Old 07-08-2015, 05:18 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Project Sandstorm. 1971 Blazer 4wd, Boosted carb'd 454 sand beast
I picked this up over the weekend. I had some questions before i started a build thread and tore into this thing. The rust is pretty minimal.
-It has a 454 with a 4speed hooked to it.
Plans are a boosted, carb'd 454 with auto th400. 35s with bead locks. Res. shocks. Should be fun in the sand.
Thats about it for now. WHen i built project karma i really wanted it to be a blazer but i just wasnt patient enough when i started. I will post more pics and start a build thread soon.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 07-08-2015, 05:57 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Started a new project. 1970 Blazer.
Post pictures of where the manifolds are hitting. It's hard to give a response without seeing what is actually going on there.
Post picture of the transfer case. The stock t-case would be a NP205. There is a badge on it if you can find it.
No on the suburban. As far as I know/read/seen, they do not match up.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 07-08-2015, 06:13 PM   #3
lyrikz
PITbut
lyrikz's Avatar
Gotcha. I will get pics coming. Pics of the transmission also?
and sold.
Old 07-08-2015, 10:04 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Suburban hatch won't work - here's a K5 hatch in WA that will: http://67-72chevytrucks.com/vboard/s...d.php?t=676046
Good luck with your build!
Old 07-08-2015, 11:20 PM   #5
lyrikz
PITbut
lyrikz's Avatar
Thanks. I told him I would take the hatch for 200.
and sold.
Old 07-08-2015, 11:23 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You bet - looks like good buy.
Old 07-08-2015, 11:27 PM   #7
GMC-YA68
GMC-YA68's Avatar
Sure. You are ditching it so I didn't figure it mattered.
-Keegan-
Old 07-08-2015, 11:34 PM   #8
lyrikz
PITbut
lyrikz's Avatar
and sold.
Old 07-08-2015, 11:44 PM   #9
lyrikz
PITbut
lyrikz's Avatar
just wondering what it is so when I sell it.
and sold.
Old 07-10-2015, 11:35 AM   #10
lyrikz
PITbut
lyrikz's Avatar
ANyone take a look at the pics and let me know what t/case and trans this is?
and sold.
Old 07-10-2015, 12:44 PM   #11
lyrikz
PITbut
lyrikz's Avatar
Transfer case is a np205.
Transmission is either a muncie sm420, muncie sm 465 or a NP435.
It has granny low, and a 6 bolt side cover.
Hmmm.
and sold.
Old 07-10-2015, 12:48 PM   #12
IronCanine
I'm trying....
IronCanine's Avatar
Looks like a SM465 and an NP205 to me. Since yours is a 70 I think there should be a build tag on the TC attached to driver's side inspection plate (assuming it's original).
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 07-10-2015, 12:55 PM   #13
lyrikz
PITbut
lyrikz's Avatar
Ya, the transfer case i know is a np205 now.
But i am having difficulties identifying the trans.. It has a L, then 3 more speeds.. Any other identifiers to pinpoint what trans it is?
Also, what fluids does the np205 take?
and sold.
Old 07-10-2015, 01:24 PM   #14
lyrikz
PITbut
lyrikz's Avatar
Hmmm.
All three of those look very similar.. I will try and get numbers on the side to see if that helps..
and sold.
Old 07-10-2015, 02:19 PM   #15
viking427
Big Block mounts should give you the exhaust clearance you need. I think the rear dump "passenger" log style manifolds were standard issue on the early BB trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=495656
viking427 is offline   Reply With Quote
Old 07-10-2015, 02:36 PM   #16
lyrikz
PITbut
lyrikz's Avatar
Its funny that im going through this again.. On my 71 i built it had an inline 6 so i bought some aftermarket big block stands and big block mounts i think.. I just dont remember the engine being this far back.
I will dig a bit deeper.
and sold.
Old 07-13-2015, 09:53 AM   #17
68panelman
68panelman's Avatar
Iron canine nailed it, Its a 465 since it has the reinforcing ribs built into the case, 435 have a smooth casting ,and a 420 has a bulge on the pass side. My '70 has it also, but with a Dana 20 TC.
68panelman is offline   Reply With Quote
Old 07-13-2015, 12:11 PM   #18
lyrikz
PITbut
lyrikz's Avatar
Awesome. Thank you. Both are leaking pretty badly so i need to get em out and reseal them. Put some fluid in and hopefully they quiet up a bit.
and sold.
Old 07-14-2015, 08:35 PM   #19
lyrikz
PITbut
lyrikz's Avatar
Dead pics
and sold.
Old 07-29-2016, 06:16 PM   #20
lyrikz
PITbut
lyrikz's Avatar
Figured i would give an update. I didnt realize i didnt update at all.
I planned on going 2wd and changed my mind. I just got off the phone with ORD placing a $3200 order with custom leafs and res. shocks. I lucked out and picked up a very straight second frame that i can build from. I also found a set of 3/4 ton axles i will be running.. i only plan on running this in the sand and some very rare mud, no rock action.
here are some random pics.
I started with the usual floor boards the rocker boxes look good. I peeled the rocker back and it was FULL to the top with mud and crap.
Opened up.
Just refitting everything.
and sold.
Old 07-29-2016, 06:19 PM   #21
lyrikz
PITbut
lyrikz's Avatar
I blasted the rocker boxes, then painted it sealed it all up.
You can see in this picture the bracket i made for the seat. I was going to just weld it in but i was advised to bolt it in. So i plated the underside and bolted it in. Solid as a rock.
and sold.
Old 07-29-2016, 06:27 PM   #22
lyrikz
PITbut
lyrikz's Avatar
This is just some of the junk the PO did.
This is how he spaced the transfer case.
They used street signs and about 40 screws to cover the shifter holes. what a mess.
Seat bracket
Little rust in the cowl area. Shaving the firewall a bit. I like that clean look.
and sold.
Old 07-29-2016, 06:36 PM   #23
lyrikz
PITbut
lyrikz's Avatar
Currently im working on the second frame and i purchased a bronco bob roll cage that i will be installing soon. I currently installed a built new th400, new axles, new radiator, and rewired the vehicle. I plan on saving the tub for last. I want to get it functioning. I do have a little video of me driving it the other day.
New frame.. SUPER straight. Hitch on the rear is already gone. Just getting it bare to send to the blasters and powder coat.
Hitch is finally gone. That was welded in so badly.
These are a rim im thinking of running. 35s with a 15x10. SHould look pretty beefy.
Here is a vid of its first test drive after the new transfer case, transmission and new wiring job.I tried to embed the video in the post so you didnt have to click a link, i dont know how to do that.
First run with new transmission/shifter/open header.
and sold.
Old 08-08-2016, 11:12 AM   #24
lyrikz
PITbut
lyrikz's Avatar
IM getting ready to send the frame out for sand blasting and powdercoating. Anything i should do before i send it out? I was thinking of having it dipped instead of sand blasted. I feel like sand blasting will not get in between the brackets that are riveted on. Any recommendations?
and sold.
Old 08-10-2016, 04:39 AM   #25
mcmlxix
Collector of Projects
mcmlxix's Avatar
Well since this new frame was never mated to the old body, I would be worried about fitment issues. Especially if you powder coat, you can't just touch up the frame if you need to make changes during final assembly. It's A LOT more work, but I would get new body mounts and test fit the frame to the body. Since you're doing rust repair, I would have liked to make the repairs to the body on the new frame with new body mounts to make sure all body panels, door gaps and windshield to roof gap line up ....
Rich
1972 K5 Blazer CST Click HERE
