02-13-2015, 07:48 PM | #1 |
Re: Show off your Wheels
1995 Corvette ZR1 wheels. I used two sets of front wheels. 17x9.5 -52mm offset. 275/45-17 on all corners. I powder coated them Speedway Grey with Casper Clear topcoat.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
05-26-2019, 11:19 PM | #2 |
Do you know how wide your rear end is? I’m wondering if I can fit 17x9’s without tubbing the bed. My rear end is 62” wide
05-31-2019, 08:44 AM | #3 | |
My 17x9.5 wheels have a little room to go out (towards fender), but with the huge positive offset, they sit in a little bit, so I cut the bed and will add small tubs. I may reverse this if I change rear end and use different wheels. Long story short, with proper offset/backspace, you should be able to fit a 9" wheel without tubbing. I 'm probably going to swap to either a 3rd Gen Axle (61.5" WMS-WMS) or a Ferd Exploder 8.8, but shortened 3". I don't know what that width will be, but it'll center the pumpkin and be close to the width of my Jag IFS, so I can run similar backspace front and rear.
06-04-2019, 10:27 PM | #4 |
Riddler 18x8 |
06-07-2019, 02:22 AM | #5 |
It's a catastrophic success.
Ridlers
06-09-2019, 04:41 PM | #6 |
04-22-2020, 06:54 PM | #7 |
Chrome smoothies 16x8 with 235/60 16 tires all around.
05-10-2020, 04:02 PM | #8 |
My 51 GMC, Wheel Vintiques 6x16 front, 8x16 rear , powder coated in red with stainless steel trim rings and smooth baby hub caps,
05-10-2020, 09:26 PM | #9 | |
