09-23-2015, 03:34 PM | #101 | |
Re: Converting factory AC to use R134a
09-23-2015, 04:22 PM | #102 |
Hey Jimbosprint, I just finished looking thru your photo gallery. Your truck is a close twin to mine except a couple of years newer. Good work with the pictures, I never thought to document everything like you did.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
09-23-2015, 04:44 PM | #103 |
Responding to thread topic (I did not read all the posts). Best I can tell, OP is converting from R12 to R134A. From the photos, it seems the original R12 condenser is being utilized. I also see a POA update tube has been installed. While this setup may work in milder northern or west coast environments, it won't work well when temps start to climb above about 90 degrees F. The R12 condenser just is not efficient enough at shedding the latent heat from the R134a refrigerant. An electric fan would help and should be considered a must. problem is, there is not enough space to fit a fan between the condenser and the hood latch support structure.
In my experience, the POA update kit is junk. You will feel it (air temp) every time the compressor cycles on/off which will be often. Good luck. |
09-23-2015, 04:47 PM | #104 |
Um... ya. Is this where I say, "DUH?" Sorry about that. Photo #210
http://public.fotki.com/blazbk/blaze...er1.html#media |
09-23-2015, 07:43 PM | #105 | |
09-23-2015, 07:44 PM | #106 |
Thanks! Good job getting through over 500 photos!
09-23-2015, 07:48 PM | #107 |
Old member
I would drive it for a while and then re check if it's the same then maybe add just a touch more. I think you right on the mark pretty much though!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-23-2015, 08:22 PM | #108 |
Tagging this so I can come back to it.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-23-2015, 11:14 PM | #109 |
Definitely. Drive it and let it tell me what to do. My calculation of 80% of R12 came to 3.4ish cans and I'm at 3. That, and the fact that my low side pressure is riding the set point tells me that a little bit more might be the ticket. VERY happy so far.
09-24-2015, 11:43 AM | #110 | |
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
09-24-2015, 05:05 PM | #111 | |
Originally Posted by jimbosprint View Post Old Air Products told me the condenser I got is the same one they sell with their aftermarket AC kits made for 134a. It seems to work above 90 degrees. Maybe it would work better with an electric fan. That is a piccolo condenser, same as the one that Classic Auto Air has sold. They more than likely get their condensers from the same manufacturer. I saw and responded to your post on fb also about that condenser. The piccolo condenser is better than the factory tube and fin type condenser but not seen as better performing than a true parallel flow cond. |
09-24-2015, 05:10 PM | #112 | |
09-24-2015, 11:40 PM | #113 |
I'm using stock condenser and the receiver drier part number in post 83 above.
I have very little time running it, but it's been surprisingly good so far. I think the key is getting the POA valve set to 26.5psi and having a very clean and dry system. Last edited by picklito; 09-24-2015 at 11:41 PM. Reason: grammar |
09-25-2015, 01:20 AM | #114 |
Those vent temps will rise in traffic or slower speeds with a factory condenser. They all do. Electric fans will help though.
09-25-2015, 03:59 AM | #115 |
Any difference in quality between 4 seasons and AC Delco components? Price is almost double for Delco but most parts Ive received are made overseas these days.
09-26-2015, 12:23 AM | #116 | |
Moderator
Went with R-12 on my next truck with factory AC. It blows snowballs out the vents in 110 degree temps, sitting at a stand still in So Cal traffic. Yes it costs more than R 134 but so what? You charge it once either way and you are done. The bottom line is you want cold air and with R 12 you get it no matter what. What good is AC if it don't work?? No hoops to jump through and "hope" it works in the end with R 12.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-26-2015, 08:31 AM | #117 |
Is it possible to strip all of a R134 system from a newer vehicle to convert factory system over?
09-26-2015, 11:52 AM | #118 |
That's way more work than necessary.
09-26-2015, 01:05 PM | #119 | |
"Negative people always seem to have a problem for every solution" |
03-05-2017, 07:19 PM | #120 |
I have a 1969 c20 and am curious as if I should replace my air conditioning system or not? I bought the truck and the compressor has not been hooked up in years. Everything is original.
03-05-2017, 08:42 PM | #121 |
I vote for restoring an original system. If staying with r12, flush, pressure check both the evaporator and condenser. Test the poa valve to make sure It isn't stuck. Check the screen in the exp valve. You can clean it with some brake cleaner. Replace the drier. They are cheap. Some reuse their hoses/lines if they are in good shape. Hoses should not have cracks. Buy an aluminum a6 replacement compressor. Use mineral oil. If going with 134a, replace original condenser with parallel flow condenser. Recalibrate poa valve. Some will say to replace expansion valve but an original will work fine with 134a. I'd replace the hoses. Use pag oil. All this can be done for less than an aftermarket system plus it all bolts in and you get to keep the fresh air option.
03-05-2017, 08:47 PM | #122 |
Awesome, thank you for the help. The system I am looking at is on a 1970 c20 and he's selling it for $350. It's all original parts. I just don't know if the parts that I have are still good. Not sure how to test them. I have all of the parts, only thing I don't have hooked up is the compressor and not sure if it's still any good.
03-05-2017, 09:04 PM | #123 |
Since you say your system is complete on your 69 c20, then I wouldn't spend the money for another system. You can use that $350 towards new parts like the compressor, drier and hoses with a little more $added to it. You can look for a local old school ac shop or I can test the parts for you. You'd have to ship them though. I restore factory ac/heater parts.
08-18-2017, 01:23 AM | #124 |
Did you guys update the evaporator or keep it original? I'm redoing the stock a.c. system on my 1969 c20.
08-18-2017, 09:24 AM | #125 |
Replied to your pm. There are no updates to the evaporator if it's the same size. You can "update or upgrade" the poa and expansion valve setup by using a poa delete kit which most guys don't like or using an accumulator/orifice tube setup. Either way you may want to consider upgrading the steel a6 compressor to either a Sanden type or aluminium a6 replacement as those compressors are designed to cycle and they don't have the oil slinging issue that comes with the majority of steel a6 compressors.
Tags |
134a, a/c, air conditioning, r134, r134a |
