07-17-2015, 10:49 AM | #1 |
GTO alternator issues
I'm installing an '04 GTO engine and the stock alternator location doesn't work with the Dirty Dingo mounts. I am thinking of using a relocation kit from CBR performance , this would move the alternator up high on the pass. side. It also changes to a CS130 alternator. Then I will need to adapt the wiring of the new alternator , which I really don't understand no matter how much I read about it.
Is there a better option? Or more info on the wiring if the is my best option. Relocation kit $180 Alternator $100 Wiring/adapter ?? Posted via Mobile Device |
07-18-2015, 07:50 PM | #2 | |
Re: GTO alternator issues
GTO's are Australian (Holden) cars, They use a Mitsubishi alternator (& starters), The Alternator isn't PCM controlled, Resisted voltage through the Charge Indicator bulb excites the regulator & the alternator charges. The Mitsu alternator bolts in place of CS130 alternators in '98-'02 Camaros. I'm 90% sure your Mitsu alternator will work on the relocation bracket, Save $100 bucks, Reuse your 140 amp alternator instead of a 105 amp CS130 & you don't have to buy a regulator plug. Call CBR & ask them if a CS130 out of a 4-gen V8 Camaro will work with their bracket..... |
07-20-2015, 12:46 AM | #3 |
Thanks for the information, the bracket I ordered is for a CS130 alternator so I will try my original first.
How will the charge indicator bulb work on a swap since I wont have that hooked up? Posted via Mobile Device |
07-20-2015, 07:55 PM | #4 | |
Or you can hook up a Charge Indicator Bulb inside the truck, Run an accessory hot to one side of the bulb & the other side will go to the "L" terminal. This Bulb will light up if the Alternator stops charging, A nice feature to have. A incandescent bulb must be used....A LED won't work. |
07-25-2015, 09:33 AM | #5 |
I got the relocation bracket and the original alternator won't fit, bought a CS130 alternator and it fits perfect. The GTO alternator is 1/2" longer than the CS130 so it hits the head.
Now to figure out the CS130 wiring, the new plug has all black wires. Posted via Mobile Device |
07-25-2015, 09:20 PM | #6 | |
07-27-2015, 10:34 AM | #7 |
It has an external fan, I got a new plug from Napa (part#EC101) but it has 4 black wires. It looks like you can ID the wires on the plug, I think they are S,F,L,P.
07-27-2015, 07:24 PM | #8 |
07-27-2015, 08:53 PM | #9 |
First off thanks for all the help. So just to be clear the Large S wire can go to the battery or starter and the L wire to a resistor on an ignition wire
Sorry I'm having a hard time with the diagram Posted via Mobile Device |
07-27-2015, 09:47 PM | #10 |
Most CS130 alternators don't use the "S" (Sense) Terminal, The Regulator will sense Internally off the Charge Post. You only need the "L" Terminal to Turn the alternator On.
I have seen CS144's use it, But mostly in "GM-Upfitter" builds like a Hearse/Limo/RV/EMT/Special use work trucks. |
