Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 05-14-2015, 04:52 PM   #26
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Parting out - 1957 3600 3/4 ton truck
Well if they say no I'll send you the book pages that say custom is the nice cab deluxe is the standard cab.
Old 05-14-2015, 05:11 PM   #27
GMCNUT
GMCNUT's Avatar
I am thinking this might be Chevrolet-specific information - I am pretty sure GMC did not call non-Deluxe cabs Deluxe....we are investigating this further. Always good to learn new / correct information so we share with others the right knowledge
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 05-30-2015, 12:32 AM   #28
Tailpipe
I have to ask...is there any chance your inline 6 could be a 261 and not a 235. The 261's are getting hard to find.
Thanks, Jeff
Tailpipe is offline   Reply With Quote
Old 05-30-2015, 10:18 PM   #29
ptc
ptc's Avatar
The inline 6 could be anything. If you can tell me where to find some identifying numbers I would be glad to identify it. It is a complete motor and trans. the trans is a 4 speed with a granny first gear. the e-brake is actually on the output shaft and has a circular brake pad around it that holds the shaft.
The extra body I have is a '55 and it is a custom small window. It has all the holes around the window and doors for the mouldings that were on it. The doors are now sold. but I still have a complete cab for $450.00. needs the outside rear corners and the lower door hinge sills. most everything else is pretty good condition. I'll even repair it (weld on new parts, no body work) if you pay the bill.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 05-30-2015, 11:00 PM   #30
Mr. D
Mr. D's Avatar
I guess I unknowingly set off a controversy about custom vs. deluxe cabs.
I'm happy that I learned something new and its great information to have.
I have a small back window cab without custom trim and was considering replacing the cab with a large back window version (if I can find was reasonably priced).
Sounds like both of yours are small back windows like mine though.
56 Chevy step-side
68 Chevy Suburban
69 Corvette Stingray
00 BMW 325 (Daily driver)
09 BMW M3
18 GMC Acadia (Wife's daily driver)
Mr. D is offline   Reply With Quote
Old 05-31-2015, 04:17 PM   #31
Tailpipe
[QUOTE=ptc;7192068]The inline 6 could be anything. If you can tell me where to find some identifying numbers I would be glad to identify them.
The 7 digit casting numbers are on the distributor side and below the line of the distributor mounting hole. They may be in-front-of, or to the rear of the fuel pump, depending on the year and c.i. The 261 will also carry with it captain's bars ( l l ) which will be cast back by the starter, usually between and above the CON number and the date code ( a letter followed by three or four numbers ). If you could just reply with the 7 digit casting number I can decode year and c.i. Thanks, Jeff
Old 06-02-2015, 05:48 PM   #32
ptc
ptc's Avatar
Ill see if I can find them and get them up here. Not getting my hopes up that it anything special, but that would be good !
The whole thing is up for sale as a 235 with trans now for $300!!! is that deal or what?
I just heard of a local SF woman who junked an old MAC computor her husband had at the house when he passed away, the e-junk company found out it was worth $200K and is trying to find her to split the money with her.... If its a 261 I'll split the extra value proceeds with ya!
Old 06-02-2015, 06:06 PM   #33
Tailpipe
Your 235 deal is great but I'm set on a 261. I've got the correct 261 head and am trying to rebuild my '52 Chevy pickup into a strong everyday driver, just can't find the block. Plus, you're just a few miles away. Well, here's hoping!
Old 06-03-2015, 10:43 PM   #34
ptc
ptc's Avatar
Ok the numbers by the fuel pump are 3837004 with GM under it.
the numbers by the rear of block are
CON4 L286
Old 06-04-2015, 01:36 AM   #35
Tailpipe
'55-'57 235ci. Thanks for checking.
Old 07-25-2015, 10:21 PM   #36
TxRat
TxRat's Avatar
do you still have the interior handles. If they are not pitted i'd be interested in all 4.
TxRat is offline   Reply With Quote
Old 07-26-2015, 12:51 AM   #37
fredos59
I can use the light switch and ignition if it has the key/s. Shipping is to 91945
fredos59 is offline   Reply With Quote
Old 08-07-2015, 05:20 PM   #38
michael bustamante
michael bustamante's Avatar
still interested in the valve cover if you still have it
1967custom
michael bustamante is offline   Reply With Quote
Old 08-07-2015, 05:26 PM   #39
ptc
ptc's Avatar
The interior handles have some pitting, ill have to dig them out and get some pics.
Have light sw and ign with orig keys
sorry Mike engine was sold with trans and everything all together...
Old 08-07-2015, 05:38 PM   #40
ptc
ptc's Avatar
Originally Posted by Mr. D View Post
Is the extra cab a deluxe or small back window? If it has big back window (deluxe), I'm interested.
BASED ON THIS:
The next biggest error is Cab identification. Most think that a De Luxe Cab was the better cab with a big window and a chromed heater panel in the dash. Again not so. De Luxe was the base model cab that could be optioned with a big window and a deluxe heater. A Custom cab was the high end cab that would have been optioned with a chrome trim package and better interior with or without a big window or heater.
The spare cab I have available is a 1955 CUSTOM CAB and has holes for all the trim!!! it is totally bare $450.00- it had the stainless steel trim all around it. It is a small back window. it has minimal rust in the typical areas. It has been blasted and thats why it has surface rust on the outside. A spray of Rust Remover and this will be clean steel again..... Needs rear corners replaced, lower door jambs. couple small floor patches.
Can do all repairs if wanted, I can do a big back window conversion too if needed @ cost+ welding time.
Old 08-07-2015, 09:48 PM   #41
Mr. D
Mr. D's Avatar
Originally Posted by ptc View Post
The spare cab I have available is a '55 Deluxe cab that is totally bare $450.00- it had the stainless steel trim all around it. It is a small back window. it has minimal rust in the typical areas. Needs rear corners replaced, lower door jambs. couple small floor patches.
I'm in. Pm my to discuss details.
Old 08-08-2015, 10:14 AM   #42
62 Barnfind
62 Barnfind's Avatar
I need a fan shroud. Did that truck come with one?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 08-27-2015, 05:33 PM   #43
whitedog76
Front spindles availible?
I know they're a PIA to seperate.
Chris
whitedog76 is offline   Reply With Quote
Old 08-27-2015, 07:17 PM   #44
Mr. D
Mr. D's Avatar
Chris
Speaking of spindles, anyone know if dropped spindles are available for 55-57 P/U?
Old 09-18-2015, 04:31 PM   #45
ptc
ptc's Avatar
Started a new post with parts listed that are left. thx
Old 09-25-2015, 05:58 PM   #46
bajabob
bajabob's Avatar
Does your truck have the clutch lever ?? (inboard of the frame).
thanks
bb
bajabob is offline   Reply With Quote
Old 09-25-2015, 06:31 PM   #47
ptc
ptc's Avatar
thanks
bb
Yes it does
Old 09-25-2015, 09:06 PM   #48
bajabob
bajabob's Avatar
I need just the lever, if you had the rod and other linkage in good shape I might take that as well. Shipped to 93004 ??
Old 09-26-2015, 09:23 AM   #49
bajabob
bajabob's Avatar
Something like this??
Old 09-26-2015, 02:11 PM   #50
whitedog76
Spindles?
