#851 | |
A day late and $1 short...
Re: Project: Shiro
![]() Drivers cab corner installed... Another view of the driver side cab corner... Driver door fit... Frame rails fresh from the powder coater. Frame loosely bolted together. We'll have to square it up and burn'em down another night, I have to work in the morning and 4am comes early. ![]()
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#852 |
Re: Project: Shiro
Thanks Buck. Excellent work on the frame Buck, it looks awesome. The only reason I like doing my own sheetmetal is that I know that I have only myself to blame for any shortcuts taken. There is no question that your truck is in good hands with Nsane.
Scott |
#853 |
Still Learning
Re: Project: Shiro
Those guys are really doing some nice work on the rust repair! and fast too. The chassis looks great too. Keep up the good work.
#854 |
![]() Join Date: Apr 2012
Re: Project: Shiro
Wow Ernie. This is really starting to move along quite fast. Everything looks great man!! Gonna be killer when it's done!!
Posted via Mobile Device |
#855 |
Re: Project: Shiro
that body work is looking FANTASTIC!!!!
#856 |
C/10 junkie
Re: Project: Shiro
Looking good!
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#857 |
Re: Project: Shiro
Pics from Nsane Hot Rodz...
#858 |
Re: Project: Shiro
... momentum killer, no updates from Nsane Hot Rodz today.
#859 |
![]() Join Date: Jul 2012
Re: Project: Shiro
Cab looks great and is coming along fast! Chassis...drool...I have a thing for nice looking chassis'...love it.
#860 |
![]() Join Date: May 2013
Re: Project: Shiro
This thing is going to be insane. You guys are knocking it out
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
#861 |
Re: Project: Shiro
First update for the day... I think there may be another later.
![]() Fuel filler before... Fuel filler during... rolled edge removed and prepped for a filler panel. Those d@mn topper boot snaps have been filled! I think he said 41 or so. We are replacing the drivers door upon DeWaynes suggestion and due to rust damage to the inner door braces and on the flange. I'm sure we'll see something on this in the next week or so. ![]()
#862 |
![]() Join Date: Oct 2013
Re: Project: Shiro
Lookin' good!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
#863 |
Re: Project: Shiro
Good info to know about the fuel filler. Glad you don't have to be reminded of the "old" cab now that the snaps are gone...oh and the rust. Looks great Buck!
Scott |
#864 |
Re: Project: Shiro
This is like watching a build on fast forward. Cool!
#865 |
Re: Project: Shiro
Second update from Nsane Hot Rodz today...
New driver's door in place... New Driver's rocker panel in place... Another view of the new rocker... And finally the new door, rocker panel, and cab corner interfacing.
#866 |
Re: Project: Shiro
Cool! That is definitely NOT in South Louisiana, because all of that bare metal would be a nice shade of rust by now.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#867 |
Re: Project: Shiro
Here is a learning opportunity for everyone. Please remember to clean ALL of the powder coat residue out of the threads of your parts and use anti-seize when assembling them.
Trailing arm and heim joint after is seized up on me while trying to install it, this is going to cause some @$$ pain.
#869 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Project: Shiro
I would chase all the threaded components with a tap.
I had a welded nut on a rear bridge do the same thing. Clean threads and anti-seize, like you said is the answer.
#870 | |
Re: Project: Shiro
Yep, it sure does. My own fault.
#871 |
Still Learning
Re: Project: Shiro
Ouch! That looks painful. I bet you can salvage the heim joint for sure but the female threads look toast. Good luck!
#872 | |
Re: Project: Shiro
It seems sometimes when a nut is welded it distorts the nut. I had started a bolt and ran it in with an impact during mock up. It ate the threads when I removed it. This was the only one. So I now chase all the theads of any welded nut just to make sure. (this was the bridge that bolts to the PB step notch). I also check them after having parts powder coated. For cleaning threads,... I don't use a normal tap and die set. I use a set of thread chasers that I got from Sears, years ago. They're made for cleaning, not cutting. (I guess they have a shallower cutting edge) You can chuck them up in a battery drill to make quick work of this job.
#873 |
Re: Project: Shiro
Sucks about the heim joint Ernie but in the grand scheme of things, just a bump in the road compared to the other stuff!
![]() It's really starting to take shape! |
#875 | |||
Re: Project: Shiro
