02-19-2015, 02:10 PM | #51 | |
Re: Heat sucks
02-19-2015, 02:39 PM | #52 |
Re: Heat sucks
That's where my gauge reads even when hot, and a mechanical gauge reads at 190-200.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
02-19-2015, 03:42 PM | #53 |
Re: Heat sucks
5 bucks says your daily driver has insulation, which goes up the inside of the firewall, where your truck is a big hunk of cold steel with a heating system that is almost 50 years old. Put a thermometer on the floor, the seat, and the headliner and see how much of a variation in temperature there is, then do this to your daily driver. Think the results might shock you.
02-19-2015, 03:57 PM | #54 | |
Re: Heat sucks
I have insulation on the firewall of the truck. Floors are bare since I just painted them. The plan is to put down sound deadening mat followed by insulation and carpet. I guess my main point was the heat sort of works when sitting still, but the air temperature of the heat coming from unit cools off when moving. I guess I will find out Saturday morning when I take it for a drive and determine if any of m y changes improved the situation. I don't particularly care about my comfort, but my 2 year old son loves riding in "his truck" and I want to make as many memories as I can with him. |
02-19-2015, 04:38 PM | #55 |
laying low
Re: Heat sucks
Have you checked the cowl air intake door to see if its working? It's been a long time since mine was on the road so memory is questionable on this. It is vacumn operated. That cowl door when closed will allow the fan to pull air from inside the cab to recirculate it thereby warming the cab better.
02-19-2015, 04:54 PM | #56 | |
Re: Heat sucks
I have also read that the fan should be multi speed. I have never tried the air fan control lever in different positions, only all the way right or all the way left. Are either of those items factory installed on a non-ac truck? |
02-19-2015, 05:13 PM | #57 |
laying low
Re: Heat sucks
Oh. I assumed you had an air cab. For sure the air cab has that cowl door but a heat only cab may not. And you definitely have a multi speed fan even on your setup.
02-19-2015, 05:26 PM | #58 |
Re: Heat sucks
02-19-2015, 07:35 PM | #59 |
Old member
Re: Heat sucks
No cowl vent flapper on non AC trucks. No need for it.I think we have figured it out though. You are just not able to over come all the cold metal for these kinds of temperatures we are having right now.
Are you planning to come to the breakfast saturday by chance?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-19-2015, 08:04 PM | #60 | |
Re: Heat sucks
I did discover that the multi speed function actually works, so I may experiment with a slower air speed so the air is in contact with the heater core longer |
02-19-2015, 08:12 PM | #61 | |
Old member
Re: Heat sucks
02-19-2015, 08:49 PM | #62 |
Re: Heat sucks
I'm off exit 27 (or 34 depending on my route) on 85, so I planned to head up 85 the whole way.
02-19-2015, 09:09 PM | #63 |
Old member
Re: Heat sucks
OK, I was just looking at the weather and it looks like snow and rain for Saturday so I want be in the truck. I'll drive the Tahoe!
