Old 01-21-2015, 10:17 PM   #351
NevEno
NevEno's Avatar
Re: 60-66 Tire/Wheel Pics
It's the weld joint.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 01-21-2015, 10:54 PM   #352
LVPhotos
LVPhotos's Avatar
Few more shots.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-21-2015, 11:16 PM   #353
joedoh
joedoh's Avatar
love it! huge fan of big billets!
Old 01-22-2015, 03:02 AM   #354
mcfarlnd
Originally Posted by LVPhotos View Post
Few more shots.
Are you able to run inner fenders?
mcfarlnd is offline   Reply With Quote
Old 01-22-2015, 11:13 AM   #355
LVPhotos
LVPhotos's Avatar
Not really. Went to set doghouse on and lower sheet metal made contact with upper bag/arm mounts. Could cut but rather sell my nice parts. I'm committed, if it has gone this far lay it out. I will fab some inners, rear tubs or like. Just got it on ground. New tko 600 trans to replace t5. This is ride height.
Old 01-22-2015, 11:19 AM   #356
LVPhotos
LVPhotos's Avatar
Fender contact.
Old 01-22-2015, 01:40 PM   #357
Nope
Nope's Avatar
I have the stock 15" steelies with 56 chevy bel air hub caps.
Nope is offline   Reply With Quote
Old 01-23-2015, 08:31 AM   #358
ChrisDollins
ChrisDollins's Avatar
245/45/18 on 18×8, 4.5bs. 295/45/18 on 9.5, 4.5BS rear.
Looks great! Perfect setup. Get that hood on and outside for more shots. Lol
Chris
ChrisDollins is offline   Reply With Quote
Old 01-23-2015, 08:45 AM   #359
darkhorse970
darkhorse970's Avatar
Did you have to trim any sheet metal to fit the rear wheels in there? Very nice stance/tire/wheel combo!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 01-23-2015, 09:54 AM   #360
LVPhotos
LVPhotos's Avatar
Not really. The inner tubs have a rub spot 1/4" x 3" long on the bubble, from side to side shift. I did cut arch for full drop yet so far don't see that it was needed.
Hood? I don't have new trans yet! Figure if I were to order new trans someone would call for job. Yep back to work. No more screwing around. New Porterbuilt hinges needed.
Old 01-24-2015, 11:20 PM   #361
sixTsix
well I don't have tires mounted or mounted on the truck ...should be mounted this coming up week ...but ill post what im putting on my ol beast ..not thru cleaning them up yet but you get the idea
66' Short Stepper- 350-NP440/4speed
Under Construction - http://67-72chevytrucks.com/vboard/s...d.php?t=629426
sixTsix is offline   Reply With Quote
Old 01-25-2015, 10:18 AM   #362
Lugnutz65
Lugnutz65's Avatar
sixTsix,
Nice choice! I'm a big fan of the slots myself.
How wide are your rims? I assume they are 15".
Going with black walls or raised white letters?
Mine are from a Jeep Wagoneer and you can see minor differences.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 01-25-2015, 10:57 AM   #363
LVPhotos
LVPhotos's Avatar
Yep, fan of the old school slots. One reason I chose Salt Flats.
Old 01-25-2015, 11:07 AM   #364
Lugnutz65
Lugnutz65's Avatar
I got my slots for CHEAP. Otherwise I'd get the Salt Flats. Love that look. What size rim and tire is that on yours?
Old 01-25-2015, 11:38 AM   #365
LVPhotos
LVPhotos's Avatar
That's a 295/45/18 on 18x9.5 Fronts are 245/45/18 on 18 × 8. Watched Trucks and their F100 is running same rear tiresults little widerwider fronts.
Guy down the street had a 65 that got wrecked but would not get rid of 15x10s
Old 01-25-2015, 01:21 PM   #366
DLW
What front end mods did you have done? Can you keep the inner fenders at ride height? For the front wheel BS, did the 4.5" work out to be the best choice you think? Asking because I'm in the market and will obviously measure but nice to see something similar. I came out the same as you in the rear for BS, but I'm going with a 275 back there I think.
I'm starting to like the 18" all around better than me thinking I might do 20/18 offset or 20/20. Looks great LVPhoto's!
DLW is offline   Reply With Quote
Old 01-25-2015, 01:58 PM   #367
LVPhotos
LVPhotos's Avatar
I just got the Porterbuilt crossmember in. The inners would have to be trimmed to clear bag mount/ upper arm mount. As for turning I would think it might be problem. I did use drop spindles so if you didn't want ride height so low...I bought rims as standard offset, still cost me custom price. The rear is a 70s 1.5" wider.
20s all round same size so you can rotate. I went for 28" tire for 3.73 gears and overdrive to get 2200rpm at 75
Old 01-25-2015, 07:01 PM   #368
Slow Build
Slow Build's Avatar
You should probably get shorter valve stems put in when you get tires mounted.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 01-25-2015, 09:08 PM   #369
corvettejim1968
corvettejim1968's Avatar
i had the 3" stainless trim rings until i broke the rear end last month. i pulled over to a parking lot and left the truck 20 min. came back to one missing. so my buddy Alan gave me a set of the 1 1/2" stainless trim rings and i like them better. i think it shows off the rim nicer.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 01-25-2015, 09:26 PM   #370
sixTsix
Originally Posted by Lugnutz65 View Post
sixTsix,
Well It will either be Cooper Corbras or BF TA ...Raised letters all the way around. I am still going back and forth on size though. 255/70 or 255/60. well I guess ill find out this week hahaha...
I've always love slots. What my pops always ran on his rides so it was a no brainer decision ya know. I'm not sure what brand mine are. The only markings I have found is the size and weight capacity stamped on the back. I do know they came off a 70 c10, so I can imagine from the way they look that they are era correct.
They are 15x7, 3 3/4 BS. I'm also not going for mirror finish either. I'm going for the semi gloss finished like they were new.
Regaurdless I'm very excited I found them in 6 lug in a 15x7 for a ok price..instead of the more common 15x8.5 or 15x10 in six lug. Best part is these have basically zero curb rash so I got a good deal. Soon as I have them mounted I snap some pics.
Old 01-25-2015, 09:27 PM   #371
sixTsix
Yea I will have metal short valve stems install when I have them mounted. One of them alrdy have a short metal valve stem installed. so that's what im going to get.
Old 01-25-2015, 11:48 PM   #372
Jeff La
Love me some slots. Would like to find a set of 16" just like running that size tires.
Jeff La is offline   Reply With Quote
Old 01-31-2015, 10:15 PM   #373
Grandpa54
Grandpa54's Avatar
Heres my wheels
Grandpa54 is offline   Reply With Quote
Old 01-31-2015, 10:21 PM   #374
Lugnutz65
Lugnutz65's Avatar
Here's a video of my slots IN ACTION for the first time.
Old 02-01-2015, 02:13 AM   #375
Captainfab
60-66 Nut
A little info about your wheels?
Originally Posted by Grandpa54 View Post
Heres my wheels
