Warn Lock O Matic Hub Removal
I recently bought a 1969 K1500. It was my grandfather's truck. It's a great truck but it's been off the road for about 20 years.
I was wanting to take the front drums off to check the brakes and wheel cylinders. My grandfather put Warn Lock-O-Matic hubs on the truck in 1978. The problem I have is part of the changes for the hubs involved removing the factory spindle nut. It's been replaced with something that has three tiny little allen head srews, and no notches for a typical spindle nut to grab onto. I think to get it off I need a spanner tool or pin wrench, but I have yet to find something. Does anyone know of the tool I need, or do I just need to fabricate something, or use something all together different? Thanks in advance for any help. |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Warn Lock O Matic Hub Removal
As I recall, loosen those three small allen screws. Then rotate the threaded collar counterclockwise by hand to remove it. If it's too tight to rotate by hand, insert a screwdriver tip into one of the holes and tap on in to break the collar loose. Shouldn't take much. There's a multi-slotted tabbed washer behind the collar, and those allen screws extend into the slots to prevent the collar from backing off.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Thanks for the reply Stocker. I'll give it a try. Really appreciate your help. It's been sitting for so long, I'm just trying to do everything possible to educate myself.
Tapping the holes with a punch did the job perfectly. You were correct, it didn't take much. Thanks for the tip!
Tags |
k1500, lock o matic, warn |
