08-16-2015, 03:41 PM | #2626 |
Re: What did you do to your truck today? Chapter II
Whooo. like to here that run, she isn't an 88F150, may have to change your handle to chevy power.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
08-16-2015, 09:14 PM | #2627 |
I changed the door locks and ignition key to a set that only uses one key instead of two. The hardest part was removing the window crank and door handle, I didn't have a tool so used the rag trick. At least now I can finally lock my doors. Oh I also ordered some more parts from Classic Industries and saved nearly $50 thanks to the 'dog days of summer' sale. That included a new front lamp harness to replace the one that Bubba hacked up.
08-17-2015, 05:31 PM | #2628 |
08-17-2015, 10:36 PM | #2629 |
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
08-17-2015, 11:50 PM | #2630 |
Tried to R & R the Pitman Arm, ugh! Even the tool I rented will not pull it off. Years ago when I replaced the steering box the dang thing almost dropped off, now it wont budge.
Even ground down the out side of the arm at the shaft to get the tool to fit better. Progress yet no results. |
08-18-2015, 10:55 AM | #2631 |
I put on some decals and made a new Colt shifter while listening to Hank on the 8 track.. life is good...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
08-18-2015, 11:07 AM | #2632 |
[QUOTE=hamjet;7277402]I put on some decals and made a new Colt shifter while listening to Hank on the 8 track.. life is good...[/QUOTE
That shifter is too cool and love the sticker!
08-18-2015, 03:35 PM | #2633 |
08-21-2015, 04:33 PM | #2634 |
new fuel tank in. get it hooked up then I can get the interior back in. have to wait til I heal up some more from surgery. not supposed to pick up anything heavy and that seat ain't light.
08-21-2015, 05:54 PM | #2635 |
Got my truck (Homer) to start, stop, go forwards and backwards. Not far mind you (about 10') but under his own power none the less. Milestone after 8 long months of blood, sweat, and tears. Few grinding discs, and some welding wire.:met al:
"Life is too short to drive a boring vehicle". Later, Wayne |
08-21-2015, 06:11 PM | #2636 |
I made another adjustment to my caster and camber that worked excelent, Ground down my brake calipers and added a 1/4 inch wheel spacer so I could run stock rims with rings and moons. Then went on a trip to the beach,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
08-21-2015, 06:25 PM | #2637 |
Nice truck.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
08-22-2015, 11:23 AM | #2638 |
I finally stopped my oil plug leak. PO had over-tightened the plug and messed up threads. I tried a simple single oversized plug and no luck. Then I tried this double plug from Dorman and added some high temp sealant to the treads.
http://www.autozone.com/external-eng...hv/133360_0_0/ Since over-tightening again would be no bueno, I slowly tightened it, checking for seeping every 20 minutes, first two times it leaked I tightened an eighth of a turn and waited. Finally stopped. WOOT! |
08-22-2015, 04:27 PM | #2639 |
went to start the truck this morning to go to work real hard start and when it did it ran like I was missing a cylinder or two. once I was able to get the rpms up it smothed out but you could still tell something wasn't right . I managed to get it to work poped the hood took off the air cleaner sprayed the carb out good blew some compressed air through the passages still crap . pulled the plugs all look good so I checked the timing because I keep it just loose enough to adjust it when needed couldn't get it to settle out . pulled the cap found the problem points almost closed on high lobe distributor was bone dry it must have rubbed the plastic down enough to close the gap it was 3 thousandths . being a little broke at the moment I had to cheat it a little put some antisieze on the cam and rubbing block on the points to help slow the wear till next week . adjusted it to 18 thousandths set the timing running perfect again . love how easy these are to work on.
08-22-2015, 05:10 PM | #2640 |
RAT1968 '68 Cab/'71 Parts
Cleaned out the beginning of mouse nests and a few of their "leavings".
Replaced the pic of the "girls" that had suffered from heat exhaustion. A/C is so cold that I haven't changed the aluminum blank we made for the classier aluminum one that Tom made and gave me for a wonderful present.... and that I had anodized black. This fall, for sure!!! In the meantime, the girls are back in shape.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
08-22-2015, 05:47 PM | #2641 |
painted the frame. start frame assy. tomorrow.
08-23-2015, 12:44 AM | #2642 |
(007) aka Houdini
Well despite I've had a bad sinus infection hitting me lately, I had something irritating me on my truck. So we all know the story if something's driving u crazy in the back of your mind what do u do, figure it out right! Well I was having a issue with my dome was staying on all the time! I traced wiring, headlight switch and so on. Well it turns out apparently/somehow the wrong bulb got put up in the cargo lamp housing and was grounding the dome light to stay on so, problem solved. Lol so while on this journey I decided I was making my cargo light that I never use into a 3rd led brake light so my next project is on......
Live life one day at a time! |
08-23-2015, 04:07 PM | #2643 |
Well ol Samson got a new battery and a coolant system flush today.
08-23-2015, 04:30 PM | #2644 |
Keepin an eye out
Got the top of my dash painted a nice black, couple coats...Also fitted my recent board purchase Dakota Digitals to my old bezel...
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
08-23-2015, 04:45 PM | #2645 |
Bought it for my 15 yr old....first vehicle. 67 with 69 front end. 70k original miles. He loves it!!
08-23-2015, 05:22 PM | #2646 |
I changed the gauges out in my cluster to the ones from a 76+ square body. I like having numbers in stead of letters
08-23-2015, 05:23 PM | #2647 |
How do I rotate an image
08-23-2015, 06:42 PM | #2648 | |
Old member
[quote=ole dollor;7273793]
Thanks Don, sorry I left for the beach and haven't had any computers there. Just my phone and it's not setup for this forum. Going tomorrow and get pricing on the clear bra stuff I hope.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
08-23-2015, 11:55 PM | #2649 |
08-25-2015, 08:38 PM | #2650 |
Yesterday was for my truck. I built a work bench with a shelf. Then ran the cable for the "clothesline" I built for my wife (aka parts hanger).
Today I started tearing into the inside of the cab. Finding the darnedest things, like a chuck key inside a duct hose. Couldn't tell ya.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
