09-21-2015, 07:46 PM | #1 |
Olive Green Aerosol
Anyone know if there's a brand of spray paint that closely matches the Olive Green from "72?
A man's thoughts devise his ways; but it's GOD that directs his steps. |
09-21-2015, 08:13 PM | #2 |
All about them K’s
Re: Olive Green Aerosol
Subd!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-21-2015, 08:18 PM | #3 |
http://www.paintscratch.com/ these guys have it , requires clear top coat
type your truck in it will come up , medium olive ,, or yellow green ,,
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
09-21-2015, 09:40 PM | #4 |
My local NAPA does color match aerosol
09-21-2015, 09:45 PM | #5 |
Most parts stores that mix paint will put your paint in a spray can around here.
09-21-2015, 10:25 PM | #6 |
Med or Dk Olive? I've used the med olive paint scratch aerosol. Not a lot of coverage and it taint cheap(!) Was a good match to factory original, but not exactly easy to work with. Part of it was my fault, working in a pretty hot garage, aerated before hitting the surface and made a fruzzy mess. But still, turned out ok. Personally, if you have something for someone to match to - I'd go that route.
09-22-2015, 07:16 AM | #7 |
Thanks all. I'll stop in at the paint shop and ask there.
If there's a way to fill and pressurize an aerosol can other than at a factory, I'd be very interested to see that. I'm guessing they'll match it by the pint or quart, and then put it through an HVLP gun myself.
09-22-2015, 07:44 AM | #8 |
medium Olive is one of the hardest colors to match. I have seen trucks with more silvery look shades to deeper like candy apple read. All were supposed to be paint mixed to factory spec. But yeah, go get it mixed. That's your best bet
09-22-2015, 10:14 AM | #9 |
My local Carquest makes spray bombs as well. I even took them an inner door panel to match my non factory color. It isn't a 100% match but it's damn close and 1000 times closer than any off the shelf spray bomb would've been.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-22-2015, 10:24 AM | #10 |
EXACTLY. Did this with my whole interior. Panels, steer column, wheel, even the flatter version of the same color for my dash pad so to match my panels.. The spray tips here were nice.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
09-22-2015, 12:45 PM | #11 |
I've had 3 cans made of med olive poly. All 3 were brighter than the original color. If I need any next time, I'm going to color match it to the inside of the glove box to see if it will more closely match the OE color.
09-22-2015, 02:49 PM | #12 |
I'll ask around for the spray cans. Not sure anyone around here does that. I only need enough to paint the heater box, and my tilt steer column.4
I also need to paint my after market dash pad and my door panels. My collision guy says that there's no way to get a proper job using aerosols.
09-22-2015, 03:18 PM | #13 |
Junior Member
I had some med olive put in a can and it turned out great.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-22-2015, 05:01 PM | #14 | |
I would not use a rattle can on large panels or the whole inside of the cab, but for the parts we are talking about it works fine. Did the pad, panels, column and wheel. It layed down perfect, and IMO turned out great. Make sure the can has that wide spray tip.
09-22-2015, 05:43 PM | #15 |
09-22-2015, 05:48 PM | #16 |
I have a medium olive green truck, and I used a company called Automotive Touchup. They have a color match guarantee and made good on that for me. The first two cans weren't quite right, but the last one I got is almost perfect.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
09-22-2015, 07:24 PM | #17 |
Thanks very much for taking the time to send the link, and especially the photos of the can with the info.
appreciate it greatly. And..........your truck is really nice sboris.
