#301 |
Re: 8 lug wheels - what's on YOUR truck?
16x8 Dick Cepeks and 265 75 16
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#302 |
Wow! I don't usually like the stock look, but this might just be killin' it as far as what everyone could want in a smart, clean semi-stock look. Way to go..you nailed it!
benner Blacked out 1970 CST, C 20. Hardcore Work Truck with 350, Edelbrock 750, RPM High Rise, Flow-Masters, Black wheels and a Log Wood Rack. One Hot Worktruck. ![]() |
#303 | |
#304 |
![]() Join Date: Nov 2014
i figured with a fair share of the 8-luggers out there running 16.5's, this'd be a good place to ask...
Any of you guys lowered on 16.5's? If so, post em up and let us know your tire size. Also, what's the smallest 16.5 tire you guys have ever run? Any pics? |
#305 |
Do your wheels stick out of your wheel openings? I am interested in buying two of these for the rear of my truck but i dont want anything sticking out past my wheel openings.
1969 CST/20 396/TH400 Tach Posi |
#306 |
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#307 |
That sucks. I want to get some for my lowered c20 but i cant have the wheel stick out. They gotta be tucked in. I guess the 16×8s would do the trick
#308 | |
sboris -> How much clearance do you have between the tire and the inside of the wheel well? |
#309 |
Plenty I think, would have to measure for exactness. The offset would definitely be worth checking out. I'll try to slip out tomorrow nite and put a tape on it.
#310 |
Tjat would be sweet. I would be sweet. I would like to make these my next wheel choice lol. Do you know it you are able to put a beauty ring on them?
#311 |
I don't know how well this will translate to your C-20, and with my lift, I had to run a straight edge down. Sidewall is 1 1/8" and the edge of the rim is another 1 1/4. Again, don't know if this will help. Mine is eaton rear out of a 70.
#312 |
Factory 17.5's with 8r radials.
#313 |
thought this would be a good place to ask.. will the 8 lug aluminum wheels off of a 2007 chevy fit my 1972 c20? I read some years will fit but not sure about 2007.
#314 |
#315 |
#316 | |
1971 Cheyenne Big Block Longhorn Last edited by Jonlopes; 05-27-2015 at 11:30 PM. |
#317 |
I found a place online that has a set of 4 used but restored slot wheels in 8 lug and 16x8 (instead of 16.5) I would have picked them up but they want $2600 plus shipping.
It seems that the American Racing Ansen Sprint wheels in 8 lug are not selling well. Most places that have them listed are out of stock or list that 2 are in stock. And those places either are using the 5 lug photo or no photo at all. They seem to be going for about $200 each which seems reasonable. I probably would buy them today if I could just see them mounted on something. I wonder if they will be discontinued?
1971 Cheyenne Big Block Longhorn |
#318 | |
![]() Join Date: Feb 2008
May sell them. |
#319 |
Maybe we can bundle them with the Longhorn bed sides!
#320 |
#321 |
#322 | |
#323 |
What are the size and backspace of your wheels and what size are your tires?
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
#324 |
Curious, do you have center caps too? do they show a brand? do they slide in from the back? having problems locating a set for my wheels.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#325 |
ARE shows these in 17x8 and 17x9 "blank" (undrilled) stock. If ARE wont drill them to 8x6.5, many wheel places and machine shops have the proper indexing jig to do it properly and accurately, although it will add cost to the package.
