Closed Thread
Old 04-27-2015, 02:14 PM   #2076
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today? Chapter II
I had issues getting my Myrtle Wood sized for my new truck deck, so I turned to quarter sawn red oak. Bought some boards this weekend and they are planed up, ready for sizing and milling.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-27-2015, 04:23 PM   #2077
In The Ten Ring
Will you stain or otherwise polyurethane these boards for your bed?
In The Ten Ring is offline
Old 04-27-2015, 04:41 PM   #2078
67ChevyRedneck
67ChevyRedneck's Avatar
Realized the importance of a battery hold down running through the mountains!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline
Old 04-27-2015, 05:02 PM   #2079
69 GMC Daily Driver
69 GMC Daily Driver's Avatar
I scored an original GM Grille and Grille insert for my 70. Still in the box.
I couldn't believe my luck. Installed it over the weekend. My original
is still in great shape if anyone is needing one.
70 GMC Serria Grande Short
70 Chevy C/10 Short LS Powered
72 Jeep J2000 4X4
86 El Camino (22k original miles)
69 GMC Daily Driver is offline
Old 04-27-2015, 05:23 PM   #2080
TxGoats
I ordered the patch panels to finally address my rust issues. Got them from GMCPAULS.COM . Can't wait to tear into this truck finally. I'm thinking color change to a champagne beige like this
TxGoats is offline
Old 04-27-2015, 06:54 PM   #2081
OregonNed
OregonNed's Avatar
I believe we will stain - just to bring out the look of the wood. It has a lot of flecks and designs in it. Then cover with the best spar varnish I can buy.
Old 04-29-2015, 05:39 PM   #2082
VWNate1
VWNate1's Avatar
Post Used '69 / '70 Grille
I sent you a PM as I need a decent one , not perfect but nice .
TIA ,
-Nate
VWNate1 is offline
Old 04-29-2015, 06:28 PM   #2083
74baggedbug
Yanked out the dash pad & the bench seat to get reupholstered .. Hope to get it back next Tuesday or so
74baggedbug is offline
Old 04-29-2015, 08:37 PM   #2084
In The Ten Ring
I am glad. I think stained wood is so beautiful. Keep us posted.
Old 04-29-2015, 08:40 PM   #2085
In The Ten Ring
I got the rest of the fuel line bent. It may not be perfect but I think it will work. I still need to bend the 90 degree turn at the junction between in-cab and on-fame lines and flare the ends, but it's there.
The green line with the blue tape on the end.
Old 04-29-2015, 10:01 PM   #2086
Lou Boffa
Lou Boffa's Avatar
Got my new gearbox, rag joint and pitman arm all tightened up and torgued correctly. Also mounted my pulleys with new add a pulley for a 3rd groove. Pained the Alan Grove brackets...now just waiting on the pump and lines to come in to finish the project. She comin...
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 04-29-2015, 10:40 PM   #2087
Saclandman
Saclandman's Avatar
Spent far too much time trying to get my drivers idea door to align and get the right gap between the fender and door. My trucks new name is M%÷£€÷_&*#!r.
Then finished cutting out the remaining rotted bed strips. Tried to do more but it was hot and I got tired. Did I mention it was hot today in Sacramento?
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 04-29-2015, 11:42 PM   #2088
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Ordered more parts, so what else is new.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 04-30-2015, 06:36 PM   #2089
In The Ten Ring
I put a clamp onto the new fuel line and bolted that onto the frame (pump end). Now the line is super solid so I think that will work.
I also scraped all of the old carburetor gasket from the intake manifold. It took a couple of hours and lots of carburetor cleaner, but the job is done.
I have the hole plugged until it's time to put on the carb.
Old 05-01-2015, 08:54 PM   #2090
In The Ten Ring
My dad and I started replacing the cab-to-frame bushings. It's great to get my dad's help as he is super experienced in heavy equipment repairs and such (not in sheet metal repairs, alas). Plus, he owned this truck for 20 years before I got it.
First, I opened up the replacement shims with a round file and drill bit. After much discussion, we decided on how the replacements should go. The kit from Classic Heartbeat lacks pointed bolts and I have lost(!) one of the rear originals. We did get the other rear original bolt and its new bushings in and I was able to show him how the cab needs to rotate clockwise to line up for the rest. I just came in from turning a replacement rear bolt to a point so it'll find that cage nut easily. We plan to work on it more tomorrow.
It was satisfying hearing dad agree that the bushings should have been replaced in the 1980's. I had asked him about it when I first came to own the truck but he didn't agree. It's clear he never looked at the bushings before today.
Old 05-02-2015, 02:03 PM   #2091
EARNHARDT#3
EARNHARDT#3's Avatar
All shined up for the first show of the year :-)
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline
Old 05-02-2015, 03:08 PM   #2092
Lees68GMC
Lees68GMC's Avatar
Kind of irks me sometimes there is so many after market parts and products for 67-72 Chevy trucks and very little for GMC. I bought these polished aluminum coil packs covers on Ebay for around $ 100.00 including shipping (Note how much Holley ones are out of plastic) and two GMC emblems for 7.00 each to try this. Don't know yet if the GMC emblems are too big for my taste yet, maybe they'll grow on me. Makes the motor look bigger like a Duramax or something, fun anyway.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline
Old 05-02-2015, 06:04 PM   #2093
In The Ten Ring
This is a post I have wanted to make for 2 years: new cab-to-frame bushings are now in! My dad helped and we did it. *Rather funny that 42 years after he bought the truck new, he's still working on it.
Old 05-02-2015, 11:11 PM   #2094
9teen69
9teen69's Avatar
That's cool you can work on the truck with your dad that is the original owner.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 05-02-2015, 11:13 PM   #2095
9teen69
9teen69's Avatar
Replaced this sucker and got my backup lights working. So nice to have backup lights after 3 years.
9teen69 is offline
Old 05-02-2015, 11:34 PM   #2096
Woodnears
Added an air system.
Woodnears is offline
Old 05-02-2015, 11:36 PM   #2097
Woodnears
A shot outside
Old 05-02-2015, 11:41 PM   #2098
In The Ten Ring
Thanks man. I grew up riding in this truck. It came along 2 years before I did and dad drove it until the early 90's (he bought it new, right off the lot. He saw it and he bought it that day).
I love your name.....when it comes time to get a license plate, I may copy your style but for a '72.
Congrats on getting reverse lights! I have to hold my reverse lever upwards for mine to work.
Old 05-02-2015, 11:56 PM   #2099
allchevy58
allchevy58's Avatar
Installed new cab mounts, steamed off motor, started on getting radiator out to replace radiator support mounts and fix oil leaks. Valve covers and damper seal leaking.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 05-06-2015, 07:59 PM   #2100
In The Ten Ring
I put the fuel tank back in but I think I'll have to take it back out....doesn't the fuel tank gauge wire go in behind the fuel tank?
Closed Thread
