a new to me 1964 dually on Friday. It's a single owner welding rig that I'll be converting over to a custom flatbed for my furniture business. The list of projects is quickly growing. I'm a goner with the c/k bug.
Today's tinkering consisted of stripping down some of the extra "beef" on the rear of the truck. Not even half way through removal and I've already stripped 600lbs 😳
Jonnyspringfield is offline
Old 11-05-2014, 03:28 PM   #93
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum!
markeb01 is offline
Old 11-05-2014, 03:57 PM   #94
Jonnyspringfield
Thanks! I've already picked up a ton of direction through these threads. You all are definitely appreciated
Old 11-05-2014, 04:14 PM   #95
disasterbus
I’ve always loved old skool style pin-striping, but never previously had a car that had the right look to carry it off well.
I thought as soon as I got it that this truck would benefit from something to add to the overall look and that a bit of pin striping could be just the thing.
I’ve seen work done by Simon, a.k.a. Nefarious Pinstriping (www.pinstriping.co.uk) on a few cars and have always been impressed with the look of the work. Had Simon round this morning and he did this for me. Really pleased with the result.
And the finished article ............
disasterbus is offline
Old 11-05-2014, 08:33 PM   #96
gimmy 64
WOW!!!!!!!!!!! that is really nice
gimmy 64 is offline
Old 11-05-2014, 10:28 PM   #97
Jeff La
yep, great job.
Jeff La is offline
Old 11-06-2014, 06:54 PM   #98
ls60apache
well not today but Tuesday I had sprayed on my insulation in the roof area layed down some dynamat on the inner roof,and wow what a difference took that in a barrel sound totally away. and then glued my roof skin back on.i hated that I didn't record this in photos.
ls60apache is offline
Old 11-06-2014, 07:29 PM   #99
1962BlackBetty
lowered rear end[IMG][/IMG][IMG][/IMG]
1962BlackBetty is offline
Old 11-06-2014, 10:54 PM   #100
CRGRS 66
CRGRS 66's Avatar
1962blackbeauty, is a beauty, welcome to the forum, show and tell us more about your long stepper!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Closed Thread
