Old 07-05-2015, 05:16 PM   #1
Hart_Rod
Hart_Rod's Avatar
Thumbs up New Product: CHUBTUBZ, shortened rear wheel tubs for slammed trucks!
**** Summer Sale through the 31 May 2017!! 15% off of the CT44s and CT47s! ****
UPDATED PRICING on ChubTubz For C10s!!!!
Due to some streamlining in our manufacturing process, we have been able to reduce the cost of production. Soooooo, I'm going to pass that on to our customers!!!
NEW PRICING:
CT44's - $550 + Shipping (10-12" wide wheel and tire)
CT47's - $650 + Shipping (15" wide wheel and tire)
Paypal preferred or Check or USPS money order.
If you have any question on fitment, please inquire! (text at 850-2NINE1-0499 or PM)
"ChubTubz!"
"Designed for the 67-87 C10s, they will also work for the 60-66 with a small amount of fiberglass work."
For the last 4 years I've been working on building a 1968 SWB that has a front and rear Porterbuilt extreme dropmember setup. Because of the large step notch in the rear, I had to raise my bed floor to clear it. This obviously created a problem with the rear wheel tubs being to tall to fit.
You can approach making the rear tubs many different ways, but I chose to try and make them look as stock as possible. So I built a set of steel ones that I shortened by 4" and widened by 1". I also made the tubs contour to the inner bed panel to fully achieve a factory fit and appearance.
Each tub required 2 factory tubs and about 15 hours worth of work to build. I know a lot of guys don't have the tools, skills, or the time to spend building these and paying someone to build a set of steel ones is cost prohibitive. So after I finished making my set of steel ones, I decided to talk to a local boat shop that does fiberglass mold building. Once I was convinced that we could make a good part that would be economically feasible, I had them pull a mold off of one my steel tubs. After I was sure of the fit and finish, I'm now ready to produce them for sale. They are designed for the 67-72 trucks, but with some small modifications, they will also work for the 73-87 trucks. Initial price will be $500/set + shipping. You can text me at 850-291-0499 or email me at robhartley@aol.com if you have any specific questions
Here are some photos of the original steel tubs that I made, and pictures of the fiberglass tubs. If you have any questions, please let me know. Thanks - Rob
Hart_Rod is offline   Reply With Quote
Old 07-05-2015, 05:19 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: New Product: Shortened rear wheel tubs for Slammed rear trucks
Here are some pictures of the fiberglass tubs. If you have any questions please let me know.
Old 07-05-2015, 07:48 PM   #3
Advanced Design
Advanced Design's Avatar
Great idea with a great price that will save a ton of time too.
Well done Rob.
Doug
Advanced Design is offline   Reply With Quote
Old 07-05-2015, 10:52 PM   #4
dbb1025
dbb1025's Avatar
I agree. I'm one of those guys without the skill knowledge or tools. When will they be available? What will be the best way to order?
dbb1025 is offline   Reply With Quote
Old 07-05-2015, 10:58 PM   #5
Hart_Rod
Hart_Rod's Avatar
Well done Rob.
Doug
Thanks Doug! I hope everyone likes them and appreciate the work that has went into them.
I'm taking pre-orders now. I currently have 8 names on the list. Paypal is preferred. Just let me know.
Old 07-07-2015, 09:17 AM   #6
69short
69short's Avatar
I will be contacting you when I reach that point in my build. Great price! Looks like a nice product
69short is offline   Reply With Quote
Old 07-07-2015, 10:37 PM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks Justin! Here are some pictures of the first set of CHUBTubz installed.
Old 07-07-2015, 10:40 PM   #8
Hart_Rod
Hart_Rod's Avatar
More installed pictures.
Old 07-08-2015, 01:17 AM   #9
ajgriffin
ajgriffin's Avatar
Looks great! What's the maximum tire width they will fit?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 07-08-2015, 01:21 AM   #10
70blackfish
Nice work
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 07-08-2015, 08:47 AM   #11
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 70blackfish View Post
Nice work
Thanks!
These will allow you to run a 12 - 13" tire. I'm running a 295/45 20 on my truck and they fit great. We are working on a 4" wider tub that will go all the way to the frame and allow you to run a 15-16" tired.
Old 07-10-2015, 11:56 AM   #12
SCOTI
SCOTI's Avatar
Rob,
What is the thickness of these? I like them & look forward to the wider version (I plan on 13" wide rear wheels).
I worry about debris damaging them & wondering if an aluminum sheet bonded to the bottom might help w/that. Your thoughts?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-10-2015, 12:07 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
SCOTI,... could you use that "Rock Guard" style coating on the inside of them?
Not sure what anyone is doing with the aftermarket fiberglass front tubs to prevent damage from rocks.
Maybe it's all about fiberglass thicknesss.
Keith
Convert to disc brakes.
Old 07-10-2015, 12:22 PM   #14
SCOTI
SCOTI's Avatar
Exactly. Even on the front tubs for my dually, I plan to bond something underside.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-10-2015, 01:24 PM   #15
Hart_Rod
Hart_Rod's Avatar
Originally Posted by SCOTI View Post
Rob,
The tubs are about 3/16" to 1/4" thick, extremely sturdy. I don't think it's an issue with the fiberglass cracking, I think it's more of an issue with the paint cracking. With that being said, I plan on spraying the underside of mine (front and rear) with a rubberized coating, such a Line-x or Speedyliner. I have a lot friends that have built high dollar glass street rods and that's what they have used with great success. Thanks for the great questions and feedback!
Old 07-10-2015, 07:52 PM   #16
nlped
nlped's Avatar
Hey Rob, for convenience sake, how much is shipping to 35079?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-10-2015, 08:56 PM   #17
Hart_Rod
Hart_Rod's Avatar
Approximately $50.
Old 07-10-2015, 08:59 PM   #18
nlped
nlped's Avatar
So $550 shipped? If so, shoot me your Paypal info. They look great, and you've always done great work. So I'm good with it.
Carter
Old 07-10-2015, 10:00 PM   #19
Hart_Rod
Hart_Rod's Avatar
Pm sent
Old 07-14-2015, 10:12 PM   #20
Hart_Rod
Hart_Rod's Avatar
I had the buy painting my bed shoot some paint on the tubs. What do you guys think? I'm also thinking about changing the name to "ChubTubz". My good friend Ronnie Welch (C10Talk from instagram fame, ) suggested it. It seems a little catchier than FatTubz...OBTW, here ar some pictures, !
Old 07-14-2015, 10:30 PM   #21
lolife99
lolife99's Avatar
I like the fact that these aren't pre-drilled.
A set a stainless button-head bolts with stainless washers, would look nice holding these down.
Keith
Old 07-14-2015, 10:50 PM   #22
Hart_Rod
Hart_Rod's Avatar
Thanks Keith. I wanted to give people an option on how they attached them because I know everyone does things a little different,
Old 07-14-2015, 10:57 PM   #23
nlped
nlped's Avatar
Those look really good, especially with my color on them
Carter
Old 07-14-2015, 11:36 PM   #24
69short
69short's Avatar
Keep the original name and call the wider version chubtubz lol
Old 07-15-2015, 12:21 AM   #25
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Damn those look sweet!! Very well done..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
