Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 12-24-2014, 02:44 PM   #2451
skorpioskorpio
Re: PO has me PO'd
I'm not sure there is actually any performance advantage of wasted spark, it really has to do with having half as many trigger events to keep track of. You basically fire the plug based on the crank trigger alone. My 6 will have that initially when I'm running carbs, mostly because it's just simpler to pull off with an engine that never had a distributor and my options are limited for a simple ignition only crank trigger based ignition that will work with a 6. I'll be using one that is typically used with a Porsche flat 6. The "wasted spark" happens during the exhaust stroke when there is no fuel to burn and the exhaust valve is open so there isn't any real way to gain anything from it.
skorpioskorpio is offline   Reply With Quote
Old 01-08-2015, 01:32 PM   #2452
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I ve been sourcing out my spicer front axle locking hubs, finally located everything to switch over my Warn locking hubs to Spicer (everything is differant)
Decided to look up Spicerparts.com.....came up with a service manual w/ exploded view.
Home page
Drop down to expert
Light axle
Literature & catalogs
5306-1
The only part i don t have are the 6 bolts and washers. I know they are 10-24, but i don t know the length. Could someone pull one out of their hub, and measure the length? Make sure you retorque to 35-40 in/ pounds.....INCH/POUNDS off the manual
I should be able to match them up, once i know for sure wnat the length is....thanks
Teaser
[url=https://www.flickr.com/photos/97391199@N06/16230701555/]
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-08-2015, 02:02 PM   #2453
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Jim
From bottom of head to end of bolt is 1-3/16" but the threaded area is only about 3/8" of the end
here is a a picture of it
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 01-08-2015, 02:56 PM   #2454
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Perfect Richard, thank you for taking the time. Seems Warn used a 32tpi, and Spicer used a 24tpi....oh well
SAFETY FIRST
AS usual, off topic
Jim
Old 01-09-2015, 09:45 AM   #2455
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Does any one have an idea what would be used to remove this threaded collar with all the little holes in a radial pattern? I consider myself well stocked with tools, but this one is not in my box.
I don t have to remove it now, but if i have to replace a wheel bearing, i would like to have the tool for the job
20150109_083326
SAFETY FIRST
AS usual, off topic
Jim
Old 01-09-2015, 10:12 AM   #2456
skorpioskorpio
Re: PO has me PO'd
Is it this?
http://m.ebay.com/itm/271712058665?nav=SEARCH
Old 01-09-2015, 10:31 AM   #2457
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by skorpioskorpio View Post
Dude you re good, sure looks like it
Thank you...how s the truck coming....your build is light years above my head
Ok blew up the image and the tool has square dogs, but my retainer has round
SAFETY FIRST
AS usual, off topic
Jim
Old 01-09-2015, 10:59 AM   #2458
skorpioskorpio
Re: PO has me PO'd
Often socket type pin spanners have squarish pegs even though the holes are round, I know that was the case with the "official" hub retention tool from Honda for my bikes, although I ended up making one on a CNC mill.
My project is stalled at the moment, probably pick up in a month or so. I've been sorting out what I need to do to get the intake manifold printed and have pretty much decided to go for carbs initially just to simplify things and get it going faster. My manifold design will do throttle bodies or Webers interchangeably.
Old 01-10-2015, 12:07 PM   #2459
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I agree on the "official" spanner tool,but i m wondering if the threaded collar is not a spicer part, and more a warn part. Since you listed the proper tool to use, just got me wondering....
Give it time, your build will come together, being an old english car guy i always liked the Webers. If you need two bodies for mockup, i have two here. Always wanted to build a SBC w/webers, just for the looks. Might look into changing them over to throttle bodies, i know they do it with hilborn injection
SAFETY FIRST
AS usual, off topic
Jim
Old 01-10-2015, 02:39 PM   #2460
skorpioskorpio
Re: PO has me PO'd
Understood, and I'm not saying that *is* the proper tool, but it's something very much like that, I'm sure. I made my Honda hub tool and a year later or so saw an official one on ebay. The official tool for your hubs is likely made by one of the automotive tooling specialty companies, and probably costs an obscene amount of money if it's even still available. I have one of the sockets for taking apart a master cylinder booster which I got used on a mislabeled auction for like $50, new that stupid socket goes for like $750.
Old English car guy eh? Well than you'll appreciate this, you know the goal is to get that Trailblazer engine to speak E-type. That engine is pretty much the same bore and stroke (give or take a little) as a 4.2 Jag engine, and I'm hoping to get it to sound like an Eagle E-type by the time I'm done. It's also why I'm going for a big 3" single exhaust with as few bends as possible and a before the wheel exit, to kind of exaggerate the doh-pop-pop-pop of a well tuned Jag.
I have the DCOE pattern throttle bodies already so already have what I need to mock things up. My biggest problem was getting the spacing right to clear the alternator (which bolts directly to the block on this engine) and maintain the maximum angle for the Weber floats while still providing at least something close to equal length runners. I ended up squeezing the spacing a bit on the design which actually makes the first and last runners a little longer, but I think it'll be ok. It makes all 6 stacks equally spaced which I think will look pretty cool. The added benefit to that is I was really afraid I was going to need to notch the firewall to clear the carbs, and this solves that problem as well. I'm planning at this point to just use known Jaguar jetting and chokes for a Jag engine putting out about the same HP as a base line. The only issue with this is that the Jag engine seems to cap out at about 300HP when they are built up and that is where the Trailblazer engine starts out. So we'll see.
Old 01-10-2015, 03:06 PM   #2461
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
You say 300+ hp, what will the torque numbers like.....your jimmy isn t quite as slick as a series 1
Got some time to finish up the coil packs, wired. Spacers, at first, didn t work out, but bought thicker wall spacers and can crank down on the mounting stud. Still have to finish up the vertical mounts
20150110_133700
SAFETY FIRST
AS usual, off topic
Jim
Old 01-10-2015, 03:09 PM   #2462
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Now, finally on to the distri.
20150110_133628
SAFETY FIRST
AS usual, off topic
Jim
Old 01-11-2015, 08:20 AM   #2463
skorpioskorpio
Re: PO has me PO'd
HP/Torque on a bone stock Trailblazer engine are 291hp@6000 and 277ft/lbs@4800.
Old 01-12-2015, 11:09 AM   #2464
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Sounds respectable...
After a three day soak in white apple cider vinegar, all the rust came off. Finally get to install my 'NOS' Locking knobs
[url=https://www.flickr.com/photos/97391199@N06/16238146086/]
SAFETY FIRST
AS usual, off topic
Jim
Old 01-12-2015, 01:20 PM   #2465
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Went to reassemble my hubs and noticed a bind on the locking knob, seems that my old knobs had a bit of a wear pattern. Rather than notch my knobs, i decided to cut the collar that was causing the bind in the first place
It s only a small amount, but enough to not allow me to torque the perimeter bolts down
20150112_120401
[url=https://www.flickr.com/photos/97391199@N06/16079067867/]20150112_120529[
SAFETY FIRST
AS usual, off topic
Jim
Old 01-12-2015, 05:57 PM   #2466
skorpioskorpio
Re: PO has me PO'd
Um, why apple cider vinegar vs just plane ol' white vinegar? Does it make them tastier?
Old 01-12-2015, 06:40 PM   #2467
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just doubles as something i can use in the kitchen....
SAFETY FIRST
AS usual, off topic
Jim
Old 01-12-2015, 07:04 PM   #2468
skorpioskorpio
Re: PO has me PO'd
When I did my bike tank I started with 3 cans of Ajax kitchen cleanser and water (shake! shake! shake!) followed by 2 days and 2 gallons of white vinegar followed by a sock full of rice for a week. came out perfect.
Old 01-12-2015, 07:10 PM   #2469
mtully79
mtully79's Avatar
Re: PO has me PO'd
I'll bite...how did you use the rice? I have a few parts to clean and I'm interested in the application.
mtully79 is offline   Reply With Quote
Old 01-12-2015, 07:11 PM   #2470
mtully79
mtully79's Avatar
Re: PO has me PO'd
Was it to soak up any remaining moisture?
Old 01-12-2015, 07:28 PM   #2471
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Actually, i think it was for fuel....it is a rice burner
SAFETY FIRST
AS usual, off topic
Jim
Old 01-13-2015, 02:07 AM   #2472
Captainfab
60-66 Nut
Re: PO has me PO'd
Sounds to me like it was already in the kitchen and someone snuck it out to the garage.
Old 01-13-2015, 03:08 AM   #2473
skorpioskorpio
Re: PO has me PO'd
Yes the rice is to dry out the moisture, so the tank didn't flash rust from the vinegar and the sock was so you could get the rice out again.
Old 01-13-2015, 01:16 PM   #2474
mtully79
mtully79's Avatar
Re: PO has me PO'd
This is why I love this site. I'll use this for future parts/projects.
Rice burner...nice one Jim!
Old 01-13-2015, 01:30 PM   #2475
skorpioskorpio
Re: PO has me PO'd
...and they may be Japanese bikes but you can't run them on straight rice, the would be ridiculous, you have to add raw fish.
