Old 09-12-2015, 10:45 AM   #1
In The Ten Ring
How hard would it be to switch to a 4x4 frame?
Assuming that one day I do buy a panel, how hard would it be to put it onto a 4x4 frame?
There do seem to be a lot of 4x4 Suburban frames out there.....
In The Ten Ring is offline   Reply With Quote
Old 09-12-2015, 11:20 AM   #2
pwdcougar
pwdcougar's Avatar
Re: How hard would it be to switch to a 4x4 frame?
The body mounts are in the same location so it will line up. Just a matter of lifting it up and dropping it on. Along of course with setting the steering, brake lines and electrical ect.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-20-2015, 02:06 AM   #3
twistedchevy
Undo the engine bay wiring, remove front bumper, remove radiator, pull front clip, undo steering column, brake booster, floor shift, and remove body mount bolts then lift body off
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank.
70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank
Dads: 67 c10 step side(project)
72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter)
Ours: 67 c30 tow truck
70 c10 long bed 383stroker w/digital gauges(work truck)
twistedchevy is offline   Reply With Quote
