Old 09-05-2015, 10:27 AM   #76
Advanced Design
Advanced Design's Avatar
Re: 5.3 into 72
Sounds really good! Key jingle, fuel pump, rummmbbblleee.....nice
Advanced Design is offline   Reply With Quote
Old 09-05-2015, 11:00 AM   #77
whitels1
whitels1's Avatar
Re: 5.3 into 72
Sounds great, a nice clean install!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 09-06-2015, 02:35 PM   #78
Arnulfo
Re: 5.3 into 72
Sounds great!i too am digging the pre-start up fuel pump sound. Nice work.
Arnulfo
Arnulfo is offline   Reply With Quote
Old 09-06-2015, 03:48 PM   #79
Arnulfo
Re: 5.3 into 72
What year blazer did the gas tank come out of? Seems to fit perfectly. I like the angle that your engine sits in . Looks factory. I wonder if the same motor / trans mount can be used with a 6L90E trans.... I'm thinking not without a high hump trans cover. What say you experts?
Arnulfo
Old 09-06-2015, 05:26 PM   #80
jessemthompson
Re: 5.3 into 72
The blazer tank is from an 87. As far as the angle goes I used all ECE mounts. They worked out well. I did have to grind a little on the driver side because the header was really close to the mount.
jessemthompson is offline   Reply With Quote
Old 09-07-2015, 05:56 PM   #81
geekitupsum
Re: 5.3 into 72
what motor mount setup did you use? 4l60e trans?
geekitupsum is offline   Reply With Quote
Old 09-07-2015, 09:30 PM   #82
jessemthompson
Re: 5.3 into 72
I used ECE motor and trans mounts and yes, a 4L60E
Old 09-10-2015, 11:16 PM   #83
jessemthompson
Re: 5.3 into 72
Just finished my road trip out to pigeon forge this evening for the shades of the past Rod run. It's been my goal to have the truck ready for this since May. I got out here with no issues and knocked down 19 mpg!!! I believe I would've got 20 if I didn't have to go through the mountains. I am happy with 19 though. So far there is a big turnout here. I'm really looking forward to the show.
Old 09-11-2015, 10:12 AM   #84
oldman3
oldman3's Avatar
Re: 5.3 into 72
Have a great time...Jim
oldman3 is offline   Reply With Quote
Old 09-11-2015, 12:40 PM   #85
gord63
Re: 5.3 into 72
Congrats on the LS install. Looks great. What radiator and gas pedal assembly did you use?
gord63 is offline   Reply With Quote
Old 09-11-2015, 09:49 PM   #86
jessemthompson
Re: 5.3 into 72
For the radiator I used an R&D aluminum radiator and I used a corvette pedal.
Old 09-11-2015, 10:14 PM   #87
Advanced Design
Re: 5.3 into 72
Enjoy the show. I see a lot of FB friends are heading there.
Old 05-09-2016, 08:42 PM   #88
jessemthompson
Re: 5.3 into 72
The time has come to add vintage air to the truck. Has anyone used an Alan grove A/C bracket?
Old 05-10-2016, 12:40 AM   #89
solidaxel
solidaxel's Avatar
Re: 5.3 into 72
Take a look at Bill's Hot Rod brackets
The fit and work, I have used them many times
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-10-2016, 09:54 AM   #90
First c10
First c10's Avatar
Re: 5.3 into 72
This is the steel Alan grove bracket for the LS motor (40-140R I think) I am going with Old Air Products AC system. see my build thread for a few more pictures. its not completed yet but you can see what I have done so far.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-10-2016, 10:47 AM   #91
solidaxel
solidaxel's Avatar
Re: 5.3 into 72
Disregard on Bill's brackets, they are only for SBC he does not have them for Genlll, sorry
LS 3 4L70E
Old 05-10-2016, 10:56 AM   #92
solidaxel
solidaxel's Avatar
Re: 5.3 into 72
Some assembly required with Dirty Dingo brackets!
LS 3 4L70E
Old 05-10-2016, 04:15 PM   #93
Willie Makeit
Willie Makeit's Avatar
Re: 5.3 into 72
if someone needs one of the Dirty Dingo idler relocater and a modified factory ps/alt bracket that is needed for the Dirty Dingo setup, hit me up. got one with less than 500 miles on it. took it out and put it on the shelf when i went with the LSA top-end and bracketry.
Willie Makeit is offline   Reply With Quote
Old 05-10-2016, 05:21 PM   #94
Advanced Design
Re: 5.3 into 72
I used KWIK ac bracket on my 56 and it fit really well. Also Holley has nice top mount brackets that look factory. Just a couple more options for your consideration.
Old 05-12-2016, 10:49 AM   #95
MMLX89
Re: 5.3 into 72
Which headers did you go with? Are the long tubes or mid length?
MMLX89 is offline   Reply With Quote
Old 05-12-2016, 01:04 PM   #96
jessemthompson
Re: 5.3 into 72
I used Gibson headers. They are full length and do not go below the frame rails.
Old 05-12-2016, 01:05 PM   #97
jessemthompson
Re: 5.3 into 72
what is the part # you used for the DD mount. The one on their site for the truck doesn't look like the one you have. What compressor did you use?
Old 05-12-2016, 05:17 PM   #98
solidaxel
solidaxel's Avatar
Re: 5.3 into 72
I don't remember the part number
The folks at D D said this is the one I needed for a 78 ,so I took his word for it!
The compressor is a Sanden I picked up locally from Century Auto Air Conditioning here in Tucson
It works really good as I have to use blend air or it will get down below 30*
I am using the stock 78 Evap and everything is on R134
LS 3 4L70E
Old 06-04-2016, 10:31 PM   #99
SKT
SKT's Avatar
Re: 5.3 into 72
Nice engine swap!
SKT is offline   Reply With Quote
Old 11-11-2016, 07:56 PM   #100
jessemthompson
Re: 5.3 into 72
Well I starTed my vintage air install just in time for winter! Figured I'd post some pictures. It's been a while since I updated this thread. With the AC compressor I had to move the intake to the drivers side. I like it better, I think it cleans up the engine compartment.
