05-30-2015, 11:22 PM | #1 |
3/4 Ton chassis
Hey guys you are all a wealth of knowledge so I am going to ask here. I am in the market for a LWB chassis and have found a couple "locally" but what I need to know is, are all 3/4 ton chassis the same. Meaning I know they came either coil or leaf spring rear suspension but are the frame rails the same for both models? Does the coil 3/4 still use the smaller section width rails. I actually have a C10 and am looking for a frame to build up wile still enjoying the truck.
Thanks Posted via Mobile Device |
05-30-2015, 11:57 PM | #2 |
10/30/19
Re: 3/4 Ton chassis
The frames are the same. Brackets and bracings might be different.
By the way, welcome to the boards.
Fight the good fight, finish the race, keep the faith |
05-31-2015, 11:53 AM | #3 |
Re: 3/4 Ton chassis
I have a straight bare 72 c10 lwb frame no front cross member still has trailing arms and rear coils. $100. Road trip (for you)
05-31-2015, 12:29 PM | #4 |
05-31-2015, 01:01 PM | #5 |
Re: 3/4 Ton chassis
Leo?
1967 C10 SWB Owner - Rustbelt Restorations |
05-31-2015, 01:10 PM | #6 |
05-31-2015, 01:11 PM | #7 |
Re: 3/4 Ton chassis
It's more complicated than that as a Longhorn is a 3/4 ton but has 1-ton rails and so. I think if you stick to LWB (not 133) it's more predictable.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-31-2015, 01:13 PM | #8 |
Re: 3/4 Ton chassis
Yes that was the ? I had spoke w "LEO" in the same area as u looking for a frame........though it might be u.......lol
05-31-2015, 01:14 PM | #9 |
05-31-2015, 01:18 PM | #10 | |
05-31-2015, 01:24 PM | #11 |
Re: 3/4 Ton chassis
Ez way to tell 3/4 from 1/2 from pic is the 1/2 t rear body mounts match frame height, 3/4's are lower..
05-31-2015, 01:34 PM | #12 |
05-31-2015, 01:42 PM | #13 |
Re: 3/4 Ton chassis
He was looking for a 1/2 or 3/4 lwb.
I have a 68 and 70 3/4 lwb and just sold the 72 1/2 LWB. Should be getting another 72 LWB this coming weekend......
05-31-2015, 01:43 PM | #14 | |
05-31-2015, 01:46 PM | #15 |
Re: 3/4 Ton chassis
To bad your not closer, I have a 68 GMC frame that will be a roller that I won't need. Jim
05-31-2015, 01:48 PM | #16 | |
05-31-2015, 01:49 PM | #17 |
Re: 3/4 Ton chassis
Im bout 1 1/2 hr NW from you in Michigan.
05-31-2015, 01:51 PM | #18 |
05-31-2015, 06:24 PM | #19 |
Re: 3/4 Ton chassis
PM sent.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord......... |
05-31-2015, 07:03 PM | #20 |
Re: 3/4 Ton chassis
I don't think there are any Longhorn 1/2 ton units. So far as I'm aware you could get 3/4 ton or 1-ton and there's not a lot of difference between the two. Don't know why they're not just all 1-ton, they already have the rails, and I think only the front suspension and maybe leafs differ.
05-31-2015, 10:03 PM | #21 |
laying low
Re: 3/4 Ton chassis
Someone posted the specs on these frames a few years ago. 1/2, 3/4, & 1 ton frames look the same but the rail thickness is different. Progressively thicker, stronger. I lost those frame specs to a crash.
05-31-2015, 10:06 PM | #22 |
Re: 3/4 Ton chassis
Thanks for that I did see these specs on the site someware and was curious to ton if maybe some of the leaf/coil configurations used different frames.
