c10 driveshaft lenghts
I've been searching and im not really coming up with any real solid results. im trying to find out the various lengths chevy trucks have had over the years in the long wheel base trucks. If anybody could help or just post the length you have in your truck. Drive shafts seem to be the a big topic and the 1 piece/ 2 piece question seems to come up alot also' so any help there would be great too.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: c10 driveshaft lenghts
I was just searching for the same info for shortbed 60-66 trucks.
Many give the answer to measure what you have - which I will, but there has to be a few standard lengths. ![]()
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 07-10-2014 at 10:21 AM. |
I have two inline 6 / 3sp manual driveshafts for short beds out right now. I can get a measurement on the one piece shafts tonight.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#4 | |
I would think with manual transmissions the bellhousing mounts to the same place whether an i6 or v8.
#5 | |
you may find one out there the right length but the ujoints and or yoke may be different. then that it was taken out of something else, is it still true( where did that vibration come from?)the time that you spend looking plus your going to have to change the joints anyway, it will be less expensive just to get it done. when you play with vehicles sometimes not everything comes from a store. ron |
#6 | |
I really think there has to be "Standard" lengths for drivelines. The Bell housing was mounted in the same place for thousands of trucks. After that you only have to consider what transmission you have, then short or long bed.
Doesn't it cost like $400+ to get a driveline made?
#8 | |
60-66 Nut
It could cost that much if you have to have a complete new driveshaft made. The trick is to start with a driveshaft that is too long and just have it shortened and balanced. That should be $120-150.
#9 | |
The operative concept here is to control the driveshaft "critical speed", the point at which it begins to swing like a jump rope. It is affected by length, outside diameter, thickness, material, mass and rpm. Highest shaft rpm is affected by vehicle top speed, rear axle ratio and tire diameter. Length is affected by wheelbase and driveline configuration. The driveline is also affected by any unusual or unpredicted system resonances, which can destroy a driveline even at a speed lower than the critical rpm. From an OE perspective the driveshaft choice (one piece vs two piece) can be manipulated by controlling any one or more of those variables. Hence there's a little more going on than picking a length and slapping a couple yokes on it (from a production standpoint). There is a chart that the engineer keeps (like the brake system release charts I have posted in the past) that shows all of the driveline configurations and shaft lengths for every GM light duty truck. I have asked the engineer for it on a couple of occasions but he has not come through with it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I doubt they made each driveline special when the truck reached the end of the assembly line.
#11 | |
Nothing on an assembly line is spontanteous (or, at least, it better not be). Keep in mind a typical line rate is 60 jobs per hour - that's one completed truck every minute. That gives you about 45 seconds to do your job assignment so there's not a lot of time for extra curricular activities. The specific parts are released into the engineering database for each available combination. That way they can be sourced and procured in quantities to support volume production, a process that could take several weeks or even months. (That supplier could be supporting as many as six or seven vehicle assembly plants, so they are making several hundred shafts per hour). With the amount of engine, trans and wheelbase proliferation in full size truck that's a lot of combinations. This is all psyched out, designed, developed and validation/durability tested months and years ahead of start of production. The parts numbers are distributed throughout the plant as required and printed on the manifest and/or build sheet. The operator selects the parts as indicated on the build sheet (either by part number or by broadcast code) and puts 'em together for that specific truck. In more detail: major components like engines, transmissions, rear axles, HVAC units, etc, are received at the final assembly plant already put together by the various suppliers. They are usually received and trimmed out in a remote area of the plant and conveyed to the main assembly line in build sequence order. Rear axles are hung on the conveyor according to the build manifest and the brake lines and shocks installed. The drive shaft is sub assembled and placed on that same rear axle hanger and conveyed to the main line, as a unit. One other nuance: usually the drive shaft assembly is attached to the rear axle before the engine/trans is installed. The front of the shaft is supported temporarily by a bungee strap and then guided into the trans tailshaft at motor set. See http://www.73-87.com/7387info/Assembly%20Line.htm photos #1, 2 and 4. I mention that only because it is one of those little tidbits that is counterintuitive, compared to what you or I would do in our own garage. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-22-2015 at 04:11 PM. |
![]() Join Date: Jan 2011
Great info as always Keith. Your perspective from the manufactures side is very insightful.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thank you; and you are welcome.
K
#14 | ||
Unfortunately (a) he didn't have any charts earlier than the GMT400 version and (b) they are not really in the format I remembered. They wouldn't really lend themselves very well to posting here or to cross referencing different usages (there are only one or two parts per page). Quote:
K
#15 |
Thanks,
I'll probably just end up getting it made if I can find one close and have a shop size and balance it.
#16 |
![]() Join Date: May 2014
I just had one made, 350/th350 in a 62, 52" CTC
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
#17 |
Many Drivetrain changes have been made to our trucks over the years.
And now we're making changes and need to get either a different driveshaft, or have ours modified. In searching these forums I've found that the lengths are all over the place. So now I'm going to start looking at other vehicles for a donor shaft. Myself, if I was to keep my ho32, I'd need roughly a 53.75" u joint center to u joint center. . So far, from just these forums I've found the following : .
#18 |
And if you have an 8.8 rear end the shaft will hit on the trailing arms cross member.
#19 |
![]() Join Date: Jun 2006
Stock driveshafts are meant for stock HP levels even if you have one shortened. I prefer to just buy a new steel DOM driveshaft without grease fittings that way I never have to worry about it.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#20 | ||
A related question/answer:.
. Quote:
. Quote:
#21 |
More:
#22 | |
Here's another thread with many donor options :
#23 |
![]() Join Date: Mar 2005
I'm running a small block with a 700r4 in my '64 LWB, and I found a combination of factory shafts that worked perfectly. No cutting or mods.
Front shaft: 1973-1987 1/2 ton Suburban (or maybe C-10 LWB?) Rear Shaft: 1960-1966 C20 Carrier bearing: Heavy duty 1960-1966 "C20 style" (shaped like a bell). You will need to run a "combo" u-joint (1310/1350) at both ends of the rear shaft if you are using a stock truck 12-bolt. At the slip joint, use the yoke from the '73-'87 rear shaft.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#24 |
I'm thinking about going out to Pick-N-Pull in the next couple weeks. I'm guessing I'll only need the wrench for removing the u-bolt at the u-joint.
I shouldn't need anything else, right?
#25 |
Also,
For donors, Did GM switch to metric at the u-joints after a certain year?
Tags |
drive shaft |
