Old 07-03-2015, 09:15 PM   #1
72.4me
Hedder bolt holes...
Has anyone ever had a problem with the Hedman hedder fitment? The hedder bolt holes just don't want to line up with the head holes can I use a step drill bit in the Hedman Hedders bolt holes to make them fit? 72 3/4 ton HEDMAN PART# 69090 thanks and Happy 4th
72.4me is offline   Reply With Quote
Old 07-03-2015, 09:54 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Hedder bolt holes...
SBC or BBC?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-03-2015, 11:33 PM   #3
72.4me
Originally Posted by GASoline71 View Post
SBC or BBC?
Gary
SBC THANKS
Old 07-03-2015, 11:40 PM   #4
72.4me
Originally Posted by 72.4me View Post
SBC THANKS
I ran a drill bit through the drivers side to clean up the holes and finally got it to fit, now passenger side needs it..I must of got a bad pair?
Old 07-03-2015, 11:40 PM   #5
geezer#99
geezer#99's Avatar
Before you make the holes slightly bigger, try just cutting the flanges between the tubes.
Old 07-03-2015, 11:45 PM   #6
72.4me
Sorry I don't follow you...
Old 07-04-2015, 12:22 AM   #7
geezer#99
geezer#99's Avatar
The header has a flange. 6 bolt holes in it. Your pipes are welded to it. The flange is the part that bolts to your head.
Common practise is to cut the flange between #1 and #3 and #5 and #7 on the drivers side. Makes the header bolt on and stay tight when you bolt it on.
Cut the flange the same on the passenger side.
Old 07-04-2015, 12:51 AM   #8
GASoline71
GASoline71's Avatar
Old school trick. I've done that before. Works.
Gary
Old 07-04-2015, 12:56 AM   #9
72.4me
Now that sounds like the way to go, thanks for the tip.
