12-05-2014, 07:23 PM | #76 |
Re: What did you do with your truck today, take 2
got my new steering wheel. Hope to find time soon to install it!
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
12-05-2014, 08:35 PM | #77 |
Nice
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
12-06-2014, 04:17 PM | #78 |
Bored today changed out my tires and installed new rally caps
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
12-06-2014, 05:10 PM | #79 |
I made some trim panels for the kick panels on my 51.
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
12-06-2014, 05:27 PM | #80 |
very cool!
12-07-2014, 02:39 AM | #81 |
Finally got my 50 GMC 450 running with TBI. Well, kinda. Starts and runs for short time. Troubleshot till dark. Had to quit till tomorrow.
IMG_2477.JPG.jpeg Last edited by eagleuh1; 12-07-2014 at 02:45 AM. Reason: Add pic |
12-07-2014, 03:46 PM | #82 |
Wiring shorting out? Hope that is just for "get it running purposes". Start a thread on why it won't keep running (symptoms) and we might be able to help.
12-07-2014, 04:56 PM | #83 |
Wired up my Lokar shifter so it won't start in gear!
yoshi's 49 project |
12-07-2014, 07:22 PM | #84 |
replaced a leaking fuel line
12-07-2014, 09:45 PM | #85 |
Orrie G, yes, just the get it started harness. Will cut and trim, wrap when I have it running. Just separated out the unused wiring.
12-09-2014, 06:46 PM | #86 |
new steering wheel
12-14-2014, 10:59 AM | #87 |
Wired and installed gauges.
1958 Apache short bed |
12-14-2014, 02:23 PM | #88 |
clear and cold in seattle - 39 deg. Got the truck out and went for a drive. Found the heater still works good.
12-14-2014, 02:37 PM | #89 |
Welded a vent connection on to the gas fill pipe. Reviewed the to buy list.
12-14-2014, 03:22 PM | #90 |
Worked on top portion of seat finished, still need the bottom seat frame to go to the blaster and maybe powder coat.
12-14-2014, 03:58 PM | #91 |
My skinnie rear wheels and tires came in. Should get my axle back from Sid's this week and be ready to start working on her again.
12-14-2014, 04:00 PM | #92 |
Pic 2
12-14-2014, 04:01 PM | #93 |
Pic 3
12-14-2014, 08:24 PM | #94 |
Found some time today to work on making a 4" bigger than stock C notch for my 51 C4 build. Hockey with the boys and hunting is taking up a good chunk of time.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
12-15-2014, 09:57 PM | #95 |
Just starting on my build.
Since I don't have patch panels for the cab yet, I decided to work on the rear bed panel. Lots of hammering to make it somewhat straight and welded some tears in the metal. 1 corner of 1 side was completely gone so I trimmed it and made a patch panel. When assembling the bed, are there supposed to be spacers to keep from crushing this area? |
12-16-2014, 08:29 PM | #96 |
Seat is done be kind I don't do this for a living!
12-16-2014, 08:30 PM | #97 |
Actually that looks pretty good.
12-16-2014, 11:59 PM | #98 |
Maybe you oughta! Looks pretty good to me.
Hi Rudy, I notice your location now says Glendale, AZ. You're out there permanently now? I know you said you were moving but are you permanently gone from the desert here? The seat looks great. Did I miss it? Whose cover is that or did you sew it yourself? And the embroidery, if you bought this who offers that? I was gonna comment on your mentioning powder coating the bottom frame. Why the expense? It's not like it'll ever be touched much. I'd paint it myself, maybe even rattle can it. No one but you will EVER see it. I know, heresy to some but on my budget I'll save the powdercoating for something that'll be seen and need the scratch protection. Merry Christmas, Rudy!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
12-17-2014, 12:35 AM | #99 |
12-17-2014, 03:50 PM | #100 |
Replaced the old waterneck and upper radiator hose with new parts from Rock Auto The new thermo housing is a aluminum part that looks good on the aluminum Holly manifold. The hose is a Gates smooth molded hose for a '69 Firebird. I had to shorten it quite a bit but it worked out fine.
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder" |
