04-10-2015, 10:20 PM | #51 |
Re: tjs 72 Blazer Build
So I decided to use 73+ front spring u-bolt plates so I could add a front sway bar down the road if I wanted. However the axle and housing on the 72 is 2.75 and 3.5" so I had to elongate slightly with an end mill and take 0.125" out of each hole.
[IMG][/IMG]
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 Last edited by tjsblazer; 03-28-2016 at 11:05 PM. |
04-10-2015, 10:24 PM | #52 |
I had to cut my original Fuel tank hanger bracket to get it out so I made a new one. I got some 3/8" cold rolled rod, shaped to match a factory one and cut some threads. I just need to add some black paint or powder.
[IMG][/IMG]
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
04-10-2015, 10:26 PM | #53 |
04-10-2015, 10:28 PM | #54 |
Got a bag of items zinc plated. All the brake/fuel line clips. They had a minimum charge so I got the fuel fill pipe and some small brake parts that were all rusty redone.
[IMG][/IMG]
04-10-2015, 10:32 PM | #55 |
These things are like a jigsaw puzzle. This took a service manual, some online pictures and a lot of my time. My first set of Drums ever. Calipers and rotors are soooo much easier. Ugghh, Right after I was done I noticed that the backing plate bolts were reversed to put the nut outside so I swapped them around.
[IMG][/IMG]
04-10-2015, 10:34 PM | #56 |
It feels soooo good to finally be putting something TOGETHER. Too many months of taking apart and cleaning / painting. Have a couple of days to put back some chassis together. Hopefully some more updates over the weekend. Cheers.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 Last edited by tjsblazer; 04-11-2015 at 09:32 AM. |
04-11-2015, 12:54 AM | #57 |
Nice update
04-11-2015, 12:04 PM | #58 |
04-11-2015, 12:33 PM | #59 |
I'm trying....
Isn't that just the best. I wish I had sent more stuff to be coated myself.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
04-11-2015, 07:36 PM | #60 |
Yes, I'm glad I got them done. I was grabbing anything I could think of Chassis wise. I had some Grade 8 U bolts I got made at the local spring shop and got them plated in the same lot.
04-11-2015, 07:44 PM | #61 |
Front axle back together. Thanks to those here who have recently gone before me, I was well versed on how to get the Ball joint pre-loads set correctly. I put new front axles in but they don't make the 71/72. Have to get 73+. Just means the larger U-joint. Just barely fits through the knuckle! Also the seal at the back of the Spindle is a little different, I had to machined my 72 spindle 0.125 deeper where the spindle bearing and seal go. In the end it all went together no problem after lots of homework ahead of time.
[IMG][/IMG]
04-11-2015, 08:02 PM | #62 |
04-11-2015, 08:22 PM | #63 |
04-11-2015, 08:25 PM | #64 |
Hey Jeff, nice work. Another one to follow. What coating did you use on your brake drums
04-11-2015, 10:16 PM | #65 |
Thank you. I used high temp manifold/header paint.
04-11-2015, 10:21 PM | #66 |
Perfect idea,ty
04-11-2015, 10:39 PM | #67 |
Carpe manana
Looks great! How are the hub dials holding up as regards the blue color and where did you get the plating done?
04-11-2015, 10:50 PM | #68 |
Thanks Pete. So far dials look the same as when they were first cleaned up. Mind you, they have just been sitting on my work bench.
04-11-2015, 10:57 PM | #69 |
It was time to get the weight off of the 40 year old wooden saw horses that were holding it. I think the legs were about to snap off. They were fine when it was just the weight of the frame. So I have a "roller". I'll work on the hard fuel and brake lines over the next week.
[IMG][/IMG]
04-11-2015, 10:59 PM | #70 |
I had 15 mins of play time left today before dinner so I managed to get the Clutch on the Engine.
[IMG][/IMG]
04-11-2015, 11:03 PM | #71 |
looking BADAZZ!
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
04-11-2015, 11:04 PM | #72 |
Sorry, I missed your second question. I just used a local plating shop in the closest city to me here in Ontario, Canada. They do all zinc, cadmium, nickel, and anodizing.
04-12-2015, 06:58 AM | #73 |
Looking great!
04-12-2015, 07:38 AM | #74 |
Jeff, if you are going to use the OEM spark plug wire looms, now is the time to mount the rear looms, they are a son of a gun to install once the engine is in. I used studs, easier for install
Great assembly work
04-12-2015, 02:03 PM | #75 | |
Thanks for the heads up.
