Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 01-14-2015, 01:01 PM   #376
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: '62 GMC BurbMaster "Rust"oration, Patina Build.....
I used the existing top bolt hole loactions, and drilled the two outers for the wedge cuts ...
Weld nuts on underside.
Final grind/sand will come later before Powder ...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-14-2015, 10:21 PM   #377
Advanced Design
Advanced Design's Avatar
That came out nice! Good progress Chief.
Advanced Design is offline   Reply With Quote
Old 01-15-2015, 12:11 PM   #378
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks man !!
Next up was the additional tranny cooler off of the Roadmaster ... might as well use it. Bypassing the radiator all together, and running a large cooler in front is the preferred way, but my tranny temps in the burban should be marginal.
I will be towing with it, but nothing more than 5000 lbs or so.
First step was mounting of the cooler. I didn't get pics of that, but basically I just reshaped the aluminum brackets to fit the core. Looks like it was made for it ...
Rather than run rubber hose (that would be toooo easy), hardline is the answer !
To me, its more like art ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-15-2015, 12:33 PM   #379
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Second line in. This one received just a bubble flare on the lower end, as it will slip into the existing 3/8" rubber line ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-15-2015, 12:58 PM   #380
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-15-2015, 12:59 PM   #381
Free Candy Inside
Those lines look great.
Free Candy Inside is offline   Reply With Quote
Old 01-15-2015, 05:36 PM   #382
Advanced Design
Oh yeah...nice line bending! Really like a neatly routed and bent line...skill and patience.
Old 01-18-2015, 01:30 PM   #383
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by aggie91 View Post
Nice!
Thanks guys ... It does take time and patience.
I try not to waste any tube in my bends.
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-18-2015, 01:44 PM   #384
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The Engine Oil cooler was next. The stock lines did reach, but were slacked tight ... so I wanted it a little more cleaner. New hardlines, some push-loc fittings, and we were good ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-18-2015, 08:27 PM   #385
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-18-2015, 09:07 PM   #386
likaroc13
Rollin' Old Skool
You have some nice attention to detail!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-18-2015, 10:17 PM   #387
Advanced Design
Thanks for sharing those connectors Chief. I hadn't seen them before.
Great detail!
Old 01-19-2015, 01:52 AM   #388
Captainfab
60-66 Nut
Very nice work Chief.....especially on the tube bending. What brand of tube bender are you using? Do you like it? I need to get a better one.
Old 01-20-2015, 11:13 PM   #389
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I have two ...
I use a larger Matco one, and just picked up a smaller, Blue Point one for a little tighter bends on smaller tube.
I will post pics and prt numbers
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-20-2015, 11:14 PM   #390
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Great detail!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-20-2015, 11:38 PM   #391
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I wanted to switch it up a bit, and move to the back of the Burban, and start the mock up of the rear floor crossmembers and fuel tank.
Since I have extra crossmembers, I decided to add an extra one to the rear floor area behind the axle, to support the wood floor, the fuel tank and eventually the rear most seat ....
Temporary shims for spacing the body mounts ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-20-2015, 11:47 PM   #392
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The "extra" crossmember was added by using these nut inserts (left over from some Aluminum truck box installs ... I save everything ) This allowed me to place the crossmember in a different spot other than the factory holes.
Next was to check the fuel tank fit. Again, this plastic tank is from the Roadmaster, and has the built in fuel pump ...
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-20-2015, 11:53 PM   #393
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
The tank needs to sit as high as possible ... so a little trimming of the front crossmeber will give me 2"... which is better than nothing
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-21-2015, 12:00 AM   #394
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Trimming the crossmember to clearance for fuel lines, and raised section of tank ....
Random pics ....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-21-2015, 09:33 AM   #395
piratexpress1369a
piratexpress1369a's Avatar
great work ..stay at it
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 01-21-2015, 11:04 AM   #396
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Thanks ....
That's the plan !
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-21-2015, 01:25 PM   #397
Advanced Design
I like the inclinometer pics...making it easy for us to understand.
Is the roadmaster tank fill on the left side?
As always great work Chief.
Old 04-29-2015, 01:38 AM   #398
Captainfab
60-66 Nut
Any more progress Chief?
I'm sure you have a lot going on but thought I'd ask anyway.
Old 10-14-2015, 09:19 AM   #399
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Hey Captain ... I sure do.
Yes, the past year has been quite a wild ride.
I am now sweeping up the dust that settled a couple of months ago, and filling the whole I was in !!
To bring this back up to date, I found some old pics on my PC from when I left off ... I must of been bored here:
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 10-14-2015, 09:25 AM   #400
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
