02-19-2015, 04:41 PM | #1 |
1991 gmc jimmy
New Purchase. VERY happy. 1991 GMC Jimmy. 84,341 miles. Fully loaded. No Tach. (is this common) 100% original, excluding tires and battery. Paint and body never been touched. Guy has had it sitting since 2001 in his heated garage here in town. His other toys are just as nice, just wont sell them. More pictures to come, this photo is from his garage. Very excited.
____________________ 1967 Chevy C10 SWB 2WD 350/Auto 1969 Chevy C10 SWB 2WD I/6 3 on tree 2001 Trans Am WS6 6spd 2010 Chevy Tahoe 4WD 1991 GMC Jimmy 4WD all original 84K miles |
02-19-2015, 05:33 PM | #2 |
Re: 1991 gmc jimmy
Tach is super hard to find in a factory one of this era. I don't think I've ever seen one in the suburban or K5 straight from the factory.
Some have retrofitted older ones in there or LMC I think has an aftermarket one that looks stock. Nice truck and great find!
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
02-20-2015, 11:59 AM | #3 |
Re: 1991 gmc jimmy
So with this sitting so long with only occasional start ups. What can a guy expect to see wrong with this once I put a few miles on it. As of now I don't see any leaking or blue exhaust on start up or acceleration. Thanks for your time guys.
02-20-2015, 01:15 PM | #4 |
Re: 1991 gmc jimmy
Very nice! Rare truck too. Last yr for Jimmy and there was only 3500 or so built.
As for a tach, no after '82 on option sheet but there are a few people who did get them installed from factory as far as '85 if I recall correctly. That being said, you have the electric speedo (90-91) so it complicates factory tach install but it can be done. Some cutting and Dremel work is involved due to speedo taking up a lot of room in the housing. I put one in my '89 Blazer but I have last yr for cable driven speedo. |
02-20-2015, 01:31 PM | #5 |
Re: 1991 gmc jimmy
Yeah I guess Im not to worried about getting one in there. Don't plan on towing much or off roading it much. Just thought maybe missing a option that seemed like a no brainer when ordering this thing.
02-24-2015, 05:02 PM | #6 |
Re: 1991 gmc jimmy
probably wouldn't hurt to put in a new fuel filter and run some techron through a tank of gas.
brakes fluid and lines might be worth looking at also. great score! that jimmy would probably look better in my garage though....
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
02-25-2015, 12:55 AM | #7 |
Re: 1991 gmc jimmy
Nice find! How about pics of the interior?
02-26-2015, 12:08 AM | #8 |
Re: 1991 gmc jimmy
Thanks for the input guys. Next question... Tops never been off. 1. Do I never take it off? 2. If I do is there going to be a new weather strip/seal kit I'll need to buy?(from never being off/old) 3. If I do decide to take it off and when I put it back on will I have new interior noises? (Hate unnecessary interior noise) this cab is tight, role down your window a quarter inch tight to make the door shut properly tight. Thanks again.
Oh also one other unoriginal piece is the one piece rear glass. Removed sliders years ago cause he noticed they leak when washing.
02-26-2015, 12:32 AM | #9 |
Re: 1991 gmc jimmy
Do what you want, it's your rig now, enjoy it to the fullest!
02-26-2015, 09:59 AM | #10 |
Re: 1991 gmc jimmy
i doubt you would have any issues, but the more you take it on and off, the more you will likely end up with noise or sealing issues.
i prefer the solid side windows myself.
02-26-2015, 11:38 AM | #11 |
I know the pieces fit
Re: 1991 gmc jimmy
They seal up well, just take your time taking it on and off and store it carefully while it's off the truck and it should be fine. Nice score.
09-09-2015, 10:06 PM | #12 |
Re: 1991 gmc jimmy
Well I haven't kept up with this post.... Here is the list of things i found wrong.
License plate light did not work. Busted wire. Burnt out left front marker light. Ac compressor failed. Cracked dim headlight. So far it's been good. I might replace all six shocks. Body mounts. Thoughts on front dual stabilizers? Also what stock height pavement pounder shock do guys like? Feels sloppy in the steering. Any other thoughts? Thanks. Ahhhh yes also cruise sets fine but then slowly looses speed and hold again... Any thoughts?
____________________ 1967 Chevy C10 SWB 2WD 350/Auto 1969 Chevy C10 SWB 2WD I/6 3 on tree 2001 Trans Am WS6 6spd 2010 Chevy Tahoe 4WD 1991 GMC Jimmy 4WD all original 84K miles Last edited by xxx1967; 09-09-2015 at 10:19 PM. |
09-15-2015, 09:48 PM | #13 |
Re: 1991 gmc jimmy new pictures sept.
finally some pictures...
09-15-2015, 09:49 PM | #14 |
Re: 1991 gmc jimmy
2more
09-15-2015, 09:51 PM | #15 |
Re: 1991 gmc jimmy
interior1
09-15-2015, 09:53 PM | #16 |
Re: 1991 gmc jimmy
interior
09-15-2015, 09:55 PM | #17 |
Re: 1991 gmc jimmy
engine bay1
09-15-2015, 09:56 PM | #18 |
Re: 1991 gmc jimmy
engine bay2
09-15-2015, 10:04 PM | #19 |
Re: 1991 gmc jimmy
Nice!
09-16-2015, 12:02 PM | #21 |
Re: 1991 gmc jimmy
wow, excellent condition! Any pics of the bottom side?
09-16-2015, 12:54 PM | #22 |
Re: 1991 gmc jimmy
Ill work on getting some of them taken here shortly. Any idea of market value on this thing in different regions of our beloved country the USA. Just curious what others have been seeing in their areas. thanks.
09-16-2015, 01:43 PM | #23 |
Re: 1991 gmc jimmy
wow that's clean
I don't think that I've ever seen one with the rear fender arm rests |
09-17-2015, 12:22 AM | #24 |
Re: 1991 gmc jimmy
Only 90 & 91. Have the shoulder seat belt in back.
09-24-2015, 12:22 PM | #25 |
Chevys Kick A$$
Re: 1991 gmc jimmy
That's an awesome and super clean looking Jimmy great score. Somebody took great care of it as can be seen. Did you get a decent deal on it? Don't have to go into exact details just curious
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
