12-15-2013, 05:25 PM | #251 |
Re: Camaro Caliper Brackets
Sorry disregard plunger that would be an issue if i were to change out the brake booster,and it sounds like thats not needed.Thanks for the help i'll post more pics when completed.
12-16-2013, 04:17 AM | #252 |
I need a set of these, but don't have time to read through 11 pages to find the price on the powder coated ones. I se a price for bare steel on the first page. I'll send a PM.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
12-17-2013, 12:27 AM | #253 |
60-66 Nut
PM replied to
The satin black powder coating is an additional $28.00
12-17-2013, 03:31 AM | #254 |
Think I'll go with the unpainted set. Will send PayPal right away. Thanks.
02-06-2014, 10:02 PM | #255 |
do you make any brackets to accomadate the 98-02 fbody calipers?
02-07-2014, 01:06 AM | #256 |
60-66 Nut
No I do not.
02-07-2014, 02:17 AM | #257 |
Will these work with the wilwood d52 calipers?
02-07-2014, 02:28 AM | #258 |
60-66 Nut
No, these only work with the '93-'97 F-body calipers. If you want to use the Wilwood D52 calipers, you will need my D52 brackets.
02-07-2014, 03:21 PM | #259 |
02-07-2014, 04:24 PM | #260 |
60-66 Nut
The total for a bare steel set is $121.65. If you wish to have them in satin black powder coat, the total is $139.65.
02-07-2014, 08:43 PM | #261 |
Regarding the corvette MC, front reservoir goes to front brakes and rear to rear? Just did my 64 lincoln and it was opposite so I thought I'd ask
02-08-2014, 01:41 PM | #262 |
60-66 Nut
I believe that is correct, but I'll have to verify that. Are the fittings different sizes? I was thinking that the general rule was that on masters that have equal size reserviors, that the front is front brakes and the rear is rear brakes.
02-09-2014, 08:31 PM | #263 |
02-13-2014, 08:34 PM | #264 |
Hey CaptFab, want to order a bracket for Impala disc/Camaro caliper. sending paypal now.
Thanks |
02-14-2014, 12:20 AM | #265 |
60-66 Nut
Payment received and email sent
08-26-2014, 12:27 PM | #266 |
ryserstine,
what is the bracket shown in this picture? or is that some sort of JIG for welding/fabrication? if you don't mind me asking?great work! that bracket caught my eye, just wondering what it's for..... Ben |
08-26-2014, 11:29 PM | #267 |
60-66 Nut
If you are talking about the bracket that is below and behind the caliper, that is the panhard bar mount that is on the NASCAR trailing arms.
08-27-2014, 09:29 AM | #268 |
that's a pretty stout looking bracket, I was just wondering what it was for, never seen one of those before.....
Thanks Captainfab! Ben |
01-13-2015, 06:04 PM | #269 |
Are you still making these brackets
01-13-2015, 09:55 PM | #270 |
That bracket is on the end of the trailing arm and where the adjustable track bar mounts
01-14-2015, 12:33 AM | #271 |
60-66 Nut
Yes I still make these as well as all of my other products
01-23-2015, 05:18 PM | #272 |
driving is in my blood
Mother of god......I don't know how I've never seen this before with all my years on the board, but I am so glad I finally did!!!! I'm in the middle of a full repaint on my '98 but the rear brakes are next on the list after paint. Thank you for offering these!!!
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-24-2015, 02:02 AM | #273 |
60-66 Nut
I do not yet make any rear disc brackets for the '88-'98 trucks. I keep hoping to find the time to work on those, but with working 70-80 hrs a week every week, time is scarce. Does your truck have the 8.5" 10 bolt or the 9.5" 14 bolt?
02-03-2015, 02:04 PM | #274 |
What rotors can I use with these brackets and calipers to swap my truck to 4.75 bolt pattern?
I've seen Chevy Astro van rotors mentioned, but the obvious Camaro rotors that match the calipers would be nice to use. |
02-04-2015, 12:18 AM | #275 |
60-66 Nut
The only rotor that can be used with these brackets without modification are the ones they are designed for.
The '93-'97 F-body rotors have a 5 x 4.65" wheel stud pattern, are smaller in diameter and a different height. I have started on a different set of brackets for the trucks using the 5 x 4.75" wheel stud pattern, but I don't know when I will have time to finish them up.
