#501 | |
![]() Join Date: Nov 2007
Re: Project; Divorce Therapy ( 72 SWB 4x4 )
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() |
#502 |
![]() Join Date: May 2003
Yup... My back is on the list of ailments too ! Can't be bent over much at all.... Man I'm starting to sound like an ole fart !!! "LOL"
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#503 | |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#504 |
I get the muscle & joint pains.
I got the 2 books today, one explains everything and the other is basically a recipe or cook book. It's basically becoming a vegetarian ! Doubt that will work for me, but I'll try it for a while to get my cholesterol down then go from there....
#505 |
Hope it goes well for you
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust ![]() |
#506 |
![]() Join Date: Oct 2013
I know how you feel guys by the time i was 43 i had both shoulders reconstructed ,Right knee and three vertebrae in my back fused and metal plates in the front and rods and anchors in the back .I used to be a lineman Electrical and had to retire early and close my Motorcycle repair shop down too .Its a huge adjustment and i lost it for a few years !LOL but it all works out in the end just have to pace myself real slow.Ha ha
#507 |
Ozzy, sounds like you got busted up pretty bad man ! Must be fun going through the metal detector at the airport !!! "LOL"
#508 |
Yea its always a challenge ha ha
#509 |
Very nice build. Like the color. Green is really starting to grow on me. We built a 70 Chevelle SS that was an original dark green car. We added a little blue to the green and the car just popped. But now the light greens are to my liking.
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project |
#510 |
Well here's my progress pics from today.....
"BEFORE"
#511 |
"AFTER"
I know it's not progress on the truck but it got soooo bad I just couldn't find anything !!!! "LOL" Does anyone else have this problem ? Now I'll see if I can't get something done on the truck !!!
#512 |
Great job on the shop cleanup! I have the exact same problem right now. You've inspired me to go out and look at my mess to see if I feel like organizing today!
![]() Your truck is turning out great! |
#513 |
It was way over due, I don't know when the last time was I saw the top of my bench was..... "LOL"
#514 |
I tend to have the same problem myself.
#515 |
me too. i have neglected the garage cleaning lately. it shows.
your workbench looks sweet! especially clean! |
#516 |
Not quite as bad as yours, but not good! My method is to push everything to the rear, until i get enuff space to work. LOL
![]() 20141120_125504 by james_jaros, on Flickr
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-04-2015 at 10:43 AM. |
#517 |
Thanks ryanroo;
Well it's time to get going again on the truck, and my garage is just a single stall under the house so there's not much room, cleaning it helped a lot. I found out that a thermostat by-pass hose is needed with any sbc with Vortec heads so I'm going to take care of that before I forget ! Problem being I didn't know this prior to buying and installing my High volume reverse rotation aluminum water pump. This water pump also has no provisions for the heater return hose so I'm looking at drilling and tapping the side of the water pump about in the center of the picture in the flat area. ( If there's enough meat ) What do you guys think ???
#518 |
I had no room left to push anything !!! "LOL"
#519 |
Gary, i read that thread and my take on it was if you have a functioning heater, flow would be ok to prevent steam pockets. But, weren t they also saying you had to drill the block in the right spot......keep the pics coming as i could use some direction on how to address this problem
Nice clean shop, i ll try to follow suite ![]()
#520 |
Jim;
Yes on the heater, but if you had A/C and the water shut off valve then you either needed a by-pass hose or drill holes in the thermostat itself. Most blocks have the water by-pass hole, it's the vortec heads that don't have the water crossover passage in them and you could build steam, over heat the heads and possibly crack a head. So I'm going to put the by-pass hose in, that goes from the intake manifold to the top of the water pump, but my issue is I have no connection on the suction side of the pump for my heater. Gary
#521 | |
#522 |
The port on the radiator has the fan control temp sensor in it, and didn't we have the fitting sized to fit the sensor when we had the fttings threads repaired ?
#523 |
Radiator port !
I was also thinking about putting a T off the top of the water pump for the by-pass and the heater return ?
#524 | |
#525 |
560 air ??? Windows ? "LOL"
