Old 05-30-2015, 11:22 PM   #1
Longhornss
3/4 Ton chassis
Hey guys you are all a wealth of knowledge so I am going to ask here. I am in the market for a LWB chassis and have found a couple "locally" but what I need to know is, are all 3/4 ton chassis the same. Meaning I know they came either coil or leaf spring rear suspension but are the frame rails the same for both models? Does the coil 3/4 still use the smaller section width rails. I actually have a C10 and am looking for a frame to build up wile still enjoying the truck.
Longhornss is offline   Reply With Quote
Old 05-30-2015, 11:57 PM   #2
kingsolver72
10/30/19
kingsolver72's Avatar
Re: 3/4 Ton chassis
The frames are the same. Brackets and bracings might be different.
By the way, welcome to the boards.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 05-31-2015, 11:53 AM   #3
WIDESIDE72
WIDESIDE72's Avatar
Re: 3/4 Ton chassis
I have a straight bare 72 c10 lwb frame no front cross member still has trailing arms and rear coils. $100. Road trip (for you)
WIDESIDE72 is offline   Reply With Quote
Old 05-31-2015, 12:29 PM   #4
Longhornss
Where are you at?
Have any pictures
Old 05-31-2015, 01:01 PM   #5
DaHos
DaHos's Avatar
Re: 3/4 Ton chassis
Leo?
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 05-31-2015, 01:10 PM   #6
Longhornss
Originally Posted by DaHos View Post
Leo?
Are you asking if I am Leo? No not me. Why?
Old 05-31-2015, 01:11 PM   #7
davepl
davepl's Avatar
Re: 3/4 Ton chassis
It's more complicated than that as a Longhorn is a 3/4 ton but has 1-ton rails and so. I think if you stick to LWB (not 133) it's more predictable.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-31-2015, 01:13 PM   #8
DaHos
DaHos's Avatar
Re: 3/4 Ton chassis
Yes that was the ? I had spoke w "LEO" in the same area as u looking for a frame........though it might be u.......lol
1967 C10 SWB
Old 05-31-2015, 01:14 PM   #9
Longhornss
Tha is likely my buddy that is helping me look
Old 05-31-2015, 01:18 PM   #10
Longhornss
So did the use 1/2 ton frames in the 3/4 ton trucks with coil springs. Is their any way of telling from a picture the difference between 1/2 and 3/4 ton rails. Other than measuring section and flange length?
Old 05-31-2015, 01:24 PM   #11
DaHos
DaHos's Avatar
Re: 3/4 Ton chassis
Ez way to tell 3/4 from 1/2 from pic is the 1/2 t rear body mounts match frame height, 3/4's are lower..
1967 C10 SWB
Old 05-31-2015, 01:34 PM   #12
Longhornss
Cool thanks for the information that helps out a lot. So when Leo called you which frame was he calling about?
Old 05-31-2015, 01:42 PM   #13
DaHos
DaHos's Avatar
Re: 3/4 Ton chassis
He was looking for a 1/2 or 3/4 lwb.
I have a 68 and 70 3/4 lwb and just sold the 72 1/2 LWB.
Should be getting another 72 LWB this coming weekend......
1967 C10 SWB
Old 05-31-2015, 01:43 PM   #14
Longhornss
What I am looking for and what he should be looking for is a LWB 1/2. Where are you located? He has talked to me about a few different chassis he has found.
Old 05-31-2015, 01:46 PM   #15
hugger6933
Re: 3/4 Ton chassis
To bad your not closer, I have a 68 GMC frame that will be a roller that I won't need. Jim
hugger6933 is offline   Reply With Quote
Old 05-31-2015, 01:48 PM   #16
Longhornss
Guys I am on my moble device here and can't see where yu are all posting from. Location is not nesasarily the deciding factor. Avalability and price MAY offset the location......
Old 05-31-2015, 01:49 PM   #17
DaHos
DaHos's Avatar
Re: 3/4 Ton chassis
Im bout 1 1/2 hr NW from you in Michigan.
1967 C10 SWB
Old 05-31-2015, 01:51 PM   #18
Longhornss
Im bout 1 1/2 hr NW from you.
So the 72 LWB you have coming......? Tell me more
Old 05-31-2015, 06:24 PM   #19
JHT67
JHT67's Avatar
Re: 3/4 Ton chassis
PM sent.
Going through life's daily grind, I can feel the effects of this physical body's fleeting days, But with a young spirit I look toward a brighter day, knowing that in the eyes of eternity, I am but a babe in the arms of my Lord.........
JHT67 is offline   Reply With Quote
Old 05-31-2015, 07:03 PM   #20
davepl
davepl's Avatar
Re: 3/4 Ton chassis
I don't think there are any Longhorn 1/2 ton units. So far as I'm aware you could get 3/4 ton or 1-ton and there's not a lot of difference between the two. Don't know why they're not just all 1-ton, they already have the rails, and I think only the front suspension and maybe leafs differ.
Old 05-31-2015, 10:03 PM   #21
Boog
laying low
Boog's Avatar
Re: 3/4 Ton chassis
Someone posted the specs on these frames a few years ago. 1/2, 3/4, & 1 ton frames look the same but the rail thickness is different. Progressively thicker, stronger. I lost those frame specs to a crash.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-31-2015, 10:06 PM   #22
Longhornss
Re: 3/4 Ton chassis
Thanks for that I did see these specs on the site someware and was curious to ton if maybe some of the leaf/coil configurations used different frames.
