11-23-2013, 02:50 PM | #1 |
Carpe manana
Need Help w Fuel Gauge Please - Tried a Search
The fuel gauge in my 72 Blazer reads 1/2 full with a full tank and when I disconnect the tan harness wire from the fuse block the gauge needle swings way over to the 5:30 position. I didn't realize it could peg that far to the right. Could this be a grounding issue? Bad printed circuit?
Just before my recent move we swapped in a rebuilt all OEM cluster. Prior to that, the gauge was working fine when I drove the Blazer from So Cal to Albuquerque. The sending unit was replaced when the PO had the Hickey tank cleaned/coated. We didn't muck with the tank. Appreciate any help. I was unsuccessful in searching for an answer. Thanks, Pete
11-23-2013, 05:19 PM | #2 |
Re: Need Help w Fuel Gauge Please - Tried a Search
I would start by verifying you have a good ground to the sending unit itself. Make some jumper wires out of surplus wire. Connect to a good ground and verify first. Then run a jumper to replace our tan signal wire. Mice chewed through mine. Will rule out ground and signal wires. Hopefully your upgraded gauge was within the resistances required to operate.
11-23-2013, 05:24 PM | #3 |
Msgt USAF Ret
5:30 is a little far for the gauge to swing to the right. That indicates that the resistor on the back of the gauge might be incorrect. Try running a ground wire to the terminal on the fuse panel and see if the fuel gauge swings all the way back to empty. If it does then pull the wire off at the sending unit and check for the 5:30 position on the gauge again. If it does the same then ground the wire to the sending unit on a good ground and check again for empty. If it goes to empty then the problem is in the tank ground or sending unit.
If you can, pull the sending unit and ground the flange and with the tan wire connected, move the float arm through it's travel and see if the gauge follows the travel. If it does you may have a bad ground on the tank or the float arm may be restricted in it's movement. A possibility is that the float may have a pinhole in it and it will only lift to the half tank mark because it has fuel in it.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-23-2013, 05:29 PM | #4 |
The wrong sending unit installed previously will send you for a loop as well. Not sure about your application.... Mine (1970) has a range of 0-90 ohms(I believe) to operate properly with the factory gauge. Much outside of that... Your needle will be all over the map
11-23-2013, 08:54 PM | #5 |
Carpe manana
Thanks for the help guys - I really appreciate it. Just to clarify, when I run a ground to the terminal at the fuse panel I'm grounding the tan wire while its still plugged into the spade or unplug the tan wire first?
Since my garage space is limited I put the Blazer in the storage unit this afternoon and drove the K20 home to tinker. Both were just delivered last Sunday after waiting ~8 weeks. I'll trouble shoot the Blazer over the Thanksgiving holiday and get back with you. On my drive home I learned one of my T3's in the K20 lost a low beam and the oil pressure gauge we converted to electronic isn't working (or the oil pump is out on my rebuilt motor with 50 miles). Doh!!
11-24-2013, 12:27 AM | #6 |
Msgt USAF Ret
Unplug it first so you'll be isolated from the sending unit altogether. If you get empty then plug it back in and then unplug it from the sending unit and ground it to a good ground to see if you still get empty on the gauge.
11-24-2013, 12:28 AM | #7 |
Carpe manana
Check - thanks again!
11-24-2013, 02:42 PM | #8 |
Great info here. I still need to get my fuel gauge working.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
11-30-2013, 01:16 PM | #9 |
Carpe manana
Well - the fuel gauge seems to work now and I didn't touch a thing. I'll trace the grounds and make sure all are secure. Also got the oil pressure gauge working on the K20 (loose connection). Greatly appreciate the help guys, thanks. Pete
11-30-2013, 02:30 PM | #10 | |
Those pesky gremlins again..... all named Murphy I bet.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
11-30-2013, 04:48 PM | #11 |
Carpe manana
You got it! Have some green chile stew at Earl's for me! Best, Pete
12-15-2013, 09:00 PM | #12 |
Excellent conversation, Thank you. I'm working on the same thing.
04-10-2014, 06:15 PM | #13 |
Carpe manana
So spring is here and ran out of gas after clocking 90 miles on a full 37 gallon Hickey tank of non-ethanol 91 octane - guess my occasional winter storage warm ups burned a lot of fuel
Anyway, I dug into trouble shooting what I thought was a resolved problem with the fuel gauge. I ran out with a little more than half a tank on the gauge. When I yank the tan sending unit wire the gauge looks like this:
04-10-2014, 06:17 PM | #14 |
Carpe manana
When I ground that slot on the fuse block I get this - will not go all the way to empty:
04-10-2014, 06:18 PM | #15 |
Carpe manana
And with I'd guess 1/2 to 3/4 tank looks like this (sender tan wire on):
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 04-10-2014 at 07:08 PM. |
04-10-2014, 06:21 PM | #16 |
Carpe manana
It's as if the gauge is off by 45 degrees or so. Does this imply a resistor problem with the gauge itself?
This is a clock tach dash built by a board member. The fuel gauge worked fine with the original cluster - not so with this rebuilt cluster so don't suspect ground or sender unit problem. If gauge issue, would a resistor swap likely result in a working gauge??
04-10-2014, 06:26 PM | #17 |
Cluster King
Hi Pete,
Was your gauge position correct when the tank was full? My thought is when they restored the cluster they may have removed the needle from the gas gauge. This is a no no because it is hard to reference where it should be placed when they put it back on after painting. Not 100% sure if that is your problem but it is possible.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
04-10-2014, 06:33 PM | #18 | |
Carpe manana
04-10-2014, 06:42 PM | #19 |
Cluster King
Pete,
I sent you a PM. Let me know if you need anything from me. Take care, Tom
04-10-2014, 06:56 PM | #20 |
Carpe manana
PM replied - thanks Tom!
04-11-2014, 10:51 AM | #21 |
My Jimmy does almost the same thing. Needle goes to about 4:00 though not all the way to 5:30. It did this once about 10 years ago, then worked fine again for a long time. Starting last fall it once again moved to 4:00. I have not tried to troubleshoot it yet, but my guess is a bad connection at some point. Good luck trying to find your gremlin, I will be watching to see if the same solution can be applied to mine.
04-12-2015, 10:16 PM | #22 |
04-13-2015, 01:18 AM | #23 |
Moderator
My 68 did the same thing. It was the ground between the wire/sender or sender/tank. With the truck running, and gauge at the 5 o'clock position no matter how much gas was in the tank, I reached back and wiggled the assembly as well as the wire connection. I watched as the needle dropped back quickly to the hatch marks, and slowed down to where it "should" be. Rocked the truck back and forth to slosh the gas and disturb the float. The needle fluctuated a bit and stopped. I topped off the tank and it registered full as it should. Has been working ever since.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
04-13-2015, 08:47 AM | #24 |
Carpe manana
My problem was a bum gauge - dial indicator was off. If your gauge has never been removed start by checking grounds as per Scott and check the fuse to the cluster while your at it. Good luck!
04-15-2015, 10:45 AM | #25 |
the sender that sits in the tank has a ribbon of fine wire that a copper conductor slides across the ribbon, sometimes varnish/deposits "Insulate" the resistance of the wire, causing the gauge to hang up, just an idea....also, those brass floats will eventually leak fuel past the solder joint where the two halves were joined, causing the float to sink.....
HTH, Ben |
