70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Removing Light Switch
I am trying to remove my dash and and have found the spring button on top of the light switch. I have pushed and pushed and now my fingers are indented and it won't release the light switch when I try to pull it out. Anyone run into this problem or have a suggestion on getting it out. I taped a washer to my finger to put more down force on the spring but that didn't work either.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Removing Light Switch
Greg did you try pulling the knob out as it will go first and then depressing the button on top?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
You are the man Pete !!! That was the trick, pull the switch out first, then push on the spring and bingo its out.
Carpe manana
Nice! Glad you made it home safe btw...
