06-26-2015, 10:57 AM | #2551 |
Re: PO has me PO'd
06-26-2015, 12:05 PM | #2552 |
Re: PO has me PO'd
06-26-2015, 02:12 PM | #2553 |
Re: PO has me PO'd
Question regarding your Bilstein install. I just installed a set on my Jimmy. I installed them with the black boots facing down since the Bilstein sticker would be upside down otherwise. No install info came with the shocks. I had my previous shocks mounted like yours with the boot up. I've seen shocks installed either way so don't know if their is a right or wrong. Do you know of any advantage/disadvantage to either way of installing them?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
06-26-2015, 02:28 PM | #2554 | |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-26-2015 at 02:40 PM. |
06-26-2015, 02:38 PM | #2555 |
Re: PO has me PO'd
Ok, just talked to Bilstein, you re right, shock should be installed with correct orientation to the sticker. Guess I have to change mine and ty for bringing it to my attention
06-27-2015, 10:08 AM | #2556 |
Re: PO has me PO'd
06-27-2015, 01:54 PM | #2557 |
Re: PO has me PO'd
are the Bilsteins gas charged? My Fox shocks are and they mount with the body up.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
06-28-2015, 08:29 AM | #2558 | |
Re: PO has me PO'd
May have run into another problem, as one of the brake drums seems to have a crack running all the way around it
06-30-2015, 11:01 AM | #2559 |
Re: PO has me PO'd
Just gotta say rock autos return policy is second to none... called them with complaint, they emailed a shipping label, dropped the part off at FedEx, new part is on the way. They paid postage both ways, what a company, will buy from them again
06-30-2015, 11:06 AM | #2560 |
Equal opportunity joke ofender
Re: PO has me PO'd
Did you notice the crack before you painted it? That probably would not make me happy if I saw it afterwards
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
06-30-2015, 12:18 PM | #2561 | |
Re: PO has me PO'd
lesson learned, inspect parts
07-05-2015, 08:30 AM | #2562 |
Re: PO has me PO'd
Ok, second part arrived, still cracked, they want to refund my money, but I still need a drum. So, I will try a AC Delco part this time and the heck with Raybestys
07-08-2015, 09:52 AM | #2563 |
Re: PO has me PO'd
First attempt to mount dual handbrakes
WIN_20150708_094308 by [url=https://www.flickr.com/photos/97391199@N06/
07-08-2015, 10:06 AM | #2564 |
Re: PO has me PO'd
WIN_20150708_100246 by [url=https://www.flickr.com/photos/97391199@N06/]
07-09-2015, 12:49 PM | #2565 |
Re: PO has me PO'd
Rather then risk ruining my good console bottom, pulled a POS one off the shelf and cut into that, glad I did, because my cuts were a bit excessive. I may have to use the 73 and up bracket on the front of the console to elevate it a bit
WIN_20150709_124437 by [url=https://www.flickr.com/photos/97391199@N06/]
07-23-2015, 11:37 AM | #2566 |
Re: PO has me PO'd
Third time was a charm on the brake drum, but went with AC Delco this time, still Chinese but better quality
Anyway, did some more work to the dual handbrakes, adjuster screw installed, now to figure out what length to make cables WIN_20150723_101746 by [url=https://www.flickr.com/photos/97391199@N06/]
07-24-2015, 08:20 AM | #2568 |
Re: PO has me PO'd
Rich, let me see if I can explain, if you re in the woods wheeling, and if you need to avoid a tree or rock you can make a tighter turn by putting truck into 2wd front axle, lock up one rear brake and turn to that side. Truck pivots on rear axle
07-24-2015, 08:33 AM | #2569 |
Collector of Projects
Re: PO has me PO'd
Cutting brakes. Got it. Isn't it usually done with hydraulics and not mechanical? I'm the furthest thing from an engineer but isn't that putting a lot of stress on that mechanical linkage?
07-24-2015, 10:36 AM | #2570 | |
Re: PO has me PO'd
Sorry to hear about your setback with the flood, hope it all works out for you
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-24-2015 at 11:11 AM. |
07-24-2015, 11:26 AM | #2571 |
Re: PO has me PO'd
Finished up one cable shroud, need some extension springs to take up slack
WIN_20150724_111427 by [url=https://www.flickr.com/photos/97391199@N06/]
07-24-2015, 01:44 PM | #2572 | |
Re: PO has me PO'd
Swamp Rat had posted "are the Bilsteins gas charged? My Fox shocks are and they mount with the body up." Yes, "5100 Series shocks use Bilstein's mono-tube high gas pressure design for consistent fade-free performance & long life." Soooooooooooo, I've learned something new. It's a gas thing! Thanks everyone
07-25-2015, 09:17 AM | #2573 | |
Re: PO has me PO'd
07-26-2015, 07:58 PM | #2574 |
Re: PO has me PO'd
I cut the boots off of mine. Looks better and ensures junk doesn't get trapped in the boot, eating up the shaft. Keep up the progress Jim.
07-26-2015, 08:27 PM | #2575 | |
Re: PO has me PO'd
Progress is slow at best
