Old 01-25-2004, 07:52 PM   #1
'70_402
'70_402's Avatar
What should i do?
Hey, I am a new member and just would like to say I learn something every time I log on! thanks! but I have a question, I just bought a 1970 Chevy with factory air and buckets and console, and a 402! it runs great but it idles to smooth for my taste I want a little "lope" in it!! has anyone put a cam into a 402 and just really loved the way it performed? and should I go with solid or roller? (sorry if this one has been covered before on a previous post)
'70_402 is offline   Reply With Quote
Old 01-25-2004, 07:57 PM   #2
'70_402
'70_402's Avatar
here is a pic of the engine compartment.. if you guys have any sugestions just tell me!! i like other guys input!!!
Old 01-25-2004, 07:59 PM   #3
zenish
i would put a hydrallic lifter cam in it if you can afford the extra gas.solid lifters have to be readjusted often.roller cams are expensive and MAY require machining of the block.
zenish is offline   Reply With Quote
Old 01-25-2004, 08:11 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
A hydrualic flat tappet cam would be great. Low manintence, and requires no block machining or anythign. A roller cam and lifters for a small block can easily run over $500 alone, not to mention the block machining that may be required. You should be able to get a nice hydrualic cam and lifters for a little over $100
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-25-2004, 08:12 PM   #5
cdowns
cdowns's Avatar
depends on how many miles are on the engine if it's a high milage unit i'd say leave it alone putting a more aggressive cam in is just going to hasten it's demise
Old 01-25-2004, 08:15 PM   #6
1972C10
1972C10's Avatar
Lunati
Comp
Crane
Puttin in a cam just to lope isnt the wisest idea im not a big block expert so i cant say wheter these cams will require a spring change but its always a good idea to upgrade the springs when changing to a perfomance cam
All these cams i posted a kinda mild and shouldnt require a stall convertor
1972C10 is offline   Reply With Quote
Old 01-25-2004, 08:19 PM   #7
1972C10
1972C10's Avatar
Yeah I agree with cdowns Its not wise to do modifcations to high mileage engines Just seems like it dont last long afterwards.
Old 01-25-2004, 08:20 PM   #8
'70_402
'70_402's Avatar
the motor has about 2000 miles on a rebuild so it is really strong.
i had thought about new upper valvetrain....guess i will need to budget that in too... the list just grows and grows!
Old 01-25-2004, 08:33 PM   #9
1972C10
1972C10's Avatar
Yeah cam it .. you got dish pistons or flat tops?
Still consider valve springs there too cheap to skip out on and then drop a valve.
Your rebuilder might have put a good spring it in already just be sure to check them out or upgrade them
Old 01-25-2004, 11:13 PM   #10
dion
72 Cheyenne
dion's Avatar
get the specs on what you have, pistons, heads, CR etc and call around and tell them what you want, they'll let you know what would be best for you..
I have a hydrualic flat tappet cam with a .550 lift, check out the videos.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 01-25-2004, 11:25 PM   #11
oldtrucknut
67-72 truck surgeon
Don't put much of a cam in it, you will lose driveability. Look for something that is suited for towing. It will give you a good rumble and add low to midrange power. You don't want anything more than that, trust me... been there done that.
1969 Chevy C10
1993 Toyota Camry LE
1999 Ford F250 Super Duty 4x4 diesel
2008 Dodge Charger Super Bee
1953 International R182
oldtrucknut is offline   Reply With Quote
Old 01-25-2004, 11:26 PM   #12
gonebad2
Merciless Butcher
gonebad2's Avatar
Do you have an automatic tranny and power brakes? Don't go too crazy with the lift and durration. Otherwise you can run into problems with insufficent vacuum for your tranny and brakes....Just a thought to keep in mind when you go shopping.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-26-2004, 05:28 PM   #13
'70_402
'70_402's Avatar
Thanks for the input guys, i really appreciate it!! yes i had thought about the vacume issue... will consider that!
Thanks, Rick
