08-19-2014, 07:41 AM | #101 | |
Re: Factory Correct Restoration Details
Re your vision: that's my point. The engine block and the alternator bracket are several hundred mile apart until they come together on the motor line in the vehicle assembly plant, and there's no painting going on then. The scenario you've proposed could not happen. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
08-19-2014, 09:27 AM | #102 |
Active Member
For sure Keith If you know that you know the answers, please chime in and share the knowledge.
When it comes to what happened at the factory the rest of us are just guessing! You are now henceforth to be known as…Our man on the inside![/B] |
08-19-2014, 05:55 PM | #103 |
Very interesting topic and so cool to have somebody like Keith here to contribute!
08-19-2014, 06:37 PM | #104 |
Dang, I wish I had paid attention to how all the various orange brackets had been painted originally before I stripped them all. I should have paid attention to whether there were areas that weren't painted where they bolted up to the block. That might have helped explain things.
That Middle picture of the second set that Steve Hafner posted is an older picture of my engine bay taken right after I put things back together a few years back. That third picture of the second set looks to include a smog pump AND an AC compressor set up. It’s pretty unusual to see that combination survive. Looking at that same truck, is it a manual or auto transmission? I can’t really tell. I don't see an automatic dip stick and it looks like a column shifter. (3 on the tree??)
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
08-19-2014, 08:27 PM | #105 | |
08-20-2014, 07:33 AM | #106 | |
The engine would be received at the vehicle assembly plant in a large rack of 6 or 8 engines, already painted orange from Flint or Tonawanda. The brackets would be provided by some outside supplier, probably in a big shipping "gong", or wire basket. These would be painted black already (some small items were dipped or painted black at the vehicle assembly plant, depending on the specific arrangements). Bolts are received in small cardboard boxes and dumped into breadpans for lineside presentation. The engine is hung on the beginning of the motor line as determined by the vehicle manifest or broadcast sheet and the parts are added as it makes it's way down the Motor Line (transmission, carburetor, accessory drive including A/C and power steering bracketry, exhaust takedown pipes, etc). So - bracket = black. Bolts = black (or cadmium/silver, depending on location/application). K Here's a good link highlighting some squarebody assembly practices: http://www.73-87.com/7387info/Assembly%20Line.htm
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-20-2014 at 07:40 AM. |
08-20-2014, 07:38 AM | #107 |
By way of background, the Camaro Research Group has an excellent overview of the assembly process at Van Nuys and Norwood. I have zero motivation to write a similar overview for trucks because this one is so well done.
http://www.camaros.org/assemblyprocess.shtml K
08-20-2014, 08:54 AM | #108 |
I wonder if the a/c trucks got them while the non-a/c trucks did not. I assume that the where to offset the power drain from the compressor.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
08-20-2014, 11:06 AM | #109 |
My 69 with 350 and A/C came with a 4 row radiator and fan clutch. I think there may have also been a HD cooling option that also would probably have had the clutch and 4 row radiator.
04-30-2015, 10:41 PM | #110 | |
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
04-30-2015, 11:48 PM | #111 |
Drive train color question.
Vehicle: 1972 K20 Suburban built Flint plant The NP205 transfer case is the original and looks to be red oxide primer, the rear drive shaft shows no sign of any color and is covered in surface rust but the front shaft has what looks to be red oxide on the front female section which connects to the diff. Were both drive shafts (both the small female end and the long tube) on both the front and rear painted red oxide matching the transfer case or left raw? Most paint them black but Id rather follow what is factory. For the front and rear axles and springs, were they also painted black from the factory? Only the rear diff cover shows any evidence of black paint. Any low mile 4x4s out there with unmolested undercarriage? Pics? Thanks for any info Last edited by RedRoad; 04-30-2015 at 11:54 PM. |
05-01-2015, 12:08 AM | #112 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-01-2015, 07:43 AM | #113 | |
Front springs, rear axles and springs were drizzled with chassis black in a small booth right before body drop. "Painted" is a bit generous, as it was not a full bodied "spray" but more of a drizzle in the general direction of the chassis, using the cheapest black paint that you can imagine. The amount of coverage was hit and/or miss at best. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 05-01-2015 at 07:51 AM. |
05-01-2015, 09:48 AM | #114 |
I love all of the information Keith has here. Anywhere he posts actually. Makes ya feel like you're on the line building one of these trucks.
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
05-01-2015, 10:32 AM | #115 | |
K
05-01-2015, 05:45 PM | #116 |
It's interesting to me that the discussion about transmission color came up.
When I had my engine our several years ago I also had my CH465 out. After I cleaned it up, It was clearly had been painted some sort of a red primer color. I simply took red primer rattle can paint and re-sprayed it. It still looks good 10 years later. It looked to be a very close match to the original paint.
05-01-2015, 07:25 PM | #117 |
Carpe manana
I did my best to research original colors and finishes when my Flint K20 was restored (see link in my signature below). Will get it right on the next build The NP205 t-cases were painted "Chrysler Red"
05-01-2015, 07:34 PM | #118 |
Black trim paint behind head light bezels disappear.
07-03-2016, 10:32 PM | #119 |
Bumping up this valuable old thread.
07-03-2016, 11:24 PM | #120 |
Here is what I ended up with for the trans and t case. kept all the original hardware, wire wheeled and reinstalled. I originally tried Rustoleum red oxide but found it to be too dark red, ended up using Krylon red oxide and matched the orange color perfectly. Used Duplicolor cast iron high temp engine paint and it matched pretty good to cast parts I soaked in evaporust to remove surface rust.
The last pic shows the NOS flywheel shield that came in black, some others stated it was chevy orange but I think black is correct. |
07-03-2016, 11:49 PM | #121 | |
07-04-2016, 11:49 AM | #122 |
Just to throw a monkey wrench in the mix on the alternator bracket, the LIFE photo of the engine assembly plant clearly shows orange brackets. These may not be truck engines, but at least SOME smallblocks got orange brackets... And I believe the year on the photo was '59.
http://www.camaros.org/images/assemb...ly-engines.jpg But the '68 engines brochure shows black... http://paintref.com/graphics/brochur...vpickup_11.jpg Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 07-04-2016 at 11:56 AM. |
07-04-2016, 04:13 PM | #123 | |
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
07-06-2016, 04:08 PM | #124 | |
I can say that's not the way we did it, nor would I prefer to do it that way given the choice (my concern would be that the bracket could get bent or damaged sticking up unprotected like that). It also points out that there can be some variation between model years, depending on what the individual program teams decide. K
07-08-2016, 01:48 AM | #125 | |
some of those engine pictures early in the post are NOT of origonal engines. too much pitting on the exhuaste manifolds which also should be orange, paint too thick, and heater hose fittings would have been installed befor painting and would have overspray on them. I'm going to stick my neck out and state that both aluminum intakes and valve covers would have some overspray on them I rebuilt a '67 221 t-case back in the early 80's. it was painted a red primer color that was remarkably similer to rustoleum red. ditto for the 420. if in doubt check out NCRS standards. not perfect but pretty close. Last edited by mike16; 07-08-2016 at 02:01 AM. |
