![]() Join Date: Jan 2015
Differences in C10, 20 and 30 cabs???
Work with a guy that wants to know if there are any differences on 1/2ton, 3/4ton, and 1ton cabs? Told him that you guys would have the answers...
![]() Thanks!!
Jimmy Hoelzel |
Go Pack Go!
Re: Differences in C10, 20 and 30 cabs???
Not that I'm aware of. All the differences are during the model years.
To name a few: 67 Small back window, big back window option. 67-68 E-brake under steering wheel and wiring harness junction block 67-68 only 71 had rear view mirrow raised pad above wind shield. |
Same cabs.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
10-30 Chevy/1500-3500 GMC cabs are all the same
Did all C30 cabs have clearance lamps on the roof? I know you could get them on the lighter trucks it was a big thing to have them around here. Also what about high humps? All of the C30's I seen had the high hump but then again so did the big block trucks and the 4X4's. My C2500 has a high hump but it was a big block truck from the factory. With the option exception the cabs will all be the same just as swapping from say a 1/2 ton to another 1/2 ton there very well could be option differences.
Now just to throw an odd ball into the mix, my 1969 C10 was a 307 3spd 2wd and it has a high hump cab, and really no real reason for it. The truck was built in Janesville.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
A C/30 with a TH350 had a low-hump. All 69-72 dual rear wheel C/30s had clearance lamps, as required by ICC. Single rear were an option just as on anything else
Thanks guys! Told him you guys were on top of these trucks!
Thanks again for the info.
Jimmy Hoelzel |
