04-01-2015, 02:37 PM | #1 |
Re: What Do You Use To Polish This?
I've used stuff from here with good results.
If you use the right buffing compounds and polishes it comes out shiny. http://www.eastwood.com/autobody/buffing.html |
04-01-2015, 03:24 PM | #2 | |
Get it as smooth as you can with 1200 grit or finer wet/dry sandpaper first. Then use the Eastwood compounds. Use a bench buffer if you can take the grille off and manhandle it yourself well enough to avoid damage (or have a helper with steady hands). |
04-01-2015, 03:37 PM | #3 |
Uummm....maybe consider toothpaste? It is very mild and some brands have materials that are basically abrasive. Seen it done with impressive results. If you do this, try it on a test piece if possible first.
My other vehicle is unmanned.... |
