Trans cooler with A N fittings
I'm looking for a tran cooler about 9" x 12" give or take with A.N. fittings. Have any of you guys bought a good one you recommend?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
![]() Join Date: Apr 2010
Re: Trans cooler with A N fittings
I used this one from summit racing, I mounted it under the truck. I've put about 1500 miles on it so far and no problems.
http://www.summitracing.com/parts/bm...FUYkgQod1DMAfw
LOWER IT AND DRIVE IT ![]() Sally's thread http://67-72chevytrucks.com/vboard/s...d.php?t=563266 |
#3 | |
All about them K’s
![]() Join Date: Jun 2014
I bought one from jegs for my 3100 and plumbed it inline with the cooler in the radiator. I got all the braided hose and an stuff from jegs as well. Give me a day or two and I'll see if I can find exactly what I've got.(it's been three years since I put it all together)
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Mar 2014
This is what I have. Paired with a RnD radiator and a 700R4. Have not finished putting it together, but the specs all work together.
http://www.summitracing.com/parts/hup-hp8255
72 K10 |
I always like to bring this up because I never know what the right answer is, and haven't heard a compelling argument either way yet:
Assuming you run the aux and the radiator trans coolers in line, then: - If you put the aux cooler before the rad's cooler then you dump less heat into the coolant and you get the 'bonus' of the engine warming the trans up more quickly in cold weather. Also the temp delta between the hot trans fluid and the airflow is greater so it should shed more heat at that stage of the process. - If you put the aux cooler after the rad's cooler, maybe you get better cooling, I don't know. This seems to be the norm. I did the former.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
That is a good question and I am interested in opinions. I think where you live has a lot to do with it as well. Ambient temp and all.
I think a search of the "data base" should come up with lots of ideas.
72 K10 |
I have heard good transmission guys indicate heat in a transmission is a bad thing. I think the quote was "Stop putting heat in my transmission." He suggested running the remote cooler without running through the radiator.
I have no real knowledge, just remember the guy had a reputation of being one of the best in town. |
Heat is bad for the transmission fluid. It loses it's lubrication properties near 300 degrees. In a modern overdrive transmission this could happen in the torque converter if it remains unlocked for too long under load.
Today they engineer the trans fluid to go to the radiator cooler first. It helps bring the engine coolant up to temp more quickly for emission compliance. The in radiator "liquid to liquid" is highly efficient. If an external "air to liquid" cooler is installed it's after the radiator so the trans fluid can be cooled even further.
Still plays with trucks
I run this B&M unit in pretty much every rig I ever build. Works for trans or oil if you want to run two of them.
I even used one in my old auto cross car as a power steering cooler. 315/35-17's on the front put one heck of a load on the power steering system. http://www.summitracing.com/parts/bmm-70266/overview/ The 1/2-NPT ports let you run whatever line fitting into them that you desire.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Great info guys. I was thinking a Hayden 516 cooler, but you guys gave me lots of other good options.
![]() Join Date: Nov 2007
This is what i plan on using. Its bigger than what you were asking, but to give you a idea.
http://www.oregonperformancetransmis...code=LNG-47391 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
