#51 |
![]() Join Date: Jan 2015
Re: 1968 Gmc ground up restoration
Yesterday we got the engine set down on the chassis and it sure looks nice. Got the radiator core support sand blasted.
vehicle's I own 1968 gmc 3/4 ton camper special 1972 gmc jimmy 1972 Chevrolet nova 1947 ford 1.5 ton dully 1997 f-350 1 ton 2007 Chrysler 300 with hemi |
#52 |
Primed and painted more parts over the weekend.
#53 |
Well i started messing with the box today removed both wheel wells gonna replace them. When i was removing some of the old bolts i noticed that the back support had some welds driver side welds were cracked and missing the bolts to hold on the quarter panel nice. Question i have is are the welds from the factory or someone added them.
#54 |
The welds are factory, all the fleet beds have them, usually you grind that off and unbolt a side to remove.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#55 |
horsepower junkie
my 67 had welds in those locations...you gonna re-use that side trim?
67 ![]() 71 olds cutlass "S" mom bought new..12.30s@113MPH |
#56 |
Ok thanks.
#57 |
not sure yet if we are gonna reuse trim or no trim.
#58 |
Today we started messing around with the drivers door and looks like I will be replacing the whole bottom of the door, of course it didn't look that bad when i bought the truck so I thought. gutted the door out and man the screws were rusty but didn't break a single screw. the track material broke into many pieces trying to remove it.
#59 |
did some more sand blasting last week we have started moving on to working the sheet metal pieces. will be replacing the back end of the fender due to some one hammering in the rusty area and then filling with looked like a couple pounds of bondo.
#60 |
Scored some great parts today, got what i would call rust free cab withe factory rocker panels. Also got a few nice pieces for the truck. The pictures are of the drivers side of the cab.
#61 |
Passenger side of the cab and even has a slider window.
#62 |
More pictures of the cab the inner cowling looks great
#63 |
No rust in the heater box area and no rust in the drip rails
#64 |
Scored the drivers inner wheel well for $20 at the swap meet last saturday. Today I got a fender, wheel covers for the box, a nice front wall for the box and a good fender which just needs a new front nose.
#65 |
horsepower junkie
did you get that stuff at the 4x4 swapmeet? i only picked up a few small things...
#66 |
Looks like a cab i seen in Olympia!
#67 |
![]() Join Date: Mar 2010
Wow, I'm so impressed with all the work and progress made. Would you please do my truck next? If you want to share, what do you expect this restoration to cost? It's also nice that you have your own shop .
#68 |
no didn't go this year. Got most of these from franks in oly.
#69 |
i did get them from olympia. i will be checking into the rockers before i get to much into the cab.
#70 |
thanks and i think i will be looking at around $10,000 to complete the truck i hope.
#71 |
Awesome Project hope your having fun and the pics are great!
#72 |
We swapped the old green rusty cab for the nice white cab
#73 |
Looking good!
#74 |
After putting the cab on the cart we started taking everything out from under the dash which included two white lights that were hooked up to the door buttons. I personally have not seen this before. We also took out the a/c unit that was installed in place of the glove box.
#75 |
This is the a/c unit after we removed it.
