01-08-2015, 09:48 PM | #1 |
1971 K20 parts F/S
Jan 6 at 5:10 PM
First thanks for looking. DLTruck1973 is a combined effort between myself "tll74" and "TBONE1964" both certainly no strangers to this site. I (Tom) have bought out my family of our family owned business D & L Truck Parts very recently. We will be offering parts from all of our Chevy/GMC trucks. I personally have a stock pile of 67-72 trucks that we will be listing as they get parted out plus many loose parts from many past trucks. Thomas aka "TBONE1964" will be handling the listing and selling of the parts. I have been selling parts for years here on the site but have been struggling finding time and keeping up with request from members. This combined effort hopefully will resolve that problem. It's our hope and wish that we can provide excellent service and parts to you fellow truck enthusiasts. To avoid possible confusion, we ask that you try to respond in the thread(s) for parts listed with in the thread. Shipping via UPS, USPS, and freight truck. Payment via Paypal, MO, and cards over phone. This thread shares common parts for K20 Pickups and Suburbans. Note: these parts were removed from a Suburban. There will be a separate thread posted with Suburban parts only very soon. Some parts may not be in the photos but available. Photo 1 Hood latch...15.00 Hood latch striker...10.00 Grill support center...10.00 Grill support left...10.00 Fender/Radiator support "triangles"...7.50 Park light lenses...12.50 each Washer hoses with firewall pass through grommet...12.50 Upper radiator hose pipe (best one I've had or seen)...85.00 SOLD Emergency brake cables (front cable, interm.cable, frame brackets, support rods, and couplers)...75.00 SOLD Front cross member...25.00 Left and right brake calipers...25.00 each Fan spacer...7.50 SOLD Front bumper brackets 71-72 4x4 only...22.50 each SOLD Steering shaft (intermediate)...25.00 Wiper transmissions...12.50 each Brake line set (front 4x4 only)...40.00 Inspection cover...15.00 Tin flywheel cover typical split at top starter hole...10.00 Bell crank with pivot stud on block, frame bracket, rod to fork...30.00 Gas peddle assembly 71-72...28.00 SOLD Master cylinder with proportioning valve...30.00 SOLD Flywheel...25.00 Front stabilizer shock with mounting hardware (aftermarket) shock probably wore out....12.50 Engine cross member been tanked and acid dipped nice...75.00 SOLD Transmission cross member...65.00 Body mount brackets / all... Front spring hangers/core support mounts...40.00 each $75.00 for a pair Front axle bump stops bumpers with brackets...10.00 each Front spring shackles...12.50 each Photo 2 Front axle shaft LH 71-early 72(small u-joint) needs u-joint, some wear on pocket bearing surface... 60.00 Front axle shaft RH 71-early 72 (small u-joint) nice...75.00 Engine mounts...5.00 each SOLD Transmission/transfer case mounts (mounts on cross member) original and complete...45.00 Front spring rear hangers for shackles...20.00 each Front leaf springs pair...125.00 Door hinges, front doors and rear door... Front upper shock brackets...5.00 each Rear drive shaft some play in splines...75.00 Rear axle bump stops with brackets...12.50 each Rear spring hangers (front)...30.00 each Photo 3 Windshield rubber and trim ding in trim RH lower corner nice otherwise...65.00 Rear HO72 differential housing tanked still original factory markings...125.00 Rear differential housing cover...22.00 SOLD Floor hump 4sp/t-case...30.00 SOLD Park brake assembly...22.50 TH350 4x4 shift linkage complete... 50.00 Door relay RH...10.00 Speedometer cable 4x4 ...25.00 Blower motor...15.00 Alternator bracket set...40.00 Washer bottle bracket...5.00 Upper trim for door panels...10.00 each Inside mirror hazy glass otherwise very nice...20.00 Outside (2) RH door handles average DQ, one pitted other kinda dull...20.00 each Window cranks...7.50 each Door release handles...7.50 each Lower side vents with handles and knobs...22.50 each SOLD PASS SIDE Wiper motor very nice paint...25.00 Under dash wiring harness 4sp/gauges very nice...65.00 Front light harness 71-72 one wire spliced...40.00 Front RH park light housing...10.00 Engine harness (for manual trans) bad ends on starter and temp... 20.00 Brake/Clutch pedal bracket assy...40.00 Steering Column...65.00 (SOLD) Defrost vents...10.00 each SOLD Last edited by DLTruck1973; 02-02-2015 at 01:35 PM. |
01-08-2015, 09:53 PM | #2 |
Equal opportunity joke ofender
Re: 1971 K20 parts F/S
condition of steering column and shipping cost to 21801 business. Also verify it is a floor shift column.
Thanks Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-08-2015, 09:57 PM | #3 |
Just like to part out trucks!!
CONGRATS Tom and Tom!!!!!!!!!!!!!! You guys will do awesome together!!!!!!!
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
01-08-2015, 10:15 PM | #4 |
depending on postage or freight, and a pic of
4 speed transhper trans cover 30.00 id like that the front crosmember ,75.00-- does it have upper and lower pieces and the mt mounts 5.00 each my zip 84648 |
01-08-2015, 10:21 PM | #5 |
01-08-2015, 10:23 PM | #6 |
01-08-2015, 10:30 PM | #7 | |
Thank you, Thomas |
01-08-2015, 10:50 PM | #8 |
01-09-2015, 01:28 AM | #9 |
Carpe manana
Condition/shipped cost to 59901 of the master cylinder, prop valve, and MC to prop valve lines - mostly need the lines but will consider whole package. Thanks,
01-09-2015, 06:54 AM | #10 |
I'll take the front 4x4 bumper brackets and upper radiator tube for a 1972!
Thanks, Eric Last edited by 1972 Jimmy; 01-09-2015 at 07:00 AM. |
01-09-2015, 07:51 AM | #11 |
One of the First
Does the HO72 cover come with good drain plug? Ill take it pending info...
And the fan spacer, can you measure, Ill take it pending info...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
01-09-2015, 09:44 AM | #12 |
I'll take the passenger side Lower side vent with handle and knob. My zip is 55443.
Thanks! Lee
72 Ochre Blazer 69 Camaro Z28 Garnet Red 48 Willys (rolled) |
01-09-2015, 10:03 AM | #13 |
What is there for hubs/lockouts?
1967 C10 SWB Owner - Rustbelt Restorations |
01-09-2015, 10:26 AM | #14 |
I've had nothing but great experience dealing with Tom ( tll74 ) Good parts at good prices !!!!!
You guys partnered together should be awesome !!!! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
01-09-2015, 01:17 PM | #15 |
in photo 4 im interested in oil fill tube extension , need price ,add to my stack
01-09-2015, 01:26 PM | #16 | |
The drain plug on this cover is in excellent condition, no rounded corners. The fan spacer is 1 1/2 thick and 1 1/2 inch bolt center. Let me know, Thank you, Thomas |
01-09-2015, 02:56 PM | #17 |
01-09-2015, 03:01 PM | #18 | |
With your other parts above, the total for everything on your list with shipping is $182.00. Let me know and I will get everything ready to ship. Thank you, Thomas |
01-09-2015, 03:04 PM | #19 | |
I can sell you the proportioning valve with the two short lines. I would rather not split the lines from the valve. The master has no real value so the price is still $30.00. I can ship without the master for $10.00 for a total of $40.00. Let me know and I can get them ready to ship Thank you, Thomas |
01-09-2015, 03:06 PM | #20 |
01-09-2015, 03:24 PM | #21 |
Thomas,
Sounds good for the lower side vent. Please PM me your PayPal contact. Thanks!
01-09-2015, 03:27 PM | #22 | |
Carpe manana
01-09-2015, 03:52 PM | #23 |
I will need your payment info , is this price with tube and grommet,
thanks kevin |
01-09-2015, 04:02 PM | #24 |
01-09-2015, 04:05 PM | #25 |
Payment Sent for Passenger side vent & Handle.
Thanks! Lee
